Seated skids
Old 07-09-08, 01:20 AM
awristawful
not aristotle
Seated skids
and i'm not talking diarrhea...
I've read several posts and heard a couple things about seated skids. Is this possible?
I know the nuts-to-stem basics, and i can skid locking either leg. but, i do not understand the concept of a seated skid.
what's the deal?
any videos?
any tips?
awristawful is offline
Old 07-09-08, 01:39 AM
daft crunk
daft crunk's Avatar
Bikes: alien track bike, cannondale t400 tourer
unweight your rear wheel by hopping up instead of leaning forward.
daft crunk is offline
Old 07-09-08, 02:11 AM
kogkrusher
straight krushin'
Bikes: RiGi track bike, Mercier beater, Schwin monster
For me it's more of a timing issue. The more you think about it the more you will understand when I say just lock your knees. You can also lean to the side to help you learn.
Full lean (nuts on stem) skids are the stupidest looking thing on earth. Skid up right or go home.
Actually I don't care, what ever you do, as long as (it's legal) you are on a bike it's alright by me.
kogkrusher is offline
Old 07-09-08, 02:16 AM
nateintokyo
nateintokyo's Avatar
Bikes: SE Quadrangle, '82 Venus NJS, '03 Bianchi Pista, '86 P'sonic Mt Cat, Fat City Yo Eddy '91 + '93, B'cuda A2E, '86 Trek Elance 400, '88 Centurion D.Scott Expert, '88 Fisher Mt Tam (and no longer with me: SE OM Flyer, Umezawa/B-stone/Samson NJS)
you might try leveraging your thigh (above your knee medial/ventrally) off the back end of the top tube as well (if your frame isn't sloping, anyway).
nateintokyo is offline
Old 07-09-08, 02:18 AM
iansmash
I don't know how anybody could skid while completely seated...Here's my theory on how it might be done though.
1. Be like...105 lbs
2. Have a crazy short gear ratio
3. Have superman legs
Then MAYBE it could happen I suppose.
But then again, I don't really have any of these things...I'm 200lbs w/ 48/17 gears and barely average leg strength
iansmash is offline
Old 07-09-08, 07:06 AM
bstrick11
I have to unweight a bit then I can hold it for a second as a stopping measure but not for long. I weigh 2 bills with decent leg strength and would be suprised to see anyone fully seated to lay down a long skid but what the hell do I know.
bstrick11 is offline
Old 07-09-08, 07:17 AM
1fluffhead
1fluffhead's Avatar
Bikes: Pake Track; Bianchi XL EV2 El Reparto Corse, Kona Jake the Snake
Seated skids have a lot to do with a few forces in play.
1. Leg strength
2. Gear inches
3. Speed
If you are weak and have larger gear ratio going fast it will be much harder to resist the pedal rotation allowing you to stay seated. It just takes practice to figure out your timing. Seated skids are like skipping but without standing. If you really want to increase the stopping power while seated press down even harder backwards with your rear foot, pull up with front. This causes the rear tire to rotate backwards while still going forward which equals increased drag. Seated skids are like trackstanding, they come with time on the bike. Alot of its just technique.
Originally Posted by diff_lock2
so what if it's custom, are you suddenly NOT a jackass?
1fluffhead is offline
Old 07-09-08, 07:35 AM
FixedonColorado
https://www.youtube.com/watch?v=F0AFp...eature=related
these guys have it down
FixedonColorado is offline
Old 07-09-08, 07:40 AM
TheDean
TheDean's Avatar
Bikes: Mino Denti
Im 155, I have a pretty short gear ratio, but I would not consider my legs that strong. I can do seated skids with no problems. Not sure what thats about.
TheDean is offline
Old 07-09-08, 07:43 AM
shants
roll'em high
shants's Avatar
Post two is on point -- you hop the rear wheel ever-so-slightly and then lock your legs. Once you become comfortable with the process, the hop will transition into the skid seamlessly. You don't actually need to lift the rear wheel off of the ground; you just need to reduce friction enough to start the skid.
shants is offline
Old 07-09-08, 07:51 AM
chevy42083
steel lover
Bikes: Bianchi Alloro, Miyata 710, Fuji Espree Fixie convert
Also, for those who can't do it... keep this in mind. Seat to bar drop, and bike geometry. Someone else's bike may have ALOT less weight on the rear wheel because of these two things. I mean, if all your weight is on your bars to begin with, it doesn't matter as much if you stand or sit.
Personally, I've never tried, and doubt i can. Then again, I'm on a 'lax geometry roadie conversion, with not a ton of bar drop.
chevy42083 is offline
Old 07-09-08, 07:53 AM
SuperVillain
superpredictable
It's a lot easier at first if you use your front brake at the same time. Then you can transition to doing it without. Running narrow low-tread tires helps too, of course.
SuperVillain is offline
Old 07-09-08, 08:20 AM
Moto74
Liked 12 Times in 2 Posts
1. Leg strength
2. Gear inches
3. Speed
+1. Couldn't have said it better myself. Just practice, get a feel for your bike and the way you ride, and practice more. You'll get it.
Moto74 is offline
Old 07-09-08, 09:43 AM
Flimflam
Raving looney
Bikes: 70s Leader Precision w/Shimano 600 (road), IRO Rob Roy (Fixed)
+1
Flimflam is offline
Old 07-09-08, 09:54 AM
jdms mvp
Bikes: nagasawa, fuji track pro
Quoted: 26 Post(s)
Originally Posted by FixedonColorado
they aren't completely seated
jdms mvp is offline
Old 07-09-08, 01:51 PM
BMonei
Inebriated Ninja Hatters
BMonei's Avatar
Gear down.
At 210lbs with a 65" gear, I only skid seated. It obviously gets harder with a bigger gear.
BMonei is offline
Old 07-09-08, 01:53 PM
peabodypride
No plan.
peabodypride's Avatar
clipless.
peabodypride is offline
Old 07-09-08, 03:13 PM
JayNev
JayNev's Avatar
65" gear ?? wow, thats pretty low. i have a feeling all of these 'freestyle' fixed gear riders do the same to accomplish tricks easier. is this true?
JayNev is offline
Old 07-09-08, 03:56 PM
BMonei
BMonei's Avatar
They do, as does Trial riders and BMX riders.
I just prefer a small gear. I don't see any reason to go faster then 20 MPH.
Going fast with no brakes is dangerous.
BMonei is offline
Old 07-09-08, 07:26 PM
4zn_balla
is actually asian
4zn_balla's Avatar
Bikes: Leader
i can do them, but the pavement must be an asphalt road not a gritty new one or concrete. When you do it, there's so much weight on the rear wheel that the pedals slowly overcome the skid so you can't hold it. More practical however is to skid ALMOST on the seat. I usually kinda pinch the seat and turn my back leg's knee in a tad. that way it's LOCKED. i do 48/17
4zn_balla is offline
Old 07-09-08, 07:30 PM
peabodypride
No plan.
this is the only practical way (aside from backpedalling) to control speed brakeless.
Old 07-09-08, 07:38 PM
nerdbot5000
Arg, this thread frustrates me.
I weight 115lbs, but I'm 5'7"; I run 71 gear inches, not 65, or whatever was recommended; and I've only biked for about a year now; and yet, I can seated skid, easily, and I learned it probably within a week. And I'm pretty damn sure I'm not special either. Speed helps, but it's not a huge factor either. Hopping your wheel is unnecessary.
Ok, it's all about form/technique/whatever. Try this out, I taught a friend how to skid in a day without getting his nuts to the stem by having him do this, so really try it.
1. Pedal a bit, and then ever now and then go limp and let the pedals push your legs around
2. Do the same thing, but this time, as the pedal come backwards and up, let it push your body off the saddle. Just relax and stiffen your back leg a bit to do this.
3. Do the same thing but try to completely straighten your back leg as the pedal comes backwards and up, and let it push your body off the saddle
4. Do the same thing as #3, but when the pedals start to approach the point where the cranks are parallel to the ground, resist with your front foot by pulling. You should definitely feel a point where there is a great resistance to pedaling, and that should be when the cranks and parallel with the ground.
#4 is the key to skidding + seated skids.
nerdbot5000 is offline
Old 07-09-08, 09:45 PM
voltrawn
busted my lockring doing these
voltrawn is offline
Old 07-09-08, 09:52 PM
awristawful
not aristotle
yo thank you all for the help...
i didn't think i learned so quickly, but i learned seated skids today.
after about over an hour of cycling up and down my street, i got it down.
AND I CAN SEATED SKID AMBIDEXTROUS
the most helpful tip that i read that i used that worked was
I realize that coming out of the saddle a bit is necessary for me to skid seated.
bonus news(/mild brag right): My friend had his bike since May(over a month*), and I got seated skids before him...(whispers: woot woot)
Old 07-09-08, 09:53 PM
iansmash
Originally Posted by nerdbot5000
blah blah blah
You're 115 lbs
You're very out of the ordinary and if you weighed what an average person does, you wouldn't be able to do this with such ease
put a 90 lb back pack on and now you're talking my language
iansmash is offline
