Ok...I've had it with the squeaks
I have used Look pedals since the mid 80's and have always liked them. However, recently I have had an issue with cleat squeak. I have tried everything but nothing seems to work for more than about a week. My current set up is the Look Keo Blades with the grey cleats. The squeak is not the pedal but the cleat/pedal interface. I'm tired of messing with Looks and want to see the next best option in a high end road pedal that does not squeak. I know everyone has their own opinions but I want to see if there is an option I may not have considered as I'm currently leaning towards an Ultegra pedal. Thanks.
Quoted: 4717 Post(s)
Liked 1,882 Times
Nothing wrong with SPD-SL pedals though. They are also a little better balanced, and therefore easier to enter.
I've tried many other lubes but not a spray silicone. Might pick up a can and give it a try. thanks
Likes For washed up:
Should Be More Popular
Quoted: 22600 Post(s)
Liked 8,928 Times
Rubber side down
Bikes: are fun! :-)
Quoted: 5 Post(s)
Liked 225 Times
Quoted: 1743 Post(s)
Liked 1,281 Times
I would second the silicone spray. I have never had squeaking problems with my Speedplay Zeros but I've used the spray about twice a year to make things easier.
Likes For bruce19:
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times
Yeah. I spent all of my time on Looks until that squeak pushed me away. Then spent like a decade on Speedplay. Then decided to go back to a delta style cleat for ease.....and went to SPD SL. Have never looked back. They really are one of the most superior pedal platforms for road that has ever existed. They licensed from Look and then actually did the engineering to make them amazing. Honestly just switch to SPD SLs. You'll love it and the pedal an interface will be just as intuitive as Look has been for you.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
Likes For Psimet2001:
Bikes: yes, i have one
Quoted: 1138 Post(s)
Liked 1,182 Times
you may not be looking for new pedals but i'll offer up plain old SPDs. have had them on my ride for 13ish years, never lubed them, always easy in/out, and silent. oh, and also don't walk like a duck when off the bike.
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
This is the reason I'm hesitant to give Assiomas a try.
Liked 1,882 Times
Thanks for all the input. I just picked up a can of silicon to try. If this doesn't do the trick and I don't need to apply for every ride I may keep the pedals. I feel that spending $200 plus for a pedal system should not require daily lube.
Quoted: 4560 Post(s)
Liked 2,802 Times
I use candle wax on the friction surfaces on my Look Delta and Shimano SPD-SL pedals and cleats. Just scuff the wax around, like using a crayon. Doesn't pick up grit. Lasts about a month before I need to reapply.
Bikes: Merlin Extra Light, Orbea Orca, Ritchey Outback,Tomac Revolver Mountain Bike, Cannondale Crit 3.0 now used for time trials.
Quoted: 126 Post(s)
Liked 55 Times
Yes candle wax or bar soap on the cleat, the tip and rear part. I have not used Look in 20 years but that was what I use to do. I got fed up with them and cleat wear. At $15 each, over the years, I paid for my Speedplay's with Look cleat replacement.
