Crowded handlebars
Crowded handlebars
I am having trouble mounting accessories on my road bike drop handlebars. I have a Garmin 705 bike computer, Nite Rider Minewt light, and a GoPro camera. Any ideas on how to fit everything?
Quoted: 630 Post(s)
Liked 369 Times
Barfly Prime with go pro mount splitter and niterider go pro mount
https://www.amazon.com/Nechkitter-Ad.../dp/B01ABDH5L2
Klaatu..Verata..Necktie?
Quoted: 10441 Post(s)
Liked 11,914 Times
Out Front mount for the Garmin?
Quoted: 2281 Post(s)
Liked 1,710 Times
There's also handlebar accessory mounts: https://www.google.com/aclk?sa=L&ai=...gQIBBA9&adurl=
Mad bike riding scientist
Quoted: 6221 Post(s)
Liked 4,221 Times
The Dajia accessory mount is one of the best I’ve ever used if you have a 4 bolt faceplate. Good and solid. It can’t twist on the bars like other mounts can.
Stuart Black
Stuart Black
Quoted: 2952 Post(s)
Liked 3,106 Times
Even without an outfront mount, it helps to mount your lights under the bar.
Likes For caloso:
On Your Left
Quoted: 3004 Post(s)
Liked 2,434 Times
Canyon biplane handle bar.....
Likes For GlennR:
Liked 11,914 Times
Likes For genejockey:
On Your Left
Liked 2,434 Times
Liked 11,914 Times
Quoted: 4260 Post(s)
Liked 1,364 Times
The 705 uses a different mount than newer Garmin devices use.
You can get an adapter than converts between the two. It might let you use options that work for newer models.
https://www.amazon.com/mounts-Adapto.../dp/B00DPUWXYI
Yes, the Garmin 705 is a big part of the problem , I have to slide it horizontally onto the mount which means I can't have anything else on the bar where it slides on/off. I guess I will have to go with a Garmin upfront mount and quarter turn adapter. My bike has narrow handlebars and I have bar tape which may need to be unwound to allow a little more mountable bar area.
Thanks for all the posted idea's to explore.
