Tubeless slick 700x38c tires
Old 11-06-22, 07:44 AM
Dimago123
Bikes: Giant TCR
Quoted: 40 Post(s)
Liked 5 Times in 4 Posts
Looking for a road tire recommendation that can be run tubeless in that size range
Dimago123 is offline
Old 11-06-22, 09:27 AM
chaadster
Thread Killer
Quoted: 3148 Post(s)
Liked 1,714 Times in 1,034 Posts
That’s a fattie for the road… Have you seen the Schwalbe G One Speed SuperGround TLE? It’s a low, textured tread, but available in 35mm and 40mm, and Schwalbe tubeless is the best, IMO.
https://www.biketiresdirect.com/prod...RoCND4QAvD_BwE
chaadster is offline
Old 11-06-22, 09:33 AM
theblackbullet
theblackbullet's Avatar
Bikes: I don't even
Quoted: 81 Post(s)
Liked 193 Times in 77 Posts
Panaracer GravelKing Slick comes in 700x38c and is tubeless compatible. Maxxis Re-Fuse is available as 700x40c.
theblackbullet is offline
Likes For theblackbullet:
Old 11-06-22, 09:39 AM
Hiro11
Bikes: 2022 Specialized Allez Sprint custom build, 2019 Giant Defy Advanced Pro 0, 2018 Seven Mudhoney Pro custom build, 2017 Raleigh Stuntman, various others
Quoted: 782 Post(s)
Liked 475 Times in 238 Posts
Seconded. Both great options.
Hiro11 is offline
Old 11-07-22, 10:00 AM
phrantic09
Fat n slow
Quoted: 3259 Post(s)
Liked 2,085 Times in 979 Posts
It’s 40mm, but the challenge Strada Bianca is a fast, smooth tire. it’s also not hard to mount on a modern, wide rim as people claim.
BRR shows it as the 3rd fastest gravel tire behind the GP 5000s TR 32 and Snoqualmie Pass EL.
phrantic09 is offline
Old 11-07-22, 10:06 AM
Polaris OBark
ignominious poltroon
Polaris OBark's Avatar
Quoted: 2242 Post(s)
Liked 3,443 Times in 1,802 Posts
I use Rene Herse extra-light Barlow Pass (38mm x 700c). They are ideal on road and quite competent off-road. If I had to choose one tire/one bike/one wheelset, it would include these tires.
Don't let anyone tell you they are too wide for the road. Narrower tires don't really have an advantage, except a tiny weight difference, or possibly an aero- advantage at speeds I rarely approach.
Polaris OBark is offline
Old 11-07-22, 10:18 AM
Atlas Shrugged
Quoted: 1248 Post(s)
Liked 1,323 Times in 674 Posts
+1 Panaracer GravelKing Slick 38mm, full time road/gravel tire.
(https://www.panaracerusa.com/product...g-gravel-tires)
Atlas Shrugged is offline
Old 11-07-22, 07:28 PM
Polaris OBark
That Panaracer GravelKing looks a lot like the Barlow Pass (which they also make for Rene Herse).
Old 11-08-22, 03:35 PM
redlude97
Quoted: 1975 Post(s)
Liked 232 Times in 173 Posts
The construction is quite different. The panaracer uses a less supple casing and a thinner tread to get the low rolling resistance and suppleness. The RH uses a more supple casing with a thicker rubber. They tend to last much longer and are more puncture resistant but more prone to sidewall damage. The endurance casing is similar to the panaracer standard casing.
redlude97 is offline
Likes For redlude97:
Old 11-13-22, 04:44 AM
Dimago123
Bikes: Giant TCR
Quoted: 40 Post(s)
good to know. I went with panaracer due to their lower price. I’m the future may try the RH. Thanks!
Old 11-13-22, 10:14 PM
Lombard
Sock Puppet
Lombard's Avatar
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times in 573 Posts
Pretty much the same concept, but the Panaracer costs less.
Lombard is offline
Old 11-15-22, 08:10 AM
phrantic09
Fat n slow
And is also a completely different tire despite looking similar.
Old 11-15-22, 12:14 PM
Lombard
Sock Puppet
Lombard's Avatar
Well yes, the Rene Herse tires are lighter and more supple allowing you in theory to go faster and have a plusher ride, yada, yada, yada. I have ridden both and can't tell the difference other than the Rene Herse are less puncture resistant, wear out faster and make my wallet lighter.
Lombard is offline
Likes For Lombard:
Old 11-16-22, 11:06 AM
phrantic09
Fat n slow
I don’t buy Jan’s nonsense most of the time, but IME an extra light far exceeds anything in the gravel king line. But again, my preference for a wide slick is a Strada Bianca HTLR- very fast and decent protection
Old 11-16-22, 03:22 PM
Lombard
Sock Puppet
Lombard's Avatar
I did in fact check out the Challenge Strada Bianca, but they didn't have it in the size I wanted for my gravel bike which is 650b x 42.
Lombard is offline
Likes For Lombard:
