Goodbye Floor Pump?
Habitual User
Quoted: 4957 Post(s)
Liked 8,099 Times
Goodbye Floor Pump?
My current floor pump (mediocre quality, mostly plastic, and been around for a while) is starting to have issues, so it's time to replace it. One of my needs is a gauge that can provide fairly accurate readings for low pressure (MTB and gravel) as well as high pressure (road, trainer, and tubeless booster), which reduces the options to digital or dual-stage dial gauges. I'm finding that most better-quality floor pumps have a 0-220psi gauge (even if the pump is only rated for 160psi) that provides terrible resolution for the ranges I use. I'm not looking for the cheapest option, but one that will suit my needs best. Silca tends to be the standard by which all others are compared, and are well-proven to last nearly forever. Lezyne seems to make some pretty decent classic-style pumps, too. There are some good contenders from Topeak, Specailized, and others.
While poking around researching floor pumps, I came across an idea on another discussion forum - a cordless inflator. The wood shop side of my garage already has a family of Ridgid 18V cordless tools, and a bunch of batteries. Ridgid also makes an inflator in the same family with a capacity of 150psi. It has a digital gauge with the ability to automatically stop at your pre-set pressure.
Replace the end with a swanky Silca Hiro presta chuck, maybe with a longer hose, and this might be a nice little device for use in my home shop.
Is this unnecessary? Definitely. A decent floor pump has worked just fine for for a whole lot of folks, for a whole lot of years, and the classic track pump is part of the tradition of cycling. I had thought about going the route of a small (1-2 gal) compressor, but I think I like this cordless idea better. A couple of downsides is that it isn't very quiet, and it cuts out pretty much the only upper-body workout I get, besides bringing groceries in from the car.
What ya think? I'm not asking what floor pump you use, or which one you think I should buy. I am curious about your thoughts on using a cordless inflator.
Likes For Eric F:
Friendship is Magic
Bikes: old ones
Quoted: 26425 Post(s)
Liked 10,381 Times
...I've never used something like that, which is small and portable. I have, in the past used a portable Hitachi twin tank compressor, when it was out and not stored under a workbench. With the compressor, since I had to wait for it to pressurize the tanks, it turns out easier and just as fast to top the tires off with a track pump, and I can get a little higher pressure with the floor pump than I can with the compressor. I inflate some tires to 130 psi.
I think I'd try to find out how long it will take to get up to the tire pressure you have in mind, before I bought one.
Likes For 3alarmer:
Quoted: 696 Post(s)
Liked 910 Times
For well over 10 years I’ve been using a Husky 1.5 gallon small compressor and hand held gauges.
Likes For Ghazmh:
Quoted: 540 Post(s)
Liked 416 Times
I've always worked in car garages since my teens, so it's compressed air for me always. It's so much faster and predictable with compressed air coming from a tank.
Tankless inflators are great for things like matresses and basketballs, but since they take a long time to inflate anything, it's easy for you to get distracted while it is filling anything, next thing you know, pop.
The smallest compressor on a tank is all you need, these often go on sale anytime the year because they are the least useful. They can only drive small things like nail guns. There are even more available used as folks often want bigger ones to run bigger air tools or paint, but big units are not required for tyre inflation which only needs seconds of delivered air.
The tanked air compressor will also open your eyes to the many other wonderful things you can do, the biggest being able to use it to dry bikes quickly as it blows air out of places that can take hours to evaporate.
This is also the reason why there is a Park Tool INF-2 Shop Inflator, they don't make a tankless inflator.
Likes For soyabean:
Habitual User
Liked 8,099 Times
Likes For Eric F:
Habitual User
Liked 8,099 Times
I haven't completely abandoned the idea of a small compressor. Is waiting for the tank to charge much of an issue? The cordless would be much more mobile in my space, however.
Quoted: 314 Post(s)
Liked 683 Times
I have one of these that I take on trips with me when flying with my bike, a Fumpa USB rechargeable mini-pump. A track pump is additional weight that I'd rather not carry in my bike box.
https://www.fumpapumps.com.au/
Is it totally unnecessary? Yes. Is it kinda cool? Yes.
Do I sometimes get lazy and use it at home instead of my track pump? Yes... 😂
Likes For tempocyclist:
Habitual User
Liked 8,099 Times
I have a Silca Pista pump purchased new in 1986 and it is still working. Costs nothing to use and is rebuildable when it needs it. To date only two plunger leathers have had to be replaced, and just this year the rubber gasket in the pump head wore out. Pumps to 150psi all day long, and the gauge is only off by 10psi after all these years.
I can guarantee that Rigid compressor will not be working 30 or 40 years from now, and will be taking up space in a landfill with the battery leaking crap that is not healthy for man nor beast. Why add such complication to an easy menial task? What is so time consuming or difficult about topping off a bicycle tire with 10psi of air using a well proven and effective design such as a manual floor pump?
Likes For TiHabanero:
Quoted: 1364 Post(s)
Liked 1,678 Times
The older I get, the more attractive e-assist for both cycling and pumping become.
Likes For BobbyG:
Quoted: 8287 Post(s)
Liked 9,057 Times
When I rode dirt bikes I used a compressor which plugged into the car. I did have a floor pump as a back up. Never had any problem with the compressor. I did always use a separate low-pressure gauge because I ran 9 psi in the front.
I use floor pump for the bikes but also use a low-pressure gauge for the mtb. I run 15 psi in the front and I don't know how accurate the pump gauge is at the low end. I would think the digital gauge on the new compressors would be pretty good.
Likes For big john:
Habitual User
Liked 8,099 Times
Admittedly, I have an attraction to gadgets. I also have an attraction to well-made simple devices like the Silca Pista Plus...in red, of course. However, it bumps up against my issue with gauge resolution. The new Silca Terra solves the gauge issue, but is limited to 120psi, which isn't always enough pressure in a tubeless booster to seat a tire.
Likes For Eric F:
Quoted: 3514 Post(s)
Liked 2,927 Times
I use a Silca Pista Plus with a Hiro chuck. I’m pumping to high pressures so the gauge works well for me. But I also have a compressor in the garage.
Likes For smd4:
Quoted: 1562 Post(s)
Liked 1,734 Times
You should just get a proper air compressor with a tank. It's much better for seating the bead on a tubeless tire. The tankless thing will not give you that blast of high pressure air to seat the bead.
No question about it, tubeless requires a huge volume of air to seat the bead, and therefore a compressor is needed, and one with a tank is recommended. Fortunately I do not have a need for tubeless tires, thus the standard floor pump works beautifully for my applications.
I do have a pancake compressor used for car and motorcycle tires as well as air tools that I use every so often. Simply don't use it on the bicycles.
Friendship is Magic
Bikes: old ones
Liked 10,381 Times
...I use the inflation of my bike tires as part of my standard warmup routine. If I stopped doing it with a floor pump, I'm sure I would hurt my back, or something else, on the ride.
Interestingly, I have both a couple of older Silca track pumps, and Newer one I bought from Performance, when it was on sale and I needed one. I had to rework that one using some Loctite on the barrel threading after a few years. But I use it the most frequently, because it moves a larger volume of air per stroke than either of the Silca pumps.
Quoted: 195 Post(s)
Liked 234 Times
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Works perfect, just set the psi you want and forget about it. Don't run tubeless so dunno there.
Likes For DonkeyShow:
Quoted: 314 Post(s)
Liked 683 Times
I looked into those special tubeless track pumps, but an air compressor was only $30 or so more and can be used for other things.
Quoted: 3956 Post(s)
Liked 7,307 Times
Quoted: 1401 Post(s)
Liked 1,886 Times
we have a number of pumps including two Silca pumps - but only use the pumps to partially inflate a tube when mounting bike tires
other than that - always use a small portable inflator to inflate bike tires
also use an inflator to top off car and truck tires
primarily use a DeWalt inflator ... also have a smaller Worx inflator but rarely use it
the DeWalt inflator is one of the 'handiest' tools we have
( note : we have a small air compressor (30 gallon tank) that I have not used in years )
Habitual User
Liked 8,099 Times
I already have an Airshot canister for help when my floor pump doesn’t get the job done. A compressor is still a consideration, but the lack mobility (or needing to deal with stashing a long hose) has me a bit hesitant to go that direction. I’m also not sure where I would put it.
Habitual User
Liked 8,099 Times
I agree that a floor pump would probably do what I need just fine, and I’m not saying that a cordless inflator is superior. The idea caught my attention, and I’m thinking of giving it a try.
Habitual User
Liked 8,099 Times
What type of chuck are you using with the DeWalt inflator?
Mad bike riding scientist
Quoted: 6220 Post(s)
Liked 4,221 Times
Something else to consider, if there is an error in the analog gauge, the amount of the error isn’t going to be all that great. It’s not like you pump it up to 15psi and it’s actually 5 psi. ±2psi is a probable error range.
Stuart Black
Stuart Black
Likes For cyccommute:
Liked 9,057 Times
There is an assumption that a digital anything is more accurate than analog anything. This isn’t necessarily the case. Just because the digital readout gives you a number doesn’t mean that the digital readout is reading the value correctly. Every measuring device made has an level of error associated with it.
