What are you current favorite tail lights for daytime road riding?
Bikes: 2011 Fuji Roubaix 2.0 (Tiagra)
Quoted: 36 Post(s)
What are you current favorite tail lights for daytime road riding under $75?
I am looking to purchase a new LED rechargeable tail light for daytime riding as mine is not able to be charged any more.
What taillights are you using?
Thanks,
RH
Thanks,
RH
Non omnino gravis
It is eye-scaldingly bright. I've had people roll down their windows (during the day) and say, "Man, that is the brightest light I've ever seen on a bicycle. I could see you from like a mile away."
And I always respond, "That's the idea!"
Quoted: 36 Post(s)
I'm not sure I want to annoy people, but I want to be seen for sure.
Now as for the price, that I can live with. How is it to plug in and all?
RH
RH
Jedi Master
Anything with an off switch is fine during the day.
Quoted: 36 Post(s)
Haha, what funny...
Seriously what lights are you guys using?
Upgrading my engine
Quoted: 125 Post(s)
https://www.serfas.com/shop/products...50-150-lumens/
I'm using this at the moment. It's pretty bright and the battery life is outstanding. I do 6+ hour rides at least once a week, so battery life is huge for me.
Its weakness is the mount. First, it doesn't come with a clothing/bag clip. Second, it doesn't mount on my chainstay very well. For some reason it always wants to move to the side where it's not as visible. Maybe a little roll of some old inner tube will fix that. The seatpost mount is fine. That's where I have it most of the time.
Non omnino gravis
My thinking is, to annoy someone they have to see you first. So in reality, at least for a few moments, we do want to annoy people.
Quoted: 4560 Post(s)
Liked 2,802 Times
Cygolite Hotshots are a best buy in daytime visible taillights. The DiNottes are great but cost more than my bike.
Re: @DXchulo's tip: Looks like Serfas has addressed my one complaint about Hotshots -- the ability to dim lights on flash modes. The Hotshots can be dimmed only in steady mode. They still peak at full blast on any flash/strobe mode, so I can't use them on nighttime group rides. I've been toting an extra taillight that's dimmer just for those occasions. But the Serfas Spectra appears to be adjustable from bright to dim in flash modes as well.
Non omnino gravis
Quoted: 285 Post(s)
I don't think clipping in to your shorts would be a secure way to mount a light.
I'll go along with the recommendation for the Cygolite Hotshot 150. I don't use mine in the day but I'm sure it's bright enough to be seen well in the later part of the day.
The Serfas tst-150 Spectra looks like a nice option. I own a couple of the earlier versions of the Serfas's and those too are very bright lights. Nice to see that Serfas upgraded to a 150 lumen version. If I didn't already own a Hotshot 150 I'd buy one of those.
Things that need to be mentioned; Not all the modes on the Hotshot offer the highest output. I use the adjustable ( timing ) fade in and out mode. That mode is one of the ones with maximum output. One of the other flash/pulse modes is also max but some of the others ( including adjustable steady ) are not.
With the Serfas 150 only the Daytime flash mode is 150 lumen. That said I'd like to see one in action just to see if I like the flash sequence. I checked Youtube but don't see any reviews of it yet. At lease with the Hotshot's you can adjust the timing of some of the flash and pulse modes and I like that.
BTW I do carry something for daytime use but I rarely use it. It is torch mounted under my seat on one of the seat rails ( Velcro'd in place ) The torch uses a very bright amber XP-G2 drop-in that is custom set to use about 1500ma. I don't know what the actual output is but it is very, very bright. maybe somewhere in the 350-400 lumen range. The driver is set-up with a wide variety of flash modes. I have it set-up on a triple pulse / pause mode. I love it but since I have the Hotshot 150 I've thought about removing it since I don't use it that much. It's real hard to set-up though so that's why I can't bring myself to remove it.
don't try this at home.
Quoted: 974 Post(s)
Liked 512 Times
Yes, the Hotshot 150 works great. It's 150 lumens on the short flashes, 90 lumens on the longer flashes or on steady. I got it specifically for better daytime visibility.
I use the "single flash", slowed down to about 2 bright, brief flashes per second for daytime use. I'm trying to get drivers to notice me when I'm still far down the road.
Solo at night, I use the "wah wah" / "fade" medium speed blinking that doesn't flash, instead it smoothly increases and decreases. I expect it's less annoying and less confusing to drivers, but still grabs attention.
The light is aimed slightly below level, but still lights up reflective signs way,way back. I can see the red pool of light on the road if I look back. That's bright!
There's 5 different blinking modes, really too many choices to cycle through.
For group rides, the steady light mode can be dialed way down to "quite dim". The dim, steady light is much nicer for the following riders, and there's enough lights (some flashing), and various reflective bits to make the group really visible anyway.
Upgrading my engine
Quoted: 125 Post(s)
I might make a review video later this year. I've only had it for a few months.
The flash sequence on the daytime mode is basically two quick flashes, then some dead time, then two quick flashes. There's kind of a long time between the flashes. I'm sure that's why the battery life is so good in daytime mode.
I can say that I do believe their battery life claims. I did a 400-mile ride with it using daylight mode during the day and just a regular flashing mode at night. I didn't run out of battery and that ride took me almost 30 hours.
Quoted: 139 Post(s)
Liked 33 Times
Another happy customer of the Cygolite Hotshot Pro 150 lumen light. I also have the original Hotshot. And then I upgraded to the Performance house brand Axiom Pulse 60. My only complaint with that light is that the thing on the back was shorter than other lights and I had to create an extra tie down so that I would not lose it off the seat bag.
All of these lights are USB rechargeable and the newer ones use the micro USB and the older ones use mini USB.
Liked 2,802 Times
- Very lightweight and compact.
- Clip secures to the provided mount, a belt loop, belt up to 1" wide, saddle bag light mounting loop, shirt collar or front pocket, backpack or shoulder bag, hat band, inside a camera/handlebar bag for nighttime use, etc. It has a well designed backup retention hook to minimize the risk of it popping loose.
- Better side visibility than the Cygolite Hotshot.
- Four modes: steady red; flashing red; steady white; flashing white.
- Steady white mode is very even and suitable for reading maps, illuminating the inside of a tent or small room in an emergency. But it's not a headlight to see the road by unless you ride slowly.
I mention the Blackburn 2'Fer often because it's a great value for what it does well -- a versatile to-be-seen light, and reading light. It may not seem competitive with the Cygolite Hotshot, which is the best value I've seen in a bicycle taillight. But at roughly the same price it's not confined to that niche role. That's why I have both. And the 2'Fer is available in a two-pack for a discounted price.
About the New Serfas 150 tail light
The flash sequence on the daytime mode is basically two quick flashes, then some dead time, then two quick flashes. There's kind of a long time between the flashes. I'm sure that's why the battery life is so good in daytime mode.....I can say that I do believe their battery life claims. I did a 400-mile ride with it using daylight mode during the day and just a regular flashing mode at night. I didn't run out of battery and that ride took me almost 30 hours.
Quoted: 36 Post(s)
The Hot Shot 150 looks like something to look into.
Bikes: 2018 Roubaix Expert Di2, 2016 Diverge Expert X1
Quoted: 482 Post(s)
Liked 151 Times
I have a 60 lumen Serfas I like a lot, have been told by coworkers they can see me from quite a long way off. I am thinking about maybe trying a Cygolite Hotshot Pro 150.
Quoted: 7350 Post(s)
Liked 2,475 Times
I don't ride where the difference between my speed and that of other road users is great, so I use one of the lower level Hotshots. I pretend it's not on and rely on my body language to convey how I will act, and I use my mirror to predict how others will act. Maybe this is not the best strategy for survival, but so far, I'm still alive. I do a lot of squiggling, though, to assist others in noticing me, when I think it will help. I don't ride at the edge of the road unless I believe I've been seen first and we have an agreement as to who will go where. Without that agreement, I often take the middle of the lane.
Bikes: 1998 Cannondale F900
Quoted: 24 Post(s)
For under $75:
+ 1 Cygolite Hotshot 150
They also make a Hotshot 100 (or they used to anyway).
I have a Hotshot Pro 80 and I would say for daytime use, it is moderately effective.
Don't bother with anything under 50 lumens if daytime visibility is what you're after. So many times I will see riders that are using blinkies in the middle of the day, and you cannot even tell they have one until you are within 5-10 feet of them. Just a waste of batteries/electricity.
Hotshot Pro 80 from a little ways back in full sun:
https://www.imgur.com/a/4GI44
...Don't bother with anything under 50 lumens if daytime visibility is what you're after. So many times I will see riders that are using blinkies in the middle of the day, and you cannot even tell they have one until you are within 5-10 feet of them. Just a waste of batteries/electricity.
Just the other day I saw a lady riding a bike on a heavily traveled road about the time the sun is setting in the sky. I was going the opposite direction and noticed first her very bright front strobe/blinker... ( +1 for the lady ) ...but as I passed I looked in my mirror and noticed that she had just the type of rear light we are now talking about. Turns out I saw her two days in a row. If I see her again I just might turn around, pull off the side of the road and give her one of my older rear lamps. On the road she was riding she needs it badly.
I have a Knog Blinder Road R70 Rear Bike Light. 70 Lumens, 5 red LEDS, 5 modes of flash, steady, and chaser. Awesome light for both day and night. Very reasonable price and great battery life. Knog.com
