flashing lights that last more than 2 hours
Quoted: 27 Post(s)
I really like my Serfas Thunderbolt lights I bought a few years ago-they strap on with some flexible ties anywhere i want to put them and they are a very bright flashing white one and red one. But they quit working after a couple hours when flashing bright. Is there a light that makes it to 6? Or is it because they are several years old?
Cygolites https://cygolite.com/product/
Quoted: 377 Post(s)
Liked 221 Times
How much do you want to spend?
I have a Dinotte Quad Red and while it's expensive it's in my opinion the best light money can buy. I get about 8 hours from mine. https://store.dinottelighting.com/new...tery-p111.aspx
I also just ordered a Lezyne Zecto Max and posted about it here: https://www.bikeforums.net/electronic...50-lumens.html It's $50 and it's 250 lumens. According to their site, when set at the 250 mode it gets 9 hours of battery life. https://www.clevertraining.com/lezyne...ng-light-black
Another decent option is the Orfos Flare Red Pro ($75) and it;s rated at 400 lumen. You would need a USB battery pack for it as it does not have an internal battery. Run times would then be dependent on the battery packs capacity. https://www.orfos.us/collections/fla...epro-pre-order
Those are my recommendations. There are plenty of other options but I like the high lumen lights.
Cycle Dallas
Bikes: Dulcinea--2017 Kona Rove & a few others
Quoted: 197 Post(s)
Liked 10 Times
I use a Cygolite Hotshot 150. I have a two-hour commute, one way. I plug it in to recharge when I get to work. I have forgotten to plug it in and it has lasted for the ride home. So I can vouch for it lasting 4 hours. I've never pushed it beyond that.
Forum Moderator
Quoted: 3091 Post(s)
Liked 6,601 Times
Thread moved from Advocacy & Safety forum to Electronics Lighting & Gadgets forum.
Quoted: 4560 Post(s)
Liked 2,802 Times
Cygolite Hotshots run a ridiculously long time between charges in some modes. I usually run my Hotshot SL 50 in triple flash mode, which Cygolite claims is good for 36-96 hours depending on tempo setting. The zoom and steady pulse modes, which alternate between steady and flash are good for 3-10 hours.
I haven't timed these but even when I run the Hotshot on every ride, including daytime, I only charge it once a week -- usually before the low battery indicator starts.
But the Hotshot isn't as slim as the Thunderbolts and doesn't strap easily to the seat stay.
I usually clip the Hotshot onto a saddle bag loop, or to the provided seat post mount on my road bike, just below the saddle bag.
Quoted: 7350 Post(s)
Liked 2,475 Times
Headlight or tail light?
Quoted: 139 Post(s)
Liked 33 Times
I have the original Cygolite Hotshot and the Pro 150 and like them both. The original has mini USB port for charging while the 150 has micro USB.
CliffordK
41
05-14-18 01:20 PM
ColonelSanders
General Cycling Discussion
11
04-28-16 05:21 PM
Richard Cranium
2
03-26-10 01:24 PM
