First Ride On Superteam Carbon Wheels
#76
I pedal in my sleep...
Sorry to hear it, hope you recover quickly! I'm also healing from a crash last weekend, at a gravel race (crash was on a paved section between gravel segments). Road was wet and I knew I was going too fast, bike started to slide on a sharp right hand curve and then high-sided, tore up my left leg pretty good when I landed. Bike was mostly ok and still rideable, and I still had 20 miles to go in the race, so I kept going. Leg is healing, nothing broken thankfully, but I'll have some good scars. At least the cause of mine was obvious, yours def sounds odd.
#77
Destroyer of Worlds
Just reading through this and wow. Firstly, sorry to hear about your wreck and injuries. Get well soon! Also, great detail and information all around. Thanks for the contribution with regards to these wheels. They look amazing, as do your bikes!
#78
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times
#79
Thanks. Yup, it was the Revolt. Scuffed the shifter and pedal, and tore the hood cover, but mechanically it was fine. I was surprised there wasn't more damage considering the speed and the tumble I took across the road and off the shoulder. Guess my leg took most of the impact. lol Looked back at my Strava data and I was def going way too fast. It's funny, the gps track doesn't always follow the road precisely, but it definitely tracked me going right off the other side. I'm extremely thankful that a car wasn't coming, they would have hit me without ever even seeing me.
As far as that front wheel goes, the more I look at the damage, the more I really feel like it's just superficial. The actual feel is no more than a light scuff, and doesn't seem to be any gouging into the carbon. The scuff is also above the brake track and does not extend into the lip. I'd relate it to taking some rough grit sandpaper and cosmetically scouring the surface of the wheel.
So I'm going to take the wheel to my shop, get it trued, get a professional opinion on the damage, and then go from there on a replacement.
#80
he said member
Bikes: yes please
Quoted: 2789 Post(s)
Liked 1,951 Times
I would scrap that wheel. The hook for the tire bead is just on the other side of that damage. If that portion of the wheel fails, you are going to blow the tire off the bead. Carbon doesn't like that kind of abuse.
Just get a new front wheel, it wont be that expensive. Sure be cheaper than another busted collar bone.
Likes For ls01:
#81
#82
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times
Could you describe in your opinion what the "profile" of the wheel is? Is it more of the older classic rounded "vee" shape, or is more of the modern bulged out "U" shape?
I see a lot of the open mold Chinese stuff going to the modern shapes, but if I buy something (even these) I don't want to be getting the old school tech.
I have wondered a bit about wheels in general what the wear/incident rate is when comparing it to rider weight and rider location. A 90kg rider in crap British or roads in Maine will probably have a tougher time than a sub 70kg rider on generally good roads will have.
#83
Quoted: 4717 Post(s)
Liked 1,882 Times
Your wheel has slight abrasion damage, not heavy impact damage..
#84
My weight also fluctuates between 75kg and 68kg depending on the season. Roads locally are pretty rough with potholes, chipseal, and patching the preferred method of fixing rather than full repaving. I have been very impressed with how the 38s held true through the many times I banged through an unexpected pothole or transition. Only very recently had the rear one gone slightly out of true and it's not even enough to have bothered fixing yet. They are currently at 4300 miles.
With your experience, I appreciate your input on the damage.
Likes For str8jakett:
#86
Wow, I’m new here and read all the remarks, bummer there’s crash n burns and heart break and busted wallets, however, my history in riding has been over 15years, I got excited and bought the new tarmac expert with disc, over my alloy rim brakes (at the time I never thought of carbon), VERY FIRST RIDE- coming off a 20 percent grade brakes boiled and over heated and flew off the side ! Luckily heard fast, lot a of road rash, helmet gone, shoes gone, gloves trashed, bibs gone, bike cracked at head tube, (fork held up) ... so went back to rim brakes. Long story short, I had a borrowed pair of Zipps 404s and bought some rovals 50mm and 32mm and fulcrums. I got in a pinch and sold em, when I wanted some new wheels, I got some off Craigslist, (yoeleo) and held up great, sold em, (mistake) later on, looked deeply into super teams, I live close to Colorado and have mtns 30mins away, and love to ride them much as possible, bought a climbers set, 40mm novetec hubs cxray spokes, actual wieght 1355grams! Tbh the road better than others I’ve had, spun up well, brakes impressive, sometimes I wud do a hard stop to touch the carbon, and it was hot haha but never felt so confident in braking or climbing and descending in the same mtn I wrecked on! So, I bought a set of 50mm, and now I just got 60mm and read this forum, I have over 3000 miles on them and it must been a build thing, I have had to true them nearly the 3000 mile mark. But love em love em!!! I refer my friends to them! And I did the same thing with Ellie, hounded and hounded! I felt bad! But all wheels have held up and love the builds! One draw back... I’ve noticed the clear coat fades over time.
#87
The front wheel with abrasion damage is at the LBS for a truing job and inspection and so far everything is looking good. There is no damage anywhere else on the wheel, nothing under the rim strip, and the wheel seems to be straightening out fine. Once I get it back, I still won't be able to test ride it for a few weeks but I will be looking forward to the results.
#88
Quoted: 1461 Post(s)
Liked 1,486 Times
This thread is really informative and the regular updates are awesome and appreciated. I hope the injuries have healed up from your crash.
I have an older canti brake CX bike that I needed a cheap wheelset for. After looking at various aluminum rim brake options I decided to order a set of 23mm wide Superteams via Amazon Prime. I went with the 38mm depth and these have the Powerway R13 hubs, and 3k matte finish with the glossy black logos. I debated going for a deeper section, but I'm planning on running 28mm tires which I think are too large to get true aero benefits on a 23mm wheel, and plus it's an old canti CX bike, so... does aero really matter that much? I dunno... the 38mm version was slightly cheaper and a little lighter.
This is my first/only carbon wheelset. I always thought rim brake carbon wheels were a terrible idea in general, but I only paid $329 for them and my expectations are pretty low. I will not be descending mountains on these or racing them in the mud, and still have an old aluminum wheelset for winter/rain riding. The main selling point for me was that these wheels were at least $150 cheaper than a comparable aluminum set, and they were wider than the Shimano Ultegra wheels they are replacing.
The box arrived today, professionally packed and damage free. The wheels look great, are true and seem to spin smoothly. Spinning them in my hand the rear hubs seems super loud, which may be an issue for some but isn't likely to bother me. They are low spoke count (20F/24R) but I'm not very big (5'-9"/155lbs) and will not be off-roading on them, so I'm not super worried about this. I was surprised to get skewers, which I didn't think were included. They also included some extra spokes and a set of brake pads. I have ordered a set of Swiss Stop black prince pads, but they haven't arrived yet so I'll probably give the Superteam pads a whirl for a few days. I don't have a scale but have seen other posts where buyers confirm the published weights, which is 1540g. On paper they're 100g lighter than the Ultegra wheels they are replacing. No idea if I will actually notice any difference or not.
Once I get them mounted up I'll post some photos and thoughts after an initial ride or two.
#89
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
OK I get it, lighter wheels are better. No argument from me there.
That's the reason I went for a pair of Mavic Ksyrium Elite UST (Aluminum) at a Mavic stated weight of 1520g / pair (without tires)
Cost me $410 out the door with the included Mavic TL tires and sealant.
But I don't understand the advantage of Carbon if the weight is similar ?
What am I missing?
Thanks
Barry
What am I missing?
Thanks
Barry
#90
Liked 1,882 Times
What am I missing?
Thanks
Barry
What am I missing?
Thanks
Barry
#91
Liked 1,486 Times
What am I missing?
Thanks
Barry
What am I missing?
Thanks
Barry
Those Mavics look like nice wheels. The sticker price on them is $750, so you got a good deal. My only concern with those would be that they come with 25mm tires, which is narrower than I'd prefer to ride.
#92
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
I am not aero enough (yet) to even consider aero wheels.
I didn’t think about profile. Thanks for the info.
oh, appearance........ way cool
Barry
Barry
#93
Will do.
Oh and question...my front wheel makes a weird sound and I'm not sure if it's just the way these carbon wheels are. These are my first carbon wheels I ever rode on. I think the front hub is fine because on the stand they seem to roll smooth and silent. When hammering a bit I notice almost like a constant whoosh type sound in the front. I wonder if it's a wind noise, or just road noise.
#94
Bikes: Trek Domane SL7 Disc, Cannondale F29
Quoted: 389 Post(s)
Liked 325 Times
This thread being 2 years old, has anyone purchased "SuperTeam" wheels recently? The cool looking wheels purchased by the OP don't seem to be available any more... at least not in that zig-zag carbon weave pattern. In just the last year or so, wide disc rims are all the rage, so I'm wondering if any of you have purchased the disc wheels and what your impressions are.
#95
Liked 1,486 Times
I was only shopping on Amazon, and only looking at rim brake options. They had 23 and 25mm widths for rim brake in stock, but probably have wider versions for discs.Their website shows a ton of options.
The wheels I bought are a 3k matte finish, with the logo being polished. They look like this:
#96
I haven't looked recently but the 12k was still available in a few eBay auctions from certain sellers. I also basically picked the options on the first set bought from kingbike and the 12k weave was something I asked for specifically during one of the many emails back and forth.
This is the third season on the set, although I haven't been outside very much so far, riding a different bike indoors. They are still holding up nicely, spin free, and brake track looks good. 4,633 mileage count.
#97
Trying to keep up
Bikes: Pinarello Prince, Orbea Onix, Ridley Fenix
Quoted: 79 Post(s)
Liked 136 Times
I ordered a set of these in late July and had them by August 1. So far I have about 450 miles on them; they have been fantastic. They were true when they arrived, and I've now ridden them on a mix of nicely paved trail, good roads, and absolutely terrible roads. I've been very impressed with them, though I had some initial issues getting the brakes set up (my fault - the rims are a good bit wider than what I had). These are my first 50mm rims after a couple of decades of riding, I am enjoying them. While I don't have a true way to compare my speed with them versus my old wheels - too many variables, no power meter - they certainly feel fast (though that may obviously be psychological). The only negative is the read hub is very, very loud.
Anyway, for the less than $400 I spent on them, I couldn't be happier. Unless they detonate after a few thousand miles, I am quite happy with the wheels and feel fine riding them every day. I may have eventually purchased more expensive wheels, but the low cost of these certainly made me feel better about trying carbon rims.
Getting ready for a metric century.
The chug checking out the new wheels.
#98
Bikes: ...a few.
Quoted: 2012 Post(s)
Liked 409 Times
Got a set back in February. I've put on close to 4000 km so far. No issues. Gone over ruts and pot holes. Check them every ride. Still in great shape. They are good value for the money, and look pretty good, but as far as performance improvements are concerned, it's pretty marginal at best. Don't expect to be going 2 mph faster all of a sudden with the installation of these or any other set of carbon aero wheels. Maybe if you were regularly averaging 30 mph on your rides you might see a bigger benefit. But for those of us who are happy doing 20 mph average, I'm happy with the aesthetic improvement alone.
#99
5700 miles and still happy.
Updating this thread to move them to a new bike. The 2015 Propel is donating it's groupset and Superteams to a new-to-me 2015 TCR.
Still working out the fit, waiting on steerer parts before cutting, since I know someone will call me out on that .
#100
Question for those who have purchased Superteams. It looks like most of these wheels have a rim size of 23-25mm. Would that mean you couldn't run a 25mm tire?
