Stem/handlebar locknut ?
Hi, I'm trying to disassemble this bike, which I haven't touched for 8 years. Can anybody help me to identify which tool I need to get this locknut (?) off? I think I must have it lying around somewhere, but it's been a while
Terminology unclear
Not sure what you need
Headset locknut? or stem or handlebars
Quill stem has a wedge dont unscrew it all the way just a bit to be proud, then use a mallet and hit the bolt end, tonreleasr the wedge
Your Public library has bike repair books to read, you know.. you can ask better questions then..
Quoted: 2026 Post(s)
Liked 1,096 Times
The correct tool is indeed a lockring wrench but a brass punch inserted into the notches and driven with a small hammer can work too.
NB newer headsets have eliminated that notched ring so you dont have to put it back on.. throw it away ..
just add a spacer.of similar thickness, . & use 2 wrenches..
a special headset 32 for the bottom , and a adjustable spanner , for the lock nut you already removed in the picture..
French manufactured headsets & other stuff get shipped across the English channel for assembling bikes in England , of course..
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3890 Post(s)
Liked 6,488 Times
Once you remove it with a hammer and big flathead screwdriver, you can throw it away. Just use an aluminum spacer in its place.
So you buy a hook spanner that fits, buy the right tools.. you reuse them, I Don' t ... ( I have seen old ones with teeth interfaces and no flats for wrenches)
Campagnolo never did not have them on any of their headsets , neither has any of the better parts ..makers since the 70's..
headset wrenches 32mm *x 1/8" thick *36 for 1.125? 40 for 1,25"
señor miembro
Liked 6,488 Times
