Leg Length and Left/Right Unequal Power Meter Balance
Bikes: 2021 Trek Domane SLR7 Project One 62cm- 2010 Specialized Allez 61cm
Quoted: 118 Post(s)
Liked 88 Times
All,
I've had a professional fit at Specialized in Boulder, so I'm pretty dialed in. After the fit I got a Dura Ace two-side power meter. Same crank lengths, all that. Saddle is fine, no hip rocking.
As part of the fit I've got my left cleat shimmed 2 degrees to help with outside toe pain.
Interesting on the power meter; over a 20 to 25 mile ride, my left/right power distribution is normally 55% - 45% or more favoring the left side. Never in a million years would I have guessed that I had lop-sided power that much to the left based on feel alone. This is not a new, one-off experience as I've had the power meter long enough to see a consistency in these numbers.
Now my question. Could my legs be of different length and/or could the 2 degree shim on my left cleat be causing this? I'm thinking about adding a cleat riser to my right cleat. Do you think this might help? When I consciously pedal to even power, my left foot hurts even less than when I added the shims.
Any thoughts to get to even power balance, other than pedaling to even power based on the meter? I'd prefer to not watch it all the time.
Thanks.
Glenn
Thanks.
Glenn
ignominious poltroon
Quoted: 2241 Post(s)
Liked 3,443 Times
Take out the shim and see what happens.
My prediction is that you will restore balance.
Quoted: 118 Post(s)
Liked 88 Times
Thanks.
Glenn
Quoted: 878 Post(s)
Liked 726 Times
Surprised your fitter didn't notice a leg length discrepancy. When I had a Retul fit mine did, and he gave me a cleat shim for the shorter leg.
Quoted: 118 Post(s)
Liked 88 Times
Thanks
Glenn
Liked 3,443 Times
(In my own case, I do have a leg length discrepancy. I tried a cleat shim and it was like torture. Now I just have one cleat set slightly further back.)
Quoted: 1248 Post(s)
Liked 1,323 Times
All,
Thanks.
Glenn
Thanks.
Glenn
Liked 3,443 Times
If you are using this (as a verb) to mean the cleat is rotated 2°, disregard everything I said.
Quoted: 118 Post(s)
Liked 88 Times
Do you have another set of cleats without a shim? Or is the shim in the insole? I am not suggesting removing it permanently. But the scientist in me thinks you need an experimental control: power asymmetry in the absence of the shim.
Glenn
Quoted: 878 Post(s)
Liked 726 Times
I'm not sure that there is a leg length discrepancy. As you know, those Retul fits are pretty comprehensive. He didn't say anything about one. Did he give you like a 2 degree shim or an a flat cleat spacer? That's why I'm wondering if a flat spacer on my right cleat might make up for the shim on my left cleat.
Quoted: 118 Post(s)
Liked 88 Times
Thanks.
Glenn
Liked 3,443 Times
As Edward Abbey would say, I have a tendency to over-exaggerate. But I did have to stop mid-ride and remove it.
Likes For Polaris OBark:
Quoted: 6196 Post(s)
Liked 4,811 Times
Seems like if the shim solves our pain, you'll be able to put out more power longer. With pain you'll be inclined not to put out as much power for so long.
I wouldn't care what the left / right balance is.
Likes For Iride01:
Liked 3,443 Times
I've never measured my r/l power balance, but from what I have heard, it often diminishes at higher power output. Do you see any chages like that when you drope the hamer?
Quoted: 4806 Post(s)
Liked 3,932 Times
I was diagnosed by a (cycling) PT (unrelated Achilles issues) with one leg 1/2" shorter. First 5 minutes as soon as she saw me walk. I now wear 1/2" lifts on every right heel and 1/4" plate shims between ever right cleat and the sole. Life changing. (Plate aluminum bent to fit the sole curvature. Not easy or fun to bend! Bench vise. sledgehammer and a very long lever.) Edit: raised the seat the 1/8" difference between the cleats.
For the first time ever, I sight down the center of the front wheel and bike frame. Fewer seat issues and sores. Ride no hands in no wind with the bike straight up and down and in line with it.
Likes For 79pmooney:
Quoted: 118 Post(s)
Liked 88 Times
Liked 3,443 Times
Here's another sick thought: could the difference be an artifact of the precision/accuracy of the two power meters? Is there any way to switch them? Can you get someone else to ride your bike and see if they have a similar imbalance?
Liked 3,932 Times
After the changes, shim and seat height, I told the PT. She said that's exactly what she would have told me to do.
Quoted: 118 Post(s)
Liked 88 Times
They are built into a Dura Ace crank set so I don't think there is a way to switch them out. I calibrate them nearly every time my Garmin 1040 asks.
I ride entirely alone and plus I ride a 62cm, both probably hindering factors for a test rider.
I can get them to 50/50 by paying attention and it doesn't feel unnatural pedaling that way. But when I just pedal there is that imbalance. Again, my left toes feel better at 50/50 because, I guess, it takes some load off my natural pedal stroke favoring that side. That brings me back full circle to thinking my right leg may be a little shorter. Having my left cleat shimmed at 4 degrees (not 4mm in flat rise) seems like it would compound a shorter right leg length. That led me to the thought of putting a flat spacer on my right cleat.
Heck, I don't know what I'm talking about. I guess everyone's right and I just need to experiment and see what happens.
Thanks.
Glenn
Likes For GAtkins:
Quoted: 118 Post(s)
Liked 88 Times
Thank you.
Glenn
Liked 3,932 Times
I have heard that the 50% "rule" (shim 50% of leg difference) is good for those with legs that are of similar proportions, ie one leg is a scaled version of the other, but doesn't work so well (or at all) if the discrepancy is largely in the thigh (or calf). I seem to be a scale factor guy so I haven't tried to stretch my brain to figure out what would work for the thigh and calf people.
Quoted: 3956 Post(s)
Liked 7,308 Times
Interesting on the power meter; over a 20 to 25 mile ride, my left/right power distribution is normally 55% - 45% or more favoring the left side… Any thoughts to get to even power balance, other than pedaling to even power based on the meter? I'd prefer to not watch it all the time.
Likes For tomato coupe:
Liked 3,443 Times
Why is the idea of using a shorter crank arm for the shorter leg frowned upon (vs a shim)?
The problem I had when I tried a shim was that the stack height really made it hard to tolerate, whereas the shorter leg only bothers me if the saddle is at the high/optimum for the longer leg. (This difference is small enough that I didn't notice it existed until my bike fitter/framebuilder mentioned it to me, but I can feel one leg can be over-extended when the other is comfortable.)
