Immersive waxing / it should be more popular
#51
Quoted: 3241 Post(s)
Liked 2,512 Times
Since we're talking about it, I might as well get it off my chest. I have a really good ultrasonic cleaner..................that never gets used. Just too much fuss and effort to fire it up on a regular basis. Maybe if I hoard up dirty things for a once a month type massive cleaning, but otherwise, not worth it.
#52
Quoted: 3956 Post(s)
Liked 7,309 Times
I can clean a chain in about a minute using one of those chain cleaning gizmos filled with Simple Green. It's one of the quickest steps of a general bike washing.
#53
ignominious poltroon
Quoted: 2244 Post(s)
Liked 3,445 Times
#54
Liked 3,445 Times
#55
Liked 7,309 Times
#56
Liked 2,512 Times
Exactly. The chain doesn't get dirty. I guess it can't hurt to run it through a rag or paper towel, but I've never seen any dirt or residue come off, so I don't bother. The wax eventually gets kind of grey, so I just dump it into the trash and stick a new block in.
I don't wax my bicycle chains because waxing is not recommended for the chains on my forklift. I did put some ceramic bearings in the chain rollers/pulleys. Didn't notice any difference in the performance of the lift going up/down.
#57
Liked 3,445 Times
#58
Quoted: 8287 Post(s)
Liked 9,062 Times
The point is your drivetrain parts wouldn't get trashed as quickly on hot wax. Your friction losses would be reduced throughout your riding. So you have 40 years of accelerated part trashing and living with a less efficient drivetrain but that is not a reason to avoid an improvement if it is practical for you. Even with a money no object replace what come approach, the task to source and fit new parts, or trip to the bike shop, eats into time.
#59
Liked 3,445 Times
Well, if the wax is changing colors it's getting contaminated with foreign materials with each redipping. Maybe you should add cleaning the chain before redipping, or not. Each person has a method that works for them.
I didn't even know fork-lifts had chains, so I cannot comment further.
For the record, I don't wax my chainsaws.
#60
Liked 3,445 Times
#61
Clean a chain that way and then soak it in a tub white white spirit and give it a good shake and marvel at what flushes out from inside your chain where it counts.
Likes For yaw:
#62
Two ways about it if you are open minded.
a) logic:
Your method of wiping your chains with a rag does nothing for what's going on inside the rollers, where all the wear happens. Drivetrain parts wear mainly due to chain elongation and that is caused by precisely that internal wear. Wax on wax is lower friction than metal grinding on metal with the helping of a gritty lubricant-contamination paste which you never flushed out with your method.
b) research:
Plenty of independent bench and real world testing to be found via Google to attest to the increase in drivetrain lifetime and the measured reduction in friction using hot wax, including the maintenance of that low friction for longer, with and without added contamination.
a) logic:
b) research:
#63
Liked 9,062 Times
a) logic:
b) research:
a) logic:
b) research:
I'm someone who might neglect things until the morning of the ride, then I throw a little Pro Link on there while I'm still half asleep. Set aside time to take chains off and wax them? Maybe have a second one ready to go? Not gonna happen. Not my personality.
Longevity of the parts? I run stuff waaayy past the time when others buy new. My main bike has over 50K miles since I bought it used. I put a new crankset, chain, and cassette on it then. The rings were pretty worn at some point and my LBS guy gave me a set of Record rings. These were on there until last year when the crankarm cracked and I found a used crankset with rings. I've replaced the cassette 3 times in 50K miles and I think 4 chains. I put a new chain (the 4th one) on last year when I changed the crankset, so that chain has about 7000 miles on it and the cassette well over 10K.
Would those parts have lasted longer if I waxed? I'll never know. As you can see, my expenses for drivetrain replacement stuff is pretty minimal. I'm at 200 pounds which is the lightest I've been since I started riding. I generally climb 300,000 feet or more each year so my bike has a bit of stress. I break wheels and other parts.
I've heard and read about the wax thing for many years. Earlier in this thread I linked a page with close to 50 threads on the subject from doing a quick search with the words "chain wax" in titles. It's not for everyone.
Likes For big john:
#64
Quoted: 20810 Post(s)
Liked 9,456 Times
Sure, but you're making judgements based on incorrect assumptions. You're doing small batches of wax - I start out each year with a fresh half pound of MSW - and a waxed chain doesn't attract nearly the same road grit and grime that wet lubes will, so there's much less accumulation than you're assuming. If you're really persnickety, MSW has "race" chain recommendations to save the other watt.
#65
Quoted: 2333 Post(s)
Liked 2,097 Times
3 cassettes in 50,000 miles would $1200 and 3-5 years of riding.
One of the cogs on a SRAM 1190 is starting to skip under load but it has around 35,000 miles and has suffered to many big-big abuses. I think the key is not letting your chains wear out. When I was lazy and used liquid lubes, my chains would last 2-2,500 miles. I've gotten 10,000 miles on a waxed chain in ideal conditions. 12 speed chains are about $100. So, there is some real money to be saved with the 5 minutes it takes to wax my chain every 500-600 miles. Lets say 20 times per year or around 2 hours. Whats that about $450 per hour?
#66
Bikes: SL8 Pro, TCR beater
Quoted: 989 Post(s)
Liked 586 Times
Likes For eduskator:
#67
Liked 2,512 Times
But there is contamination after the first dipping if you don't clean the chain before redipping and strain your wax after each dipping. That's not really important either way, but it does run counter to some of the pro waxing discussion in thread. The OP and others started with how easy and less time consuming it is. But as the thread goes along there seem to be more of, "Well yeah, you have to do that as well and you also have to do that also." To be fair, you countered some of their points in your earlier posts.
I think the real reason is because some individuals(such as myself) think of lubrication as more of a pre ride ritual and less of a monthly/longer maintenance chore similar to servicing headsets. I have multible bikes in each speed from 5-9 speeds. The 5-8s all take the same chains. I have at least one spare each of the 5-8 and 9 chains sitting on the wall. I'd never think of breaking them out of their package until they go on a bike. When they do, another will be ordered to take their place on the wall. That's just me.
The strange thing is that all of my bikes stay at my place of business, which has a shop with tools and a parts washer. Rarely though, does a chain come off a bike for cleaning. If it does, it just gets soaked in some concoction of brake cleaner/degreaser. Usually in something like a bowl. The parts washer never gets used for bike chains. Then the chain is dried out and reinstalled on bike before lubrication. Weird.
#68
Liked 2,512 Times
This is countering the reasons the pro waxers are stating in the thread about how easy and less time consuming it is. There's one more step you have to add to the process. WhyFi seems to be the only one stating that extra work in involved at the beginning of the process.
#69
Liked 9,062 Times
Likes For big john:
#70
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
What do you do when on a trip away from home and need to re-wax? If you use some other lube, can you just go back to waxing after, or do you need to clean everything off the chain?
#71
Liked 9,456 Times
I also really don't care to evangelize waxing - though I'm happy to answer questions and correct misconceptions - because everybody has a different workflow that they're comfortable with. I like waxing because, in my riding environment, it takes me waaaaay too much work to keep my chain/drivetrain from getting grimy. While my preferred method takes a bit of upfront elbow grease, after that it's probably less than 5 minutes of hands-on time, per month, for the next 10k miles. No wiping down, no re-application, no cassette flossing, no scaping gunk off of jockey wheels, etc. Evidently, some people don't need to do this stuff very much or they don't mind doing it - cool, you do you, but don't try to nit-pick, based upon incorrect assumptions, what is very clearly a net benefit for me.
To touch on another needlessly controversial subject, waxing is much like tubeless, to me - I'll happily front-load a little work if it makes my life easier down the line. For those that are fortunate enough to not experience frequent flats or those that don't mind addressing them roadside - cool, you do you, but don't try to nit-pick, based upon incorrect assumptions, what is very clearly a net benefit for me.
#72
Liked 9,456 Times
How much are you riding on these trips? I rotate two chains, so that I only have to re-wax once a month or so, and I regularly take trips with my bike. I make sure that both chains are freshly re-waxed before leaving. I usually log 500+ miles on these trips and I often don't even make it to my second chain.
#73
Liked 2,097 Times
#74
Quoted: 9656 Post(s)
Liked 6,366 Times
I typically rotate two chains as well, and have not found the process to be time consuming. Even initial chain cleaning is time efficient because it does not require a concentrated amount of time - put chain in Gatoraid bottle with mineral spirits, shake, soak, shake, soak, move to a clean bottle and repeat. I typically do that while doing other things around the house.
I sometimes use Squirt between immersions.
I don't have to wash greasy rags used to wipe the chain after other lubes, and don't have to pre-treat stained clothes.
All-in-all, it's about the same time spend either way you go.
#75
Liked 3,445 Times
Don't non-wax chain lubricating folks also do the initial chain cleaning? That stuff Shimano uses to pack the chain is incredibly adhesive. I wouldn't want that as my initial lube, regardless of what I use.
