Immersive waxing / it should be more popular
#101
If you are buying a new chain anyway, just source a prepped and pre-waxed chain to get you started. If you don't already have the solvents and want to save yourself the disposal trip, it's usually well worth the service charge. You won't have to solvent clean it again thereafter.
If you have a waxed chain that is due for its next immersion, it's enough to just wipe it with a microfibre cloth to remove any surface dust, or if you have it on hand, just a few sprays of isopropyl on the cloth, run the chain through the cloth a few revolutions while on the bike, then take the chain off and drop it into the wax. If you set up a little raised sieve in your wax pot that keeps the chain from the bottom where flushed out contamination accumulates, you can even skip any chain wiping and just chuck the used chain into the pot.
Likes For yaw:
#102
Who did this test? For what it's worth. I had a Fisher mt. bike that I did many mt. bike races on, then retired it to a commuter. Did over 6.000 miles commuting with it. Original chain, and before I was a Bike Forum member and didn't know better, all I used was WD40 to lube it. The only reason I didn't have a chance to put a new chain on was that it was stolen at work. (seven speed chain if it matters)
In terms of how long chains last, we really need to establish a measurement like 0.5% when it is officially due before it starts rapidly eating the drivetrain. People may report that their chains/drivetrain last for so and so long but it's all arbitrary unless we introduce some measurement. Even that is difficult since chain wear tools differ quite a bit in when they indicate 0.5% due to manufacturing tolerances. The last (non hot wax) chain I wore out was fine on my park tool CC4 but showed above on the slide scale checker the bike shop had. And some chains even start out quite differently one from another. Then the drivetrain, people certainly have a variety of ideas re when it counts as worn. Just because it runs does not mean it is not terribly inefficient. Performance oriented riders will obviously care the most. I am not tolerant towards sloppiness on my bike.
#103
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Likes For cxwrench:
#104
Bikes: lots
Liked 2,932 Times
You absolutely don't have to touch the chain when removing or replacing the rear wheel...unless you have a TT bike w/ rear facing dropouts. That's the ONLY time I ever touch a chain when removing/installing a wheel.
Likes For cxwrench:
#105
Quoted: 8287 Post(s)
Liked 9,061 Times
Likes For big john:
#106
ignominious poltroon
Quoted: 2241 Post(s)
Liked 3,443 Times
Some people can touch their toes. I can barely touch my knees.
Likes For Polaris OBark:
#107
Liked 3,443 Times
#108
Liked 9,061 Times
#109
Quoted: 3956 Post(s)
Liked 7,307 Times
#110
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
No, I don't
Yes, I can. That's exactly what I do. Maybe my chains wear faster and get dirtier than a waxed chain. Maybe they rob a Watt or two of power. But these have not been problems for me. The bike I ride most is now three years old has something like 6000 miles on it. Drivetrain is quiet. Shifts are smooth and reliable. My Pedro's gauge says the chain is just starting to show measurable wear--I can force it to slip into the 5% tab; when it goes to 5% easily or will forcibly go into the 7.5%, I'll replace the chain.
Maybe some guys ride in dustier environments or put 10,000 miles per year on their bike, and maybe some guys really dislike cleaning their drivetrain, or worry about how much grit is getting inside the chain. Waxing may be a good idea for them. But it's not a universally superior process.
Likes For Broctoon:
#111
Liked 9,061 Times
#113
Bikes: lots
Liked 2,932 Times
#114
'Paying double' is just uninformed and deceiving rubbish.The couple prepped chains I bought cost the equivalent of USD 10 more than the factory chain for the clean and initial wax. Compared to a trip to the hardware store and fussing around with fuming solvents, which I did to clear up a couple of my existing chains, that can easily be worth it unless you have the cleaning supplies already. You can pick whatever 'good' chain brand you want, it's not like they are a different make.
As for 'money up front', sure if someone cannot afford a single extra chain then they will be penalised by 'the system' as usual for not having money. But otherwise, you will run through these chains in the future anyway so pre-purchasing them and running them together will mean that the chain elongation wearing your drivetrain down is halved once again. Check out that benchmarking table and calculate how many one-off drip lube chains you buy before I get two new hot wax chains for a new rotation.
I think you are resisting facts and confuse an attempt to inform with the intention to sell you something.
#115
Just Pedaling
Bikes: YEP!
Quoted: 334 Post(s)
Liked 522 Times
The people who package my wax say that you use it to seal jar lids. They call it canning wax. It is completely safe. You can eat it. It will pass right through you.
If you put toxic stuff in it like Cd or Mo or other heavy metals, obviously that will make it toxic. But there is no need to do that (unless you pay for somebodies bogus magic potion).
Likes For SpedFast:
Likes For SpedFast:
#117
Liked 9,061 Times
Likes For big john:
#118
Liked 3,443 Times
#119
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
..just a mineral spirits soak and shake up in a little container or a bottle until it runs clear and a final alcohol rinse to get any residue off will do. If you are stripping a well used chain you may just need a couple more rounds of the spirits to get all the crap out.
Where to dispose used solvents should be listed online somewhere for where you live.
You're right. This is much faster and easier than wiping down the chain with a rag once a month and dripping a little lube onto it. I don't know why I didn't pick up on this process long ago.
#120
Liked 9,061 Times
#121
Liked 9,061 Times
#122
Liked 3,443 Times
You don't. (Also I recently found that if you clean your chain with mineral spirits first, the wax doesn't last nearly as long.)
Again, no need. Besides, you are in Utah.
Gimmick. Again no need.
I've never done that.
A jar of peanut butter takes more space.
Hammer a nail into a fencepost. Do this outside.
Quick-links come with my chains, and I use one for the life of the chain. If I didn't wax, I would still take my chain off to clean it.
Yeah, it is more work than not cleaning the chain, which is essentially what you aren't doing when you wipe it down with a rag and dump more lube on it.
and maybe some alcohol.
Or, I can start with a pre-waxed chain for a little extra cost.
Oh, and find or make some sort of sieve for it to sit in while soaking in the dedicated crock pot or saucepan,
which have to be stored when not in use.
And make some arrangement for the chain to hang from while drying/cooling
And when it's time to re-wax, all I have to do is remove and reinstall it on the bike.
#123
Fun and snarky but ignorant of these:
- Your drivetrain will last multiple times longer, much fewer chain, cassette and chain ring purchases
- Your chain will run more efficiently throughout, you will feel it run ridiculously smooth
- All chain and drivetrain cleaning and degreasing falls away from your general maintenance needs
- The initial chain prep or prepped chain purchase is a one-off
- The initial pot setup is also a one-off, unless you live in a small place you can leave it all set up in the 'bike corner'
#124
Liked 7,307 Times
A cleaned and waxed 12-spd YBN chain from MSW is $110-$150 depending on how much you want them to do. A pre-waxed 12-spd Dura Ace chain from Silca is $185, and a pre-waxed 12-spd SRAM Force AXS chain from Silca is $155. I can walk into my local shop and get a 12-spd Dura Ace, Force AXS, or Super Record chain for less than $70. So, yeah, you're paying about double if you buy a pre-waxed chain.
