what size b screw for a RD 7800?
Quoted: 129 Post(s)
I run a 27 big cog and wanted to try a 28. Put in the B screw all the way and almost almost but not quite enough clearance.
What size screw should I buy at home depot?
Quoted: 6556 Post(s)
Liked 58 Times
Just take it with you and match it, just 1/4 inch longer. Probably M5 or 6. You can go to the nut selection and use metric nuts to see which one fits the screw (bolt). Get stainless steel if you can. You may have trouble finding the exact type you want, so be flexible about the head type. Hex head, allen head, flat driver head, Phillips head, it doesn't really matter for this purpose.
Really Old Senior Member
Your current screw is an M4-12.
12mm is about 1/2" long.
Simple enough to look up in the Shimano tech docs.
https://techdocs.shimano.com/techdocs...H5!-1887296039
Quoted: 1438 Post(s)
Liked 1,092 Times
You might be able to put your existing screw in from the opposite side and have the head go against the derailleur to gain more clearance.
Low car diet
Bikes: 2006 Windsor Dover w/105, 2007 GT Avalanche w/XT, 1995 Trek 820 setup for touring, 201? Yeah single-speed folder, 199? Huffy tandem.
I'm running a 28T with the backward screw and it works great.
Quoted: 4212 Post(s)
Liked 3,883 Times
I've had to bend a longer screw after installing it to get the head to hit the hanger tab fully. Andy.
