I polished my pawls!
Bikes: '23 Poseidon Redwood, '07 Specialized Roubaix Comp Triple, '12 Gravity Fixie, '21 Liv Rove 4, '06? Giant EB Spirit
Quoted: 345 Post(s)
Liked 237 Times
After disassembling and cleaning my new* Bitex RAR12 rear hub I noticed some shiny wear spots on the pawls and the idea hit me... use some metal polish (carefully) on the pawls and other mating surfaces on the freehub using a Dremel tool and a felt tip. I removed the pawls and springs and got to work. I was very careful not to get any metal polish in/on the bearings. The pawls are now have an almost mirror finish. I applied the same treatment to the track that the C ring and seal rides in using twine soaked in the metal polish. I cleaned everything off thoroughly with a rag and rubbing alcoholI and applied a *light* coat (I've made that mistake before if you know what I mean) of Park's poly lube grease.
The hub free rides better than ever. The hub is so smooth that I even tried removing half the pawls (there are six) after a recommendation by someone on the forum and didn't notice a difference in the resistance when freeriding. In other words, the resistance is dominated by something else (likely the four cartridge bearings and/or grease drag). I put all six of the pawls back in went for a ride and had to report back.
So, if your pawls are dirty or rough, give 'em a nice polish and be amazed at the difference.
(btw, i'm quite proud of that eye catching and immature title )
*yes, I'm that much of a geek that I have to disassemble new gear to see how it works
Likes For Symox:
Quoted: 6177 Post(s)
Liked 4,794 Times
I knew a guy when I was a kid that was a machinist. He took a big deep sea fishing reel he just bought and put valve lapping compound on the gears and ran it for a good long bit. It was probably the smoothest running action on a fishing reel I've ever experienced.
Don't know how many more fish were caught because of that. Nor do I know how much better your cycling will be. Pawls are only needed when you are coasting. Don't coast so much!
Likes For Iride01:
Quoted: 1163 Post(s)
Liked 441 Times
By polishing the pawls does this diminish the strength of engagement when in drive mode?
Just curious.
Just curious.
Likes For Symox:
Mostly Harmless
Bikes: Have two wheels
Quoted: 13694 Post(s)
Liked 4,520 Times
Likes For rjones28:
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times
You will without a doubt have a quicker failure of the freehub. The pawls aren't tarnished - they have a coating on them to help with long term wear and you have removed it making them softer. That freehub has 6 pawls that are timed in 2 groups by removing 3 you've doubled the engagement time and considering how quickly those pawls wear anyway you have most likely effectively cut the lifetime of that freehub in half.
Just an FYI.
Just an FYI.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
Likes For Psimet2001:
Quoted: 20808 Post(s)
Liked 9,450 Times
^^^ Well, sure, but other than that, sweet job!
Likes For WhyFi:
Fat n slow
Quoted: 3252 Post(s)
Liked 2,079 Times
Just an FYI.
Just an FYI.
Likes For phrantic09:
bike whisperer
Quoted: 1523 Post(s)
Liked 716 Times
I think it's either directly proportional or proportional to the square of speed, while air drag starts off much bigger and rises with the cube of speed. But even leaving that aside, the way some peeps talk about hub drag, it's like they haven't even considered the leverage the tyre has over it.
The only reason I'd be mucking around like this is trying to make the ratchet quieter.
Sheldon Brown's bike info ~~~ Park Tools repair help
Half-step triple, using double gear ~~~ 6400 STI rebuild walkthrough ~~~ Want 8/9/10s @126mm OLD? OCR. ~~~ Shimano cassette body overhaul ~~~ Ergopower Escape wear repair ~~~ PSA: drivetrain wear
List of US/Canada bike co-ops ~~~ Global list
Likes For Kimmo:
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1939 Post(s)
Liked 1,463 Times
The OP did reinstall them and so is back to six pawls.
Likes For SoSmellyAir:
Liked 1,463 Times
Quoted: 345 Post(s)
Liked 237 Times
Just an FYI.
Just an FYI.
You seem to know a lot about the coating, care to share its thickness?
bike whisperer
Liked 716 Times
A quiet ratchet is a minor one of the many reasons I consider Shimano freehubs far superior to the rest.
Likes For Kimmo:
Quoted: 345 Post(s)
Liked 237 Times
one benefit I see to the Shimano design is that the bearings carrying the weight are at the extremes of the hub - much like an external bottom bracket.
if I’m not mistaken, the four cartridge bearing style that Bitex uses has the weight bearing bearing close to the freehub to hub interface. (There are two bearings in the hub body and two in the freehub body. ). Someone please correct me if wrong
Quoted: 345 Post(s)
Liked 237 Times
Just an FYI.
Just an FYI.
Quoted: 1109 Post(s)
Liked 1,200 Times
As for:
Just an FYI.
Just an FYI.
Shimano does make excellent hubs, I have several. However, not having to tweak the cone tightness is a real benefit to me of the cartridge style bearing hubs. If it’s well made there is really little maintenance.
Imo a QR shimano hub with the bearings in the ends is far better.
Likes For Racing Dan:
Just an FYI.
Just an FYI.
bike whisperer
Liked 716 Times
Cartridge bearing hubs with preload adjustment (and decent sealing) are rarer than rocking-horse poo.
Likes For Kimmo:
Hub drag is pretty trivial; lots of folks way overestimate its effect.
bike whisperer
Liked 716 Times
Totally happy for my dribble shot from the hip to be corrected
Liked 1,463 Times
Two weeks ago I passed another cyclist going the other direction on a local bike path, and his freehub sounded like a miniature minigun; it was the loudest freehub that I have ever heard. Judging by the frequency of the ratcheting -- I am referring to the period between each ratchet rather than the pitch here -- it also sounded like it may have a relatively high number of pawls, hence the minigun reference. He passed me before I could ask about his wheels. Maybe he has the same wheels as you do? For reference, I have two sets of Mavic wheels (Aksium, Kysrium Elite) so that is the freehub volume that I am used to. I have heard that Shimano freehubs are quieter.
Quoted: 345 Post(s)
Liked 237 Times
like using them to make recent COVID walkers in the middle of the neighborhood streets know I’m coming (or scare them when I pass)
