29+ inner tubes for 29 x 3.0" tires
Old 06-07-15, 06:57 PM
Erik_A
Quoted: 20 Post(s)
Guys and Gals, what inner tubes are you using for 29+ (Surly Knard 29 x 3.0"). Do you buy fat bike 3.0-4.8 tubes or just use standard 29er tubes?
Erik_A is offline
Old 06-07-15, 07:15 PM
Erik_A
Quoted: 20 Post(s)
Surly does a 29"x3" tube, but I've had great success just running a standard 29er tube. Mount 'em up tubeless and skip the tube all together for improved ride quality!
Thanks - well these are standard 23mm rims (not the 35mm min Surly recoomends). I may wait till I build a Velocity P35 Blunt rim up before trying tubeless.
Erik_A is offline
Old 06-15-15, 08:21 PM
c_m_shooter
c_m_shooter's Avatar
Bikes: Surly Cross Check, Redline Monocog 29er, Generic Track bike, Surly Pugsley, Salsa Fargo, Schwinn Klunker
Standard tubes work. I had a knard on the stock front wheel on my Fargo for a year and it worked. I just had a rabbit hole built for it a couple weeks ago.
c_m_shooter is offline
lesiz
Advocacy & Safety
32
09-07-11 11:49 PM
acaurora
Road Cycling
1
03-30-10 04:35 PM
morten_beta
Singlespeed & Fixed Gear
0
05-01-09 02:08 PM
J.W.
Road Cycling
1
04-22-09 09:24 PM
ivan_yulaev
Commuting
11
03-08-05 05:55 AM
