Need diameter measurement info for wider 700c (29er) tires
On Holiday
Bikes: A bunch of old steel bikes
Quoted: 394 Post(s)
Liked 14 Times
I'm upgrading a 29er and want to mount wider tires than the originals 35-622s. Width is not an issue; the limiting factor is the diameter of the tire. I figure that my max diameter is about 720mm, equivalent to a circumference of 2260mm. Browsing the websites of manufacturers (and other "authorities") leads me to believe that ISO widths of up to 50 may be possible; however the available info is inconsistent. I was hoping to get some feedback from actual users.
I would very much appreciate anybody using tires of ISO 45-622 to 50-622 taking the time to measure and post diameter or circumference of mounted tires. Also include manufacturer, model, ISO designation, and also what rim they are mounted on.
Thanks
Thanks
I'll check back in with you in a couple of days. I have a Trek DS 8.4 that came with 700x38 on it I ordered some Schwalbe Hurricanes 29x2.0 which are actually 50mm wide that were supposed to be here yesterday but bad weather has delayed delivery.. In the Hybrid forum I was told they'd fit, we'll see .
Quoted: 1221 Post(s)
Liked 629 Times
Just grabbed a rough estimate from my 29er front tire, distance from center of wheel to outer tire is about 35.5cm (radius) so about 710mm diameter.
Continental xking 2.2" (55-622) mounted on giant s-xc2 rims, I think they have a 17mm internal rim width.
ETRTO data is marked on the side of the tire .. 29er bead seat is 622 - ( xx ) XX being width in mm..
Quoted: 5224 Post(s)
Liked 3,581 Times
Liked 3,581 Times
dunno if this will help you. just measured what I have handy outside
50 622
28x2
schwalbe marathon winter studded tires
at 30psi
approx diameter 28 3/8" or 720mm?
maybe a tiny bit larger cuz my ruler's left edge was to one side of the front axle
on these Alex rims
& fwiw ~ this is their width measured (47mm?) when mounted at 40psi
50 622
28x2
at 30psi
on these Alex rims
Liked 3,581 Times
these are my 29x2.25 Riddlers. this angled thing is a DIY debris deflector
Rim widths matter too. Most 29ers should be able to take a 2.1 to 2.4. Your 29er came with 35 mm tires? So that is a road bike or hybrid? Make and model of your ride?
This is a useful utility:
https://www.yojimg.net/bike/web_tools/trailcalc.php
Enter wheel size and tire width and it will give a wheel diameter and radius. Not possible to be spot on every time. My experience is the numbers are usually a bit high and rarely too low.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
Surly has a table for their tires on their website but it might be easier to find via Google.
It seems like sometimes manufacturers will list the width at the lugs (Kenda) and some the width of the carcass (WTB)
On Holiday
Quoted: 394 Post(s)
Liked 14 Times
50 622
28x2
at 30psi
approx diameter 28 3/8" or 720mm? maybe a tiny bit larger cuz my ruler's left edge was to one side of the front axle on these Alex rims & fwiw ~ this is their width measured (47mm?) when mounted at 40psi
50 622
28x2
at 30psi
Bicycle Trail Calculator | yojimg.net
Browsing around, I found this Wheel Diameter Visualizer. Developed by Dan Stroud. Neat stuff. He has a tire measurement database that has a lot of info but needs to be fleshed out a bit for some manufacturers, hence is invitation to add data.
Thanks to all who have responded
Have you gotten them yet? Those tires at that size is on my list of possibilities.
Thanks
Thanks. The pics were great. 720mm would allow me about 5 mm clearance at closest interfering point.
My closest point is the seat stay bridge but by only a few mm over the fork crown and the chainstay bridge
Thanks
Got one of the Schwalbe Hurricanes put on tonight. With 48 psi in them on 17mm wide rims they measure a tick under 2 inches wide on the lugs and right at 28 and 3/8ths inches tall. Hope that helps.
On Holiday
Quoted: 394 Post(s)
Liked 14 Times
Thanks
