To grease...or not to grease :)
Old 07-15-19, 10:38 AM
stephr1
Quoted: 41 Post(s)
Liked 3 Times in 3 Posts
Looking for some feedback about lubing brake and shift cables....
Early on I used a dry graphite lube (as in, went on dry), tho I wasn't very diligent about it.
At some point I decided to move to a dry lube (using one from Spin Doctor) that goes on wet and then dries leaving a teflon-like coating on the cable.
The other day I had a conversation with someone who was not an avid rider, but was consistently on his bike. He stated he uses grease (tho, I didn't ask him if it was a lighter grease like a Park Tools blue lube, or if it was some generic automotive grease).
I'd be interested to hear about what folks experiences have been, especially if you've used both grease and the go-on-wet-dry-with-teflon lube, and any recommendations, cautions or suggestions based on that experience.
Thx in advance.....
stephr1 is offline
Old 07-15-19, 10:52 AM
Wilfred Laurier
Señor Member
Wilfred Laurier's Avatar
Quoted: 364 Post(s)
Liked 84 Times in 60 Posts
I use either grease or a few drops of chain oil.
There are some cables and housings, however, that are not supposed to have lube added - I believe Teflon coated cables and the old Gore RideOn cable and housing sets are examples. Any plain cables can and probably should be lubricated.
Also, while Phil's claims their grease is specifically for bicycles, it is really just waterproof grease made by some other manufacturer and repackaged by/for Phil's... I buy 500ml tubs of 'waterproof trailer grease' at Canadian Tire and it looks and performs very much like Phil's, but at ~1/10th the cost.
Wilfred Laurier is offline
Old 07-15-19, 01:40 PM
canklecat
canklecat's Avatar
Quoted: 2909 Post(s)
Liked 243 Times in 185 Posts
Some of the Shimano cable kits are pre-greased. Probably a good idea with galvanized cables.
On bikes with old crusty feeling cables, I'll dribble in some Boeshield T9 to smooth the cable runs until I have time to replace them. Works okay but doesn't last long. Same with Boeshield T9 on chains. It works but needs to be refreshed every week or every couple of rides, depending on conditions and mileage.
I usually smear a little Phil's grease on my fingers and thumb and drag a new cable through before installing.
It would probably take years in most climates to see any difference between greased, oiled, dry lubed and dry cables/housings. It might matter in coastal areas.
canklecat is offline
Old 07-15-19, 02:14 PM
Litespud
Bikes: 2000 Litespeed Vortex Chorus 10, 1995 DeBernardi Cromor fixie
Quoted: 146 Post(s)
Liked 39 Times in 27 Posts
I’ll use common-or-garden auto grease if I have the cables out, otherwise I invert the bike on the stand and drip oil into the housing, working the levers to draw it in
Litespud is offline
Old 07-15-19, 07:43 PM
drlogik
drlogik's Avatar
Bikes: '87-ish Pinarello Montello; '89 Nishiki Ariel; '85 Raleigh Wyoming, '16 Wabi Special, '16 Wabi Classic, '14 Kona Cinder Cone
Quoted: 395 Post(s)
Liked 18 Times in 10 Posts
On my older bikes I lube my cables with Finish Line Extreme Flouro Teflon grease. Yeah it's expensive but you only have to lube them once. The stuff lasts forever. When the DuPont Pure Teflon Bearing grease was still available I used that. The Finish Line product is basically the same thing. This grease makes for a very slippery cable! Better than regular grease in my opinion.
As was previously stated, some modern cables and housing are not meant to be lubed. I have two bikes with that type of cable and I don't lube them at all but do pull the cables out once a year and clean them.
drlogik is offline
Old 07-15-19, 07:56 PM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
Bikes: Nekobasu, Pandicorn
Quoted: 3871 Post(s)
Liked 367 Times in 238 Posts
Bike Aid Dri-Slide. Will never gum up. One bottle will last a lifetime.
DrIsotope is offline
Old 07-15-19, 08:26 PM
Reynolds
Passista
Reynolds's Avatar
Quoted: 476 Post(s)
Liked 34 Times in 28 Posts
I think grease is too sticky for cable use. ATF or other light oil is what I use.
Reynolds is offline
Old 07-15-19, 09:31 PM
GamblerGORD53
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 636 Post(s)
Liked 8 Times in 6 Posts
Maybe once in my life I put a light oil on a brake cable. My tour bike with a hard pulling Drum brake hasn't been touched in 12,000 miles/ 4.5 years/ 2 tours. My LBS guy did lube my DeR shifter stuff a few times.
I haven't had a peeling cable in 35 years. I only replace them because I won't reuse a squashed cable.
I have cut off a rear cable and used it shorter on the front.
GamblerGORD53 is offline
Old 07-15-19, 10:02 PM
MarcusT
MarcusT's Avatar
Quoted: 298 Post(s)
Liked 21 Times in 17 Posts
I am always worried how some lubes will affect the plastic housing and such. I use silicon oil, about as inert as you can get
MarcusT is offline
Likes For MarcusT:
Old 07-16-19, 05:59 AM
JonathanGennick
JonathanGennick's Avatar
Bikes: Priority 600, Priority Continuum, Devinci Dexter
Quoted: 680 Post(s)
Liked 44 Times in 26 Posts
If I have to put grease in a cable, I just change it out for new. That puts me in the "no grease" camp. I do buy lined housing though.
JonathanGennick is offline
Old 07-16-19, 11:02 AM
All Terrain
All Terrain's Avatar
Bikes: 1996 Specialized S-Works Steel, 1983 Maruishi Town and Country, 1982 Rocky Mountain Sherpa, 1984 Falcon Harrier, plus a dozen more.
Liked 8 Times in 2 Posts
I like oil for my cables. Have used grease in the past, but switched years ago. I also use automotive waterproof grease for all my bearings. I have it here for my vehicles, so don't notice the cost.
All Terrain is offline
Old 07-16-19, 11:20 AM
ramzilla
ramzilla's Avatar
Bikes: Vintage Japanese Bicycles
Quoted: 426 Post(s)
Liked 19 Times in 17 Posts
I live near the beach in Florida. I grease up everything on my bikes. Used to use Vaseline as assembly lube on my threads & cables. But, now I use green waterproof grease on everything. Back when I had a house directly on the beach, I used to spray a mist of WD-40 all over my entire bike. Then, wipe off the rims with alcohol. All metal parts corrode regardless if they're steel, aluminum or other alloys.
ramzilla is offline
Old 07-16-19, 04:52 PM
stephr1
Quoted: 41 Post(s)
Thx much for all the great responses and feedback!!!!
re: "greasers" the good news about greasing is that it will last quite a while. Bad news, for me, anyway, is the road (on and off) dirt it will attract and hold onto and how much of that will make its way into the housing and cause unnecessary wear and tear on the cable and housing. Even with the dry lube I see some accumulation on the ferules that I have to be mindful of.
Sounds like the dry lube is a good choice for me and my riding environment. What I am hearing is that I lube my shift cables every couple of weeks or so, and my brake cables every month or so and maybe I can do those specific maintenance activities a bit (maybe even less) often.
Again, appreciate all the input. Cheers...
Ride safe. Ride smart. Always have a plan b, c, d....for avoiding those idiots who are unavoidable.
stephr1 is offline
