Good old frames for commuter
Quoted: 23 Post(s)
What are some good classic frames for commuting? Specifically interested in being able to fit larger tires (~30mm, hopefully more) with fenders because that's just what I need to do here in rain+pothole country (Seattle). There are lots of 70s and 80s frames for sale but not sure what to look for that would be a good fit for commuting needs.
The Trek 520 with cantilever brakes seem great. Just hard to find in my size. Any more like this?
Thanks!
Thanks!
aged to perfection
Quoted: 837 Post(s)
Liked 1,258 Times
you should be able to find a high quality frame in good shape for 150-200 bucks, I recommend the Japanese made frames, they are very high quality and will generally have fender eyelets (you live in Seattle, you understand) and they are usually ISO threading so you won't have fit issues.
Are you confident that you can evaluate a frame for damage before buying it ? What size are you looking for ?
Mark Petry
Bainbridge Island, WA USA
Mark Petry
Quoted: 23 Post(s)
Mark Petry
Mark Petry
Not super confident but I made a little checklist for myself:
-Check for dents on tubes by feel and visually
-Check that chainstays are not crushed by kickstand
-Check that seat tube not crushed by seatpost
-Checks for gaps in/around lugs
-Check that head tube is in line with fork
-Check that wheel splits fork blades evenly
-Check that fork blades line up from the side
-Check that rear dropouts are spaced correctly with ruler
-Check that rear dropouts are aligned visually
-Use string to check that seat tube and head tube are aligned
Happy banana slug
Quoted: 1533 Post(s)
Liked 1,528 Times
Thanks!
Thanks!
Quoted: 637 Post(s)
Liked 1,281 Times
Mid 80's Schwinn Voyageur and LeTour Luxe with cantis. If you can snag a Voyageur SP they came with Blackburn racks standard as did some of the LeTour Luxes.
Quoted: 1372 Post(s)
Liked 1,751 Times
This is my mountain bike set up the way I like it and I DO like it. So far, got about sixty dollars Canadian into the bike and no need to spend any more, although I would like to find an inexpensive perfect feeling new unripped saddle for the machine...
Old bikes, Older guy
Location: Fiscal Conservative on the Lefty Coast - Oregon
Bikes: A few modern, Several vintage, All ridden when weather allows.
Quoted: 251 Post(s)
Liked 167 Times
Hello,
Personally, I like better quality aluminum MTB frames less than twenty years old. They are light, don’t rust, durable and handle well in tight spots. My current one is a 2004 Giant Iguana with rigid forks, riser bars, disc brakes and 9 X 1 gearing. It’s about 25# with rack and basket. Hope this helps.
Cheers,
Van
Cheers,
Van
Remember: Real bikes have pedals.
...and never put a yellow tail on a Red, White and Blue kite!
Space Ghost
Bikes: Bridgestone, Fuji, Iro, Jamis, Gary Fisher, GT, Scott, Specialized and more
Quoted: 292 Post(s)
Liked 412 Times
I would also go with a good quality, older mtb for a commuter.
But nothing wrong with a classic Japanese steel road bike, either. I would look for something that takes long reach brakes, as well as the eyelets.
You know, now that I’m thinking about it, my favorite commuter is actually this old, dutch three speed cruiser.
Might be worth a look in that direction.
Quoted: 796 Post(s)
Liked 522 Times
+1 on vintage MTBs as they run fat tires with lots of room for fenders and most have a good selection of braze- ons.
Next week Bikeworks co-op in Columbia city is having their warehouse sale you might want to check that out or go to their warehouse most any Saturday (check their calendar) as they usually have a selection of project bike if your willing to do some basic maintenance you can find some good deals heck I even lucked into a Trek 520 there a few month back so you never know.
I am potato.
Quoted: 1789 Post(s)
Liked 1,629 Times
Craigslist
If it were me, I'd favor an aluminum rigid with 26 inch wheels, rack & fender eyelets. But steel is just as well.
Then I'd junk whatever knobby hard rolling mountain bike tire was on it in favor of some 26x 1.1 slicks up to 26x1.5 commuter tires.
I favor 559-28 Continental Gatorskins (aka 26x1.1 or 26x1 1/8)
For in city use anything bigger that 1.5 or has knobs really isn't necessary, gets heavy, and rolls slow unless they are super light & thin; which disqualifies them from "commuter" purposes, IMO.
I'm sure many will have their own opinion.
I'd avoid vintage anything with suspension. That's just like asking for old, obsolete, worn, broken garbage. I'm not saying there might not be a true gem of garage queen wonderfulness out there. I am saying that the potential for problems & expense just isn't worth the risk or the trouble.
Good luck.
Oh, FWIW: check out Bike Works in Columbia City, on Ferdinand Street. What you are looking for is their specialty.
Good luck.
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
It's hard to argue with the old mountain bike advice, but I'm going to try.
I gave the rigid mountain bike thing a go with a 1989 Specialized RockHopper built up like this:
It was a decent bike, perfectly fine for commuting. I think I've got 26x1.75 tires on it in this picture. It would fit much over 26x2, but you don't need that for commuting. The problem, to the extent that there was a problem, was that I actually wanted a road bike, not a mountain bike, and even when you put drop bars on a mountain bike the geometry isn't road bike geometry.
I'd counter that what you actually want is some kind of sport touring bike. I think I saw a nice Miyata 310 on Seatle CL. There are many other options. It sounds like you have your preferences dialed in pretty well. I bet if you stop by Bike Works they'd have something that fit your needs.
Here's my 1982 Specialized Sequoia as an example of a sport touring bike built kind of like you seem to want.
My Bikes
My Bikes
aged to perfection
Quoted: 837 Post(s)
Liked 1,258 Times
here's a good one that is looking for a home. Hardly ridden and your size. PM sent.
Mark Petry
Mark Petry
Quoted: 2338 Post(s)
Liked 2,822 Times
Early 80's Japanese mid level bikes like bike like Nishiki, Centurion, panasonic, bridgestone, univega get my vote you can keep them simple (friction or upgrade) easy to work on and good quality
easy to put a north style bar on for more upright commuting (and then use a thumb shifter)
both of these wold work, the bridgestone is a upper end model
and to be clear Steel frames are not heavier than aluminum
63 cm in bellingham $125 https://bellingham.craigslist.org/bi...945112402.html
loooks like a nice bridgestone $325 https://seattle.craigslist.org/see/b...953742405.html
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
The other advantage of a rigid frame MTB is cost. Nice rigid frame MTBs are typically around $100. Sure, the super desirable names like the early Stumpjumpers are much higher.
Do be careful on size. I've seen as much as 2 inch difference in top tube length, for the same size MTB, between models and brands.
My Cimarron was a garage sale pickup, in deplorable condition, but only $15. I recently picked up a lightly used 1990 Shogun MTB, full Deore XT, for $65 and did a "transplant". I like how it turned out.
Again, not all MTBs work out that well, and they are not for everyone. Doing an upright conversion, to North Road handlebars, is the cheapest option. That way you can use original shifters and brake levers. I've done a few of those for family and friends.
88 Cimarron 2019 Version by wrk101, on Flickr
Schwinn Sierra NR by wrk101, on Flickr
1988 High Sierra 3 by wrk101, on Flickr
Shifting is fun!
Bikes: Yes, please.
Quoted: 2198 Post(s)
Liked 4,600 Times
Interesting to see all these suggestions for sporty machines. Where I live the most important quality of a commuter bike is that you can just hop on in your suit and tie and pedal to work. Upright bikes with fenders and closed chain cases have a distinct advantage in that respect.
Likes For non-fixie:
Quoted: 18375 Post(s)
Liked 4,510 Times
How old are you looking? This is my hybrid to drop conversion. Frame dates to about 2000. 520 steel.
I think a 23" (58.4cm) was the biggest the Trek 520 was sold in, at least by going off the 90's catalogs I have seen. There may have been a larger size in the earlier years.
I'm 6'2" as well and fit a 23" 520 nicely. I have shorter legs, compared to my torso, so any larger and I wouldn't clear the top tube.
You didn't mention whether you want drop or flat bars so I'll echo either a vintage mountain bike or touring bike. Just note that rim brakes are not the best in wet conditions like Seattle, discs are better at that.
Liked 2,822 Times
But the question is how long is the average commute? My understanding is that it is not that far in the Netherlands.
over the last years my commute distance has varied from 5 to 10 miles one way, for me anything over 5 miles is better on a more "sporty" bike
Quoted: 1609 Post(s)
Liked 2,590 Times
I'm 6'2" so looking for at least 60cm, maybe up to 63cm.
Likes For curbtender:
Quoted: 1088 Post(s)
Liked 1,205 Times
Quoted: 767 Post(s)
Liked 1,898 Times
Thanks!
Thanks!
Mounting points for racks, bags, lights, bottles, etc., are all plusses.
If I had a daily commute, I'd ride this:
Quoted: 4806 Post(s)
Liked 3,928 Times
On plus of this approach - things happen to commuters. Those frames were so similar that almost all the parts would just lift off one frame and go on the next. Even bottom brackets, headsets and seatposts. One evening of work and often nothing to buy beyond cables and the like.
Thankfully, the Japanese built thousands of those bikes and inspired makers in Europe and the US to do the same. Those bikes are out there to be had.
Ben
