Bottom bracket options - lightning cranks
Bikes: 2003 Cannondale Jekyll 1000, 2014 Fuji Finest 1.5 (wife), 2008 Fuji Finest 1.0 (Daughter), 2012 Fuji Cross 2.0 (son), 2011 Cannondale Road Tandem 2
Quoted: 57 Post(s)
Liked 27 Times
Are there any alternative options to replace the bottom brackets for lightning tandem cranks?
Bikes: See user name...
That really depends on what the bike's bottom bracket type is. I replaced the Lightning stoker BB with a wheels manufacturing BB when the original started creaking.
https://www.universalcycles.com/shop...s.php?id=96097
Quoted: 57 Post(s)
Liked 27 Times
This is a calfee with standard threaded cups
Likes For TobyGadd:
Most bottom bracket companies have options for 30mm spindles with ~86mm bearing span. I'm a huge fan of Wheels MFG bottom brackets with angular contact bearings for use on tandems.
Quoted: 57 Post(s)
Liked 27 Times
Thanks to all who commented. Ended up getting the cups direct from lightning (the wheels mfg would have been preference but could not find anyone with them available fast enough. I got them installed and found the noise I was trying to rectify didnt go away 🤔. Digging a little further and almost fully disassembling the crankset I found that the spider lock ring had loosened, ever so slightly. Just enough to create an intermittent hard to locate creak! Problem now solved (and new bottom brackets lol)
Likes For ahultin:
Likes For TobyGadd:
Clipless in Coeur d'Alene
The small issue with the lockring is a known quirk that Lightning is aware of (a few of us owners have notified them previously). The best solution to solve is by adding a super thin washer between the lockring and the spider body, which fixes the issue of the lockring working loose by 100%. Lightning supplied us with the thin washer promptly and without charge. When we travel, I do include the lockring tool in my tool kit, as that item is custom and you cannot use a generic or Specialized ring tool.
Likes For twocicle:
Quoted: 57 Post(s)
Liked 27 Times
You ended up getting probably the best option for new BB cups since the Lightning version has ABEC-5 bearings which are superior to lower spec bearings (Wheels uses ABEC-3). Sadly like most things now, the price has jumped up a bit from the long static cost of $60 to $85, but happily it is still well under the $100 that Wheels charges for lower quality bearings.
Quoted: 5 Post(s)
Lightning cranks and diagnosing noise
I have lightning cranks on my tandem and last time we took it out, the noises and creaking were pretty bad. The bearings had been replaced by a mechanic not too long ago, but something definitely seems off. Would you suggest checking 5he lock ring on the captain’s cranks, or stoker’s cranks, maybe both? Any suggestions on how to maybe find the issue. Thanks!
Quoted: 57 Post(s)
Liked 27 Times
Ours was the drive side stoker spider, that said, the plan is to request the shims for all three spiders twocicle described from lightening as well as the correct tool amd get all three to spec.
Tightening the drive side stoker spider eliminated 90% of the creak on for the whole of the stp ride we just completed!
Quoted: 5 Post(s)
In terms of asking Lightning for this washer (or maybe it is a shim), does this go between the spider and the spider lock ring? Will Lightning know what I am asking about when I contact them? Lastly, since this is a tandem, should I request 3 of these washers? Thank you!
Quoted: 5 Post(s)
Lockring tool
Is the lockring tool the same as Specialized lock ring tool, for cranks that are very similar to the lightning cranks? Or is the Lightning lockring tool specific and different from the specialized version? Thank You!
Quoted: 57 Post(s)
Liked 27 Times
based on what Bryan mentioned above, it appears the lock ring and lock ring tool are proprietary.
The lockring tool is different than Specialized which will not work on these cranks.
Quoted: 5 Post(s)
Lockring tool and washers / shims
I ordered the Lightning lock ring tool and 3 new spider lock rings from Lightning yesterday. I believe I was speaking with Tim at Lightning, and he said he would also include these washers or shims, 3 of them, which have been mentioned in this thread. From your last post, it sounds like I really only need to use 1 of these shims on the stoker drive side. I guess I may end up with a couple of spares; not a bad problem to have, Just curious, why is the shim good for the stoker drive side, but not needed for the timing side cranks. If it is a pain to explain, then I understand and you can ignore my curiosity. I will go with your experience and advice. Thank you!
Quoted: 5 Post(s)
I received the lock rings, shims,and lock ring tool from Lightning. The directions say to use Blue Locktite on the lock rings; is this what others have done? Thanks!
I don't have this crank, but I would absolutely follow their instructions if I did! In general, if something isn't supposed to turn, I use blue Loctite. It's got good grip, but is still easy enough to break.
I would not call this additional micro-thin washer a shim (ie it is not used as a spacer). If it was installed between the BB bearing cup and the tandem frame or the BB bearings and the crank spider, then it would be a shim. pOtAtO, pOtatO.
Anyway, the washer is only needed behind the stoker drive side spider lockring, and I assume only on this one crank side because it may have something to with the direction of crank force vs. the direction of the lockring threads that tends to work loose this one lockring. The 2 non-drive side cranksets rotate in the opposite direction, which may explain why no additional washer has been needed on these cranks to my knowledge - FWIW.
Yes, blue locktite should be used/re-applied on the lockring threads anytime the ring is reinstalled or retightened.
Sorry for the long delay in responding, I'm not in this forum much lately.
Likes For twocicle:
