SKS fenders
Bikes: 61 Bianchi Specialissima 71 Peugeot G50 7? P'geot PX10 74 Raleigh GranSport 75 P'geot UO8 78? Raleigh Team Pro 82 P'geot PSV 86 P'geot PX 91 Bridgestone MB0 92 B'stone XO1 97 Rans VRex 92 Cannondale R1000 94 B'stone MB5 97 Vitus 997
Quoted: 392 Post(s)
Liked 49 Times
SKS fenders
I just spent two hours installing a set of SKS fenders. What a fiddly, over complicated, and yet inadequate design. Never again.
Bikes: 2011 Lynskey Sportive, 1988 Cannondale SM400
Quoted: 20 Post(s)
I agree- I got a set for Xmas 2013 to put on my Lynskey. The hardware won't stay tight, and I lost enough of it in short order that i went back to the Crud Roadracers that I had leftover from my previous road bike.
Quoted: 392 Post(s)
Liked 49 Times
Here are my beefs.
- Each of the four stay to fender clamping/adjustment points involves three small, loose pieces (x4 stays = 12 loose bits) that are trying to fall apart or get launched by a flexed stay and get lost - until you finally get them tightened down. They don't give you any extra bits. Lose one, and you'll spend all night crawling around your shop floor.
- Because of this, you are well advised to assemble all the stays to the fender at the work bench, then fit the entire assembly to the bike.
- But the stays are much too long for most bikes, and the plastic retainers that go on the end of the stays have closed ends. So you need to cut the stays, unless you want the fender to sit an inch off the tire.
- This means you have to assemble the whole thing, install it on the bike, measure how much excess space there is between the fender and the tire at each set of stays, disassemble the whole thing, cut the stays, then reassemble and install the whole thing. Hope you measured right!
- I guess if you have done a couple before, you know to mount the stays on the eyelet, just hold the fender in place, mark the stays, cut, then proceed. But the instructions sure don't tell you this. And they are in German anyway.
Compare to Planet Bike fenders. The stay to fender clamp adjustment mechanism is preassembled on the fender. Nothing can come loose. Simply stick in the stay and half tighten the nut. You can install the stays to the eyelets first, then put the fender on, or install the stays to the fender and mount it as one piece, whichever you wish. After you get the fender on the bike, you simply push it to the desired clearance from the tire, fully tighten the nut to hold it, then cut the excess stay.
I will say that the SKS fenders are solid once mounted. And you can learn how to mount them, I'm sure the second or hundredth set is lots faster than the first. But if you ever have to take them off, they dissolve into a bunch of easily lost little bits again. And you can't move then to another bike with a much taller tire or a lower eyelet position. Because the stay has been cut, and the plastic retainer only allows a little bit of adjustment. With the Planet Bike fenders, you can leave the stays uncut and then move the fender freely to another bike, or use a different eyelet on the same bike.
The SKS fenders were a good bit cheaper than the Planet Bike fenders, at the LBS. The LBS warned me not to buy them, saying the installation was hard. I thought (insert thought bubble here) "give me a break, I've installed VOs, PDWs, Cruds, RaceBlades, PBs - almost every fender other than the SKS, this lady is just patronizing me". She was right. Next time, I'll pay extra for the PBs. Even if I don't mind the extra hassle of the SKS install, being able to move the PBs from bike to bike is worth it.
Oh, and SKS don't include any mudflaps. Really?
If you are ok with a lot of excess stay length, you could have just clipped the tops of those plastic caps off letting the stay slide all the way through it. The one pair of Planet bike fenders I have came with some tiny rubber caps for the stay which didn't last long. The SKS plastic bits have proven far more durable though I did crack the top of one somehow.
Constant tinkerer
+1 After trying a couple different kinds I always come back to Planet Bike fenders. They're about the cheapest on the market and seem to work the best. Mine have held up to tons of abuse over the years on my commuter.
My favorite are the cheapest, most basic model. These: Full Fenders hybrid/touring (2015)
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4339 Post(s)
Liked 2,982 Times
I had some Velo Orange fenders that were real pretty, but 10* the hassle to install as SKS.
I had some PB fenders that went on easy, but looked cheap and didn't cover as well.
These SKS Longboards are nice.
Um, no.
Bikes: 2012 Motobecane Fantom CXX, 2012 Motobecane Fantom CX, 1997 Bianchi Nyala, 200? Burley Rock 'n Roll
+1. I also have 3 bikes with these fenders and had no trouble installing them. These are the P__ models. They have been very durable as well. Once I had a Planet Bike fender (Freddy Fenders) get caught in the front tire, and it folded up, stopped the front wheel, and dumped me. I don't know if they still use that same flexible material, but I have no desire to try Planet Bike again. The SKS fenders are stiffer, and there is really no chance that the same thing could happen.
Quoted: 4212 Post(s)
Liked 3,883 Times
Comfort is achieved with practice, one learns how to manipulate the various parts easily and only once. Just like any new device with complexity, it takes time to get the mechanical coordination down. Andy.
Quoted: 392 Post(s)
Liked 49 Times
Mine came with no mudguards. Maybe they omit them on the cheapest model?
Bikes: '04 LeMond Buenos Aires, '82 Bianchi Nuova Racing, De Rosa SLX, Bridgestone MB-1, Guerciotti TSX, Torpado Aelle, LeMond Tourmalet 853, Bridgestone Radac
Quoted: 101 Post(s)
Liked 46 Times
I don't know if SKSs still mount the same, but the ones I bought in 2007 had a ridiculous piece of cheap metal that you were supposed to clamp with pliers around the rear fender, then attach that to the brake bridge. I don't remember how long I messed with it, but eventually gave up. I drilled a couple holes and zip-tied the fender to the brake bridge.
Ive got it down to a science now, so next time .....
Never had an Issue .. Done 3 installs *, 2 Bikes came with them standard equipment ..
* one done 30 years ago is still fine.. I do them for customers at LBS , But I've been supplanted by 30 year olds lately.
sorry I cant do it for you over the internet, PDX has plenty of places that will.
Of course I have No Idea about your abusive practices .
Bikes: Frequently
Quoted: 158 Post(s)
Liked 253 Times
I've felt your pain.
I've done the SKS install a couple times, including recently, and a PB install recently. PB was much more installer-friendly.
Mudflaps are included on the SKS longboards (as you suggested further down) unlike the prior version I have, but I found them too long for my tourer's 700c front wheel! Ridiculous.
The old set of SKS has held up well over several thousand miles, tho; I have to give them that. And the break-away function worked as it should.
Half way there
Quoted: 989 Post(s)
Liked 884 Times
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
I did an SKS longboard P35 mod on my Seven:
https://imgur.com/a/cL4H1
Problem with the front fender is eventually the front mudflap flapped enough to fatigue the plastic it was attached to below the stay brackets so I had to ziptie it on.
Quoted: 2604 Post(s)
Liked 1,934 Times
SKS fenders can be a bit fiddly to install, but now that they're on I don't think I'll take them off either bike. Maybe I wsa just lucky and didn't lose any of the fender stay attachment parts.
It's MY mountain
Liked 2,982 Times
Liked 406 Times
The stock River-City-Reacharound bracket for the front caliper does not work with Campagnolo brake calipers when used with a normal depth carbon fork. If it did things would be much simpler. And every single replacement I've devised metal fatigues due to road vibration. Until I come up with a eureka moment, I just zip-tie it the front fore-fender to the caliper when there's a chance of rain, otherwise I leave it off. That front fender does make a surprising difference in your quads getting wet or not from road moisture.
You Try a Sheldon's Nut?
I splice mine for tire clearance ... winter bike Lowest point was the fork crown so I mounted the stub in front ..
it Is a hub drum, not a rim brake rig
Liked 406 Times
zip-ties are about the only thing that I can think of at the time.
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
Ever looked at Curana fenders?
It's MY mountain
Liked 2,982 Times
Thanks - "Bruce" has his own Picasa page:
https://picasaweb.google.com/1081129...STrekDistrictS
