worth getting narrower tires? (currently running 40mm)
My hybrid has 40mm Schwalbe G-One Allround, Kevlar, 40-622. So far they have been great tires, no punctures in 6 months and I feel reasonably fast, although i really dont measure these things as im not out to race.
I run them at max pressure of 70psi, my logic being a hard tire is more resistant to punctures, and my limited experience so far has agreed with this.
I was thinking of switching down to 32mm tires to see if it made the bike a feel more performant.
From reading around, 40 is quite wide, even for a commuter and there may be benefits to a narrower tire, without going too narrow.
What are peoples thoughts on this?
Pennylane Splitter
Bikes: Yes
Quoted: 1807 Post(s)
Liked 1,448 Times
Make sure your rims will take whatever size you want to go down to. I've never used 40mm tires, almost always been in the 32mm-35mm range, and never had problems with them. Plenty of brands, tread styles, and other options in the 32-35mm range.
Likes For tyrion:
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
If you feel reasonably fast and you aren't out to race, why is increasing performance important? If it ain't broke...
Likes For Rolla:
aka Phil Jungels
A narrower tire, like a 35-32 on the front will improve performance, less than 40 on the rear - not so much, and comfort will suffer.
https://www.bicyclerollingresistance.com/
Look up your current tires, and then compare them to other tires you may be considering. But know that rolling resistance is a small percentage of the overall amount of power needed to move a bike. This BRR website does give good reviews and comparisons of tires. It's also good to know things like the puncture resistance. While I don't use just the numbers to make tire selections, I do use the information.
Likes For ofajen:
Im glad i posted, as advice is a narrower tire wont make a huge difference and more importantly and unexpectedly, im running the tires way too hard.
Will drop them down by 10-15psi on the next spin.
Thanks all!
Thanks all!
Likes For wilson_smyth:
Clark W. Griswold
Quoted: 4371 Post(s)
Liked 4,011 Times
Narrow tires are so last century. Wide or die!
I have a vintage bike I am stuck running 700x25c tires and they are just so small. Even my ti road bike on 28s is a little narrower than I prefer but I love the bike and it is nice to have a pure road bike for just tarmac but even still 30s or 32s might have been nice as well.
I have been commuting on 28mm tires for decades. Never an issue with flats or durability. I also have a Miyata 1000 with 38mm tires on it that I use for commuting once in a while. The fit of the two bikes is near identical. The rack, bags, lights, pedals, and drive train are identical. The different tire size makes a slight difference in the commute time. 15 miles one way takes about 10 minutes longer on the wider tire bike. Mostly I feel the difference climbing out of the river valley, and the other hills on the route. Comes down to acceleration. When the wheels have to be pushed the narrow tires do it better. I will say, the 38mm tires have never had a flat, whereas the 28mm have had two flats in the last 4000 miles. 28mm tires are the low end Conti Ultra Sport tires, the 38mm tires are Conti City Ride tires.
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
Otto
Likes For Flip Flop Rider:
Bikes: Norco search xr
Quoted: 198 Post(s)
Liked 146 Times
I went from treaded 40mm tires to smooth 32mm tires on my gravel bike and on asphalt they perform so much better! Of course I lost the ability to wonder in the deep gravel, but for the asphalt it was a fantastic upgrade.
Likes For Gconan:
Tire pressure will depend on your weight and more importantly, load on each wheel (you'll need to weight the front and back wheel separately with you sitted on the bike) and set your pressure according to those numbers.
I can't find a psi table with 40mm road tires but the pressure used for 37mm shown below should be good too for 40mm. Yep, 70 psi sounds excessive, unless you weigh 300 lbs
It might be worth getting narrow tires for the reduced pedaling effort and ability to cruise at higher speeds but at the cost of bumpier ride and higher probability of pinch flats when hitting potholes, etc.
The sram pressure calculator (link at bottom) guesstimates 42 & 45 psi respectively, for front and back. That seems very low though, but now I'm thinking the internal model I have in my head of bike setup is wrong and needs recalibration. Reduced from 70 to 55psi each for my next ride but will go lower for thr one after.
Nice to have stuff to play with on the bike that costs nothing!
https://axs.sram.com/guides/tire/pressure
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
I weigh 165, I inflate the 40mm tires I have (Rene Herse, smooth) to a little under 40psi front and a little over 40psi rear. Remember, it's free to experiment, unless you flat of course. Think of it this way...if you had 50mm tires on your mtb what would you inflate them to? That's 2". You'd probably be around 30ish for off road. 55 is still way high for road use.
cyclotourist
Quoted: 443 Post(s)
Liked 205 Times
I might get flack for this, but I'm going to link to Jan Heine's Myths in Cycling (1): Wider Tires Are Slower
Likes For skookum:
Mad bike riding scientist
Quoted: 6222 Post(s)
Liked 4,222 Times
Based on what evidence? I know that people think that low pressures allow the tire to flex around an object better than high pressure does but, in practice, I’ve never found tire pressure to have much effect on flat frequency. I have bikes that run 110 psi to 80 psi to 40 psi on my mountain bikes. All of them have gotten flats at some point with about the same rate. The mountain bikes experience far more flats than my other bikes but they are ridden in places that are more prone to objects that can puncture the tire. Most of the time, that’s goatheads but I did flat this last week on a prickly pear cactus spike.
Stuart Black
Stuart Black
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
So, I choose tire pressure based on other performance considerations, like comfort, stability, rolling resistance and so on.
My rides generally include stone trails and gravel, so I run bigger tires and lower pressures.
Otto
Likes For ofajen:
Quoted: 4227 Post(s)
Liked 2,488 Times
I wouldn't run anything smaller than a 32mm tire.
Liked 2,982 Times
Going from 28s stock R & F to the combo of 30 R 28 F has provided the best thus far.
Before settling for that combo, had a various other combos that didn't provide any or minimal benefits. Such combinations tried; 28 R 32 F - 28 R - 34 F - 32 R - 28 F - 30 R 32 F
28 R 34 F was worst, 34 R would not clear.
-Oh Hey!
-Oh Hey!
Bikes: lots
Liked 2,932 Times
aka Phil Jungels
40 on the rear, and a 35 on the front... A 32 will be more harsh!
The 35 will quicken steering, and make it more precise.... Therefore, performance is improved.
Liked 4,222 Times
No. Bicycle tire calculators say that is right for my weight. Years of riding experience tell me that is the right pressure for my weight. Frankly, I see any thing less than that to be far too low. I’ve never had problems with pinch flats nor with rim damage. I’ve ridden on tires that are going flat and could never stand the wallowing feel that goes along with flat tires.
Stuart Black
Stuart Black
