Newb question: bottom bracket replacement
I have an 1960's schwinn bike frame that has a one piece crank and threadleas bottom
Bracket casing.
Without realizing, I bought a cartridge bottom bracket and three piece crankset to match the bB.
My question is, will it be possible to
Use the newer crankset and Bortom
Bracket in my old frame. The frame seems to be threadless where the bottom bracket would go.
Is it possible?
Bracket casing.
Is it possible?
Quoted: 2026 Post(s)
Liked 1,096 Times
There is an adapter that converts Ashtabula (one piece) bottom brackets to standard English threads. Harris Cyclery has them for about $20. Look here:
https://harriscyclery.net/product/tru...apter-1335.htm
Mechanic/Tourist
Also, the length of bottom bracket axles varies depending on several factors. Hopefully you ordered a crankset that will be compatible with your frame and drivetrain.
Location: England, currently dividing my time between university in Guildford and home just outside Reading
Bikes: Too many to list here!
Quoted: 1074 Post(s)
Liked 295 Times
Sounds like he already has those parts - assuming he's got the right length for the chain line to line up.
