Forumslader (USB charger) - first impressions
cyclotourist
Quoted: 443 Post(s)
Liked 205 Times
How do I place an order and pay?
Orders are currently only possible via email, unfortunately prepayment is required. We prefer SEPA within the EU, outside Europe and PayPal is also possible on request.
How long is the delivery time?
We can almost always send kits within the next few days after receipt of the money, but mounted loaders have delivery times of 3-6 weeks (please ask).
Quoted: 86 Post(s)
Liked 51 Times
Price list in English:
https://www.forumslader.de/fileadmin/...st_english.pdf
Assembly instructions in English:
https://www.forumslader.de/fileadmin/...V5_kompakt.pdf
I'm thinking of getting a Forumslader V5 Ahead and don't mind a bit of DIY. I don't get how the electronics and battery assembly is secured in the steerer tube though? Or is this left up to the installer to work out for themselves? An expander plug (not supplied) is used to secure the USB stem cap right? Then the cables pass through this to the electronics below, but what is securing / supporting the electronics?
Bikes: Custom built LHT & Troll
Quoted: 837 Post(s)
Liked 149 Times
It is supported from above by the wires going to the USB plug, and if you like, from below by some stuffing (eg. a piece of foam). Being very lightweight, wires from above appear to be sufficient. (I've added a couple of layers of silicone tape around the cylinder, to add friction between the forumslader and the steerer. Zero sign of stress)
Thanks for confirmng - I was wondering if it was just hanging by the wires! That's good to know and about the weight and padding / foam idea too. Thanks
Quoted: 86 Post(s)
Liked 51 Times
If you want something more permanent than foam, you can shove a starnut all the way down to the fork crown, or up from below, and feed the wires up through the gaps. Assuming it's an old style metal fork with a steerer tube that's open top to bottom.
Personally I like the tight foam plug idea. You might add some hot melt glue around the edge for a bit more peace of mind.
That's a good call about using the star nut. I was planning on ordering a expander nut for the top of the stem, so I could reuse the existing star nut on the bottom for support. (I can see all the way through the steerer tube when I remove the stem cap). I'm a bit apprehensive about having the electronics (maybe a couple of hundred grams?) swinging by the USB cables inside, but I'm sure I can find a solution with either foam or starnut or both.
Quoted: 86 Post(s)
Liked 51 Times
If it was me using the star nut... I'd remove one tang with a dremel, polish it smooth, then wrap the heck out of the wire from the hub where it would go through the gap.. Couple of layers of heatshrink maybe, or just a lot of electrical tape. Otherwise the gaps in the tangs are real small, and might be sharp enough to abrade the insulation over time.
Quoted: 1188 Post(s)
Liked 1,154 Times
My own personal opinion is that for touring you are better off having the Forumslader as an independent unit, with the big batteries and a plug connection to the bike wiring. Then get the USB loader and fit the same plug to that. That way the FL acts like a dynamo charging portable battery bank, that you can also charge from a wall outlet. With it removable from the bike you can charge your stuff or the FL in your tent, room, internet cafe. In my case I made it into a tube like a bike pump and use pump clips to mount it on the frame, but you could easily carry it in a handlebar bag.
Likes For Trevtassie:
Most importantly: the email address for the order is info (@) forumslader (dot) de
Bikes: Kona Sutra
Hello,
I am interested in dessing a USB-charger similar to Forumslader but more basic for a university subject.
Do you know the electronic parts?
What is the DC/DC ? Maybe use LT3759 ? or something similar?
Realy I am a little lost,
Can you help me?
Thanks in advance
Can you help me?
Thanks in advance
Quoted: 3452 Post(s)
Liked 1,452 Times
But, I kept blowing out the circuits and gave up. If you ride a bike down a hill without using any of the power out of a bicycle dynonub, the voltage can climb quite high, so your circuit would need to withstand high voltage. I measured over 30 volts coasting down a shallow hill on my dynohub.
So, if you want to build your own, maybe start with a buck step down voltage converter like I did but maybe put in some zener diodes for high voltage or maybe get one that could withstand higher voltage than the one I had.
And like I said, I am not an electronic engineer, so perhaps the little bit of advice I have here is not very good advice.
Good luck.
In the future you might consider starting a new thread instead of resurrecting an older thread for a new purpose.
Bikes: Kona Sutra
I am not an electronic engineer, so I have no clue on a lot of this stuff. But I can say that i was really surprised how much it cost to buy a good USB charger that you could use with a bicycle dynohub. So, I tried to build my own using a USB step down voltage converter with a rectifier. Bicycle dynohubs put out alternating current.
Good luck.
Good luck.
Thanks for the answer. I´m trying to be an electronic engineer
At the moment, I found this information:
-The electrical drawing must have:
*Bridge Rectifier --> Maybe using SBR diodes
*Input Protection --> Maybe using MOSFET
*Input Capacitor blocks
*DC/DC Converter --> This is my biggest doubt. I think like you, the prices in the market of the usb charger are very high however the electronic circuit not. This is why I choose to design it for my university subject.
*Output
*Battery blocks
If I can manufacture it, I "give away" the electrical drawing and the component lists.
Best regards.
The "Forumslader" is the result of a "design your own charger" project
That's exactly how the "Forumslader" came to be. The name says it all. It's a charger (lader) designed my members of the German online "Rad Forum" (Bike Forum). They found that the commercial versions were overpriced and under functioning, so they designed their own.
What they ended up with has more features than I want; the current version (v5!) seems to be oriented around 12V e-bike lighting rather than 6V conventional bike lighting. But it's incredibly good value for what you get, especially if you buy the "kit". Building it yourself also lets you decide how big a cache battery you want, what form-factor you want, and so on.
If you want to design your own, you should of course feel free to do so — it will be a fun and educational project. A really good place to start, though, would be understanding the design ideas and tradeoffs that the Rad Forum designers made — start here.
Bikes: Kona Sutra
If you want to design your own, you should of course feel free to do so — it will be a fun and educational project. A really good place to start, though, would be understanding the design ideas and tradeoffs that the Rad Forum designers made — star here.
Thank you very much for your reply.
So, can you ensure that "Forumslader" uses the MC7806 integrated circuit?
I would say that it does not use an integrated regulator, however it does use a switched regulator.
Bikes: Bruce Gordon BLT, Ridley Orion, Sonder AL Camino, Holdsworth Special, Milwaukee Road (soon)
Maxim 20048?
I am currently tinkering with a Maxim MAX20048 Buck Boost controller which might meet our needs. Has huge input range, can be configured to output 5 volts, minimum input voltage is low at 2v, can output up to 5A. Efficiency in the low 90's. Next step is to buy a USB monitor to measure actual performance at various speeds.
Bikes: Schwinn, Nishiki, Santana, Trek, Rodriguez
Quoted: 189 Post(s)
Liked 106 Times
Liked 1,452 Times
https://www.ebay.com/itm/USB-Power-T...s/123946852024
I measured 30 some volts out of my hub with no load on it on a shallow downhill, you are right that only 40 volts capacity for over-voltage is not high enough.
Quoted: 86 Post(s)
Liked 51 Times
So slap a 40V Zener diode across the inputs
EDIT: or does it need a pair, one in each direction? As the current is AC. Disclaimer: I am not an electrical engineer
Very instructive thread.
BTW, the ad bots keep posting ads for Dodge Chargers, but no info on how to mount them on your bike.
dwmckee
0
06-16-16 09:42 AM
Winfried
10
02-16-13 06:27 PM
late
1
06-08-11 02:38 PM
