Cinelli Identification help please?
Quoted: 5 Post(s)
I have what I believe to be an late 50's, early 60's Cinelli. Not sure if it is a "B" or an "SC".
A couple more bits of information... It came with a sloping crown fully chrome fork. chrome steel bars, and a set of chrome 3 arm cottered cranks with Cinelli engraving. There is an oil port in the BB shell. I'll post more pictures of the parts. It looks like someone took it apart to restore then packed it away. The newspapers it was wrapped in are from 1974.
Serial number is 5404, but apparently the serial numbers are pretty random...
Thanks for any info...
Unfortunately I cannot post any pictures until I have posted 10 times...Sad, but I guess I understand the rule.
Best, Davis
Best, Davis
Forum Moderator
Quoted: 3090 Post(s)
Liked 6,593 Times
Bikes: A few
Quoted: 289 Post(s)
Liked 195 Times
Open C on the dropout. It's an old one for sure. Has the spring hole as well.
Stop reading my posts!
Quoted: 1443 Post(s)
Liked 1,062 Times
Since you say it has the full sloping crown fork, and this style seat cluster, I'd guess it's an SC, and looks like a real beauty! Is there a headbadge?
mycocyclist
Quoted: 910 Post(s)
Liked 812 Times
Additional photographs if you please!
In addition to the details previously mentioned, the "B's" from the pre-three holed lugs period did not feature oil or drain holes, and for a few years had Simplex dropouts.
It's likely an "SC," but we'll need many more pictures to be certain.
Many, many more.
Many, many more.
Quoted: 3015 Post(s)
Liked 3,802 Times
Nice! I suspect 1951-1953 SC.
Sloping fork crown = SC
Oil port on top = SC
Lack of oil drain hole = prior to 1955
Lack of filed rear dropout = prior to 1953
Rear derailleur stop at 7 o'clock = after 1951
Likes For iab:
Liked 3,802 Times
Although I will say that oil port on top is a feature that is more mid-50s. But as with all Cinellis, usually more questions than answers.
Quoted: 4511 Post(s)
Liked 6,378 Times
Best, Davis
Best, Davis
That said, welcome aboard, glad you found us, you're in the right place, we love Cinelli's.
Liked 3,802 Times
Measure the thickness of the rear dropouts. That info could help.
Forum Moderator
Liked 6,593 Times
Likes For DavisCarver:
Crawlin' up, flyin' down
Quoted: 1025 Post(s)
Liked 2,525 Times
Go with iab's info - he knows his stuff. Velo-Reto has a great Cinelli timeline here. It's the source I used for figuring out the approximate ages of Cinellis that have passed through my hands. But iab's info is more detailed for the period yours appears to come from.
You are correct about the random assignment of serial numbers on Cinellis. Their alleged system probably made sense to somebody at some point, by the logic has been lost in the mists of time. Strong men and women have been driven to the brink of madness trying to solve this riddle.
For example, I have two SCs that are in all details identical (the same tube lengths, same angles, same wheelbase, same port holes, same spring hole in the right rear dropout, everything except color) that I have pegged to the mid-1960s. One is serial number 14xx, on is 85xx. Another SC from the early 1970s that I had until recently was 15xx. There is no way Cinelli built enough frames to cycle through the numbers so as to account for the numbering. Go figure.
What a great find you have there. I look forward to learning more about it.
I find the color interesting, especially as it's from the early 1950s. It almost looks like the classic Bianchi celeste. A bold color statement, considering Cino Cinelli had poached one of Bianchi's top builders (Luigi Valsassina) a few years earlier - see the Velo Retro timeline c.1947.
Quoted: 5 Post(s)
I have the feeling that the paint may actually be original, but it is hard to tell. It looks like someone chipped away at the paint on the BB shell to read the serial #. No overspray anywhere I could find.
I can't post pictures until I post 10 times, but if someone is OK with posting them for me, I can e mail them. It might help identify the year by the components.
Best, Davis
Best, Davis
Forum Moderator
Liked 6,593 Times
Additional pic assist.
Can you be more detailed about what filed rear dropouts would look like?
To that list I can add "wolf's ears" lugs.
Liked 3,802 Times
Could be original paint, Cinelli did offer a similar color. But there is no doubt, the headset spacer was rechromed in its life. If someone is willing to rechrome, they could repaint too.
https://www.speedbicycles.ch/velo/48...el_b_1955.html
Liked 3,802 Times
On many, not all, SCs had the back of the of the rear dropouts filed flat instead of being left in the original "rounded" state. Again, a stolen image from Stefan's collection to illustrate..
Liked 3,802 Times
No. Mostly because you haven't a clue of what was changed over the last 65 years and what was not. Also, many times frames hung on shop walls until they were built up later. And, sometimes components didn't change for years.
VeloBase.com - View Single Frame Part
My SC from ca 1971 has the rear dropouts filed down.
Quoted: 5 Post(s)
Some of the components look like they have been rechromed. especially the crankarms and front derailleur cage.
Liked 3,802 Times
Likes For iab:
Liked 3,802 Times
PM sent.
mycocyclist
Quoted: 910 Post(s)
Liked 812 Times
