1989 Trek 930 Single Track
Old 01-06-21, 02:58 PM
grizzly907la
Grouchy Old man
grizzly907la's Avatar
Bikes: Diamond Back Insight 2, Gravity Basecamp mountain bike.
Quoted: 38 Post(s)
Liked 20 Times in 17 Posts
I just bought a 1989 Trek 930. I'm having a hard time finding the specs for the bike. I know its a steel frame bike. I know that the derailleurs are exage 400 lx. I might replace the front derailleur. The rear one looks okay. Any thoughts and/or links? Thanks!
grizzly907la is offline
Old 01-06-21, 03:15 PM
thook
Quoted: 330 Post(s)
Liked 192 Times in 145 Posts
here's the '89 brochure. (scroll way down for mtbs) i don't see a 930 in the brochure, although the 950 matches your color
https://www.vintage-trek.com/images/t...89Brochure.pdf
thook is offline
Old 01-06-21, 03:24 PM
thook
Quoted: 330 Post(s)
there is a 930 listed in the '90 brochure
https://www.vintage-trek.com/images/t...rek/90Trek.pdf
thook is offline
Old 01-06-21, 03:25 PM
3speedslow
3speedslow's Avatar
Bikes: A few
Quoted: 1679 Post(s)
Liked 457 Times in 335 Posts
Hey!
I saw that Trek come up on CL! Nice one. I see you live around there. That part of our state has some nice bikes for sale!
My 930 is a 96 year. Love it!
3speedslow is offline
Old 01-06-21, 03:39 PM
Clang
Quoted: 676 Post(s)
Liked 309 Times in 235 Posts
This is a 1992 model. I have the same bike in the other color offered for this year: red.
Catalog link: It's annoying that the page with the picture for the 930 is missing from this pdf, but the specs are there on page 34.
Trek Catalogue 1992 | Catalogues | Retrobike
Clang is offline
Likes For Clang:
Old 01-06-21, 04:58 PM
grizzly907la
Grouchy Old man
Quoted: 38 Post(s)
Thanks for the info!
Old 01-06-21, 05:02 PM
grizzly907la
Grouchy Old man
Quoted: 38 Post(s)
Originally Posted by 3speedslow View Post
Hey!
I'm in western NC, near Asheville. I figure that I can build it into a respectable touring bike.
Old 01-06-21, 06:30 PM
3speedslow
3speedslow's Avatar
Bikes: A few
I would say you can! Progress pics when you get a chance.
Old 01-06-21, 06:45 PM
grizzly907la
Grouchy Old man
Quoted: 38 Post(s)
I was thinking about filming the work, but I will take plenty of pictures. I just took apart the rear wheel hub. I got some mad scientist ideas for this bike. I just took out the rear axle and free wheel hub. I'm pretty sure it needs to be serviced. My biggest obstacle is finding a spot where I can spray paint it (the current color scheme isn't doing it for me, plus the current had dings, and scratches. I don't want to be touring on what looks like a meth bike.) Once I've got the old paint off, that and buying components. I might swap the fork out for an inexpensive carbon, fork and mount a front disc brake on it. I considered getting a bracket brazed on the back, but decided it against it because it seems to complicated and expensive. If I keep the original fork, I'm going to upgrade the brakes from cantilevers to v-brakes for the front and back.
Old 01-06-21, 09:14 PM
dedhed
SE Wis
dedhed's Avatar
Quoted: 1474 Post(s)
Liked 966 Times in 656 Posts
Levers may not be V brake pull compatible
dedhed is offline
Likes For dedhed:
Old 01-07-21, 12:39 AM
thook
Quoted: 330 Post(s)
they are, though. tektro 520's are specifically made for them. i'd had them on a cross check at one time. they work fine if you keep the pads adjusted close to the rim and have good pads. the standard black ones just aren't that great, ime. i have some v-brakes on one ride currently. i put some kool stop salmon mtb pads on last week and i have to use caution slamming on the brakes. modulation is good enough
thook is offline
Likes For thook:
Old 01-07-21, 07:58 AM
dedhed
SE Wis
dedhed's Avatar
OP has flat bars and didn't mention converting to drop bars which are what 520 levers are for. Nor did they mention what the existing levers are or changing levers at all.
The OPs levers may in fact be switchable between canti pull and V pull, but without knowing what they are, I can't say.
dedhed is offline
Old 01-07-21, 02:18 PM
thook
Quoted: 330 Post(s)
good grief. my bad. hot toddies chasing a sinus eruption leads to neural paralysis i guess. where was i last night?
yeah...ignore what i said then
thook is offline
Likes For thook:
Old 01-07-21, 03:14 PM
Clang
Quoted: 676 Post(s)
There was a nice '92 Trek 930 recently on Blue Lug's Flickr.
https://flic.kr/p/2khUPi9
Clang is offline
Old 01-08-21, 12:24 PM
grizzly907la
Grouchy Old man
Quoted: 38 Post(s)
The bike originally came with flat bars, though I am going to replace them with some trekking bars. I am also replacing the shifters and levers.
I've also used long pull levers, with caliper brakes on my old Denali and they worked just fine. Dumb luck, maybe.
Old 01-08-21, 07:59 PM
9volt
9volt's Avatar
Liked 6 Times in 6 Posts
Here's a purple 930
9volt is offline
Old 01-09-21, 01:21 AM
Korina
Happy banana slug
Korina's Avatar
Bikes: 1992 Specialized Rockhopper Sport, 2016 Giant Liv Rove Lite, 1995 Trek Singletrack 930, 1994 Trek Multitrack 750
Quoted: 780 Post(s)
Liked 439 Times in 298 Posts
You're mad! Mad I say!!
Good luck getting the paint off; Imron is automotive paint, and very tough. For a paint booth, if you have a furniture store around, see if they'll give you one of their oversized cardboard boxes; refrigerator boxes work well too. Dings and scratches are called "patina" around here; battle scars showing the bike's had a life. But, to each their own; paint away! Definitely make a rebuild thread. We like to watch...
And since we're showing off our 930's,
Zoe (Washburn), my badass off-pavement ride.
Korina is offline
Likes For Korina:
Old 01-09-21, 06:52 AM
Jeff Neese
Quoted: 123 Post(s)
Liked 33 Times in 22 Posts
As has been pointed out, it's a '92. Here's mine.
That bike and others like it are a very flexible platform. When I took this picture I had trekking bars, but later converted to drop bars. These make respectable touring frames, but because of the higher bottom bracket it's not going to be as stable under really heavy loads as a purpose-built touring bike does.
Jeff Neese is offline
Likes For Jeff Neese:
Old 01-09-21, 11:03 AM
Mr. 66
Mr. 66's Avatar
Quoted: 468 Post(s)
Liked 316 Times in 231 Posts
Since everyone else is showing theirs. My Mean green 930.
Built up with Deore 9 speed. This my son's bike for campus uses.
Mr. 66 is offline
Likes For Mr. 66:
Old 01-10-21, 08:56 AM
3speedslow
3speedslow's Avatar
Bikes: A few
Showing? Well okay!
96 in inkwell blue.
Likes For 3speedslow:
Old 01-10-21, 07:28 PM
grizzly907la
Grouchy Old man
Quoted: 38 Post(s)
I shall take plenty of pics! Not to worry, I'll add my own battle scars to the bike....as I am building it back up and I am sure to get some as I ride it.
Old 01-10-21, 08:10 PM
grizzly907la
Grouchy Old man
Quoted: 38 Post(s)
Define heavy and why would a higher bb effect stability? Just curious.
Old 01-11-21, 04:42 AM
Jeff Neese
Quoted: 123 Post(s)
This is heavy. The bike is a 1983 Trek 720. Lower BB = lower center of gravity, improved stability.
Old 01-11-21, 09:33 AM
grizzly907la
Grouchy Old man
Quoted: 38 Post(s)
That does look heavy. I have a steel shogun frame, that needs stripping and painting. Thanks for the answer. That helps me better understand things.
