ISO: 27.0 silver post, NDS Shimano Italian cartridge cup
Dropped
ISO: NDS Shimano Italian cartridge cup
Building up a '69 Atala Record Pro frameset with on-hand parts to see how it rides, and have run into numerous roadblocks with crank choices. Going with a Sugino XD now. I have a Shimano UN-52 cartridge BB but I'm missing the NDS fixing cup. Does anyone have an orphan kicking around your parts stash, or a trashed cartridge that can donate one? Must be Italian thread because the BB shell diameter is wider than BSA. OD on NDS cartridge body is 30mm.
FOUND! Thanks L134Also looking for a functional one piece silver seatpost in 27.0, normal or zero setback. Well worn is fine as long as it functions properly and safely.
Thanks!
FOUND! Thanks L134
Thanks!
Dropped
Quoted: 7348 Post(s)
Liked 2,470 Times
@JunkYardBike, hi! Haven't seen you in a long time!
Likes For noglider:
Dropped
Quoted: 1088 Post(s)
Liked 1,205 Times
Silver, huh? I have a black American Classic 27.0 I would be willing to trade if that interests you. I'm looking for a crank set or a set of drop bars, but I'm a little picky as to which for this next build. PM me if you're interested.
Dropped
Thanks, I'll keep it in mind. But I strongly prefer silver, so will keep looking.
Quoted: 3810 Post(s)
Liked 6,699 Times
Dropped
Patrick, I have a silver 27.0 American Classic. One caveat: @rhm recently tried to install it in a bike that had a 27.0 post, but found it was too large. I can measure with my dial calipers, but clearly not all 27.0 posts are the same size!
Bikes: 1978 Bruce Gordon, 1977 Lippy, 199? Lippy tandem, Bike Friday NWT, 1982 Trek 720, 2012 Rivendell Atlantis, 1983 Bianchi Specialissima?
Quoted: 345 Post(s)
Liked 175 Times
Thanks!
Thanks!
one is well used and may be missing the clamps (I’d have to check loose parts).
The other is complete and appears to never have been installed. Each appears to be 190mm though I’m not certain how one measures. I measured from end to about the clamp.
Dropped
I have 2 SR custom of this style:
Quoted: 345 Post(s)
Liked 175 Times
Quoted: 345 Post(s)
Liked 175 Times
Just a minor heads-up to say that I've found Phil Wood lockrings fit Shimano sealed bbs very nicely. I recognize that they're priced higher and worth more than loose Shimano cups, but can you actually buy new loose Shimano cups? I don't know, just asking that one.
At any rate, just so folks know, if they didn't, you might be looking for a Shimano cup not realizing you've got loose Phil rings kicking around that'll fit. I'll use them as replacements sometimes with older/higher-end Shimano bbs with dual removable cups, because they give you more control over bb position, chainline and inner-chainring clearance.
Fuggedaboutit!
Fuggedaboutit!
Likes For pcb:
Dropped
That's a good tip. I do have one set of Phil cups, but they are British. I ended up buying a replacement BB for this - $15 less than a set of Phil cups! Still willing to buy a spare cup if someone has one - or if someone has the cup and is looking for a good cartridge, I've got one! Shimano does sell loose ES50 plastic cups, but I have a bunch of those and they don't fit the UN5x I tried them on.
