Front Derailleur Esoteric Quest
#51
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
mtb's have higher bottom bracket, so it's easy for a longer cage to clear the stay when/if using smaller rings on them
#52
Quoted: 1088 Post(s)
Liked 1,025 Times
I did check the Tiagra a lot more tonight and I think I might have to cancel my order for the derailleurs, they might not work at all. The 4700 tiagra der I do have, like several other random, more modern ders, has an offset to the front and rear plates that would not allow plates to be screwed together at an alternate location like an older style might. However the plates, in part due to thickness and in part due to shaping are incredibly stiff compared to a number of older ders that I have. Makes me wonder if just cutting and shaping wouldn't have enough stiffness. The back plate has two widely spaced connection points plenty of shaping to make it stiff for pushing and the front plate is pulling where it is strongest. I'd suspect the upshift would be where it might have the most trouble and if Gavenelle doesn't come up with more shifters I might have to test out the new disc sander and the grinder and find out just how stiff the der is without the sides connected.
#53
small ring
Quoted: 438 Post(s)
Liked 925 Times
59 Allegro Special -- 72 Bob Jackson -- 74 Motobecane Grand Jubile -- 74 Sekine SHS 271 -- 80 Nishiki International
#54
Reasons for an IHG with cogs:
- No front derailleur so can use a chainguard.
- Needs a tall overdrive because of tiny wheels, like a Brompton.
- Needs an ultra-low granny because pedaling a recumbent towing a heavy trailer up hills.
#55
Señor Member
Quoted: 1491 Post(s)
Liked 1,090 Times
That's 63. I'm guessing 3 front x 9 rear x 3 IHG = 81 = no reason for it on that bike.
- Because I feel like it.
Likes For USAZorro:
