ISO: "touring" parts..
Quoted: 1872 Post(s)
Liked 692 Times
..even though I won't be touring. But I need to set up my bike with low enough gearing to race 150 miles and 10,000ft climbing.
I'm thinking 32h 700c wheels, 170mm low-geared (triple?) crankset w/ corresponding Italian BB, derailleurs, 13-32? freewheel or similar (7s?) cassette (obviously has to match the wheels), barend shifters, indexed would be awesome.
Also need toe strap type pedals. And a Selle San Marco Regal from the 80s. And possibly a full size frame pump. Piece of cake right?
- crank ✓
- barend indexed (8s?) group
- 32h wheels
- BB (for Sakae triple crank)
- freewheel/cassette (depends on the wheels) ✓
- toe strap pedals ✓
- 26.6 seatpost ~300mm+ ✓
- Vittoria 1976 shoes (size 11)
- Selle San Marco Regal ✓
- frame pump
- crank ✓
- 32h wheels
- frame pump
Quoted: 5888 Post(s)
Liked 3,471 Times
Tough to beat a 110 bcd crank which you can run as a triple. With 7 on the back and the ride you're talking about (150 miles, 10000 ft climbing), I'd run a triple. I like the old school MTB set up with 46/36/24 rings and an 11-28 7 speed cassette. 11-28 7 speed cassettes are available new even if the supply has been drying up with the pandemic. If you go with a freewheel, 14-28 is the most likely combo new but there are older freewheels out there with 13-28 or even 12-28 but they may be hard to source. Bottom line is first you have to figure out what kind of wheels you are running (freewheel or cassette) as that will likely make a difference as to what kind of rings you want for the crank.
For new 126 OLD wheels, I'd check out what velomine has for sale as well. They have reasonable prices and good products.
For a crank, a 110 bcd crank is your best bet but you'll find more supply at 175 mm than 170 since 175 was a pretty common size on MTBs. The supply of square taper bottom brackets is shrinking but you can still find 68 x 127 BBs. Those seem to work the best with the shimano deore triples I've set up.
For shifters, 7 speed shimano bar ends are a great choice. For derailleurs, just run shimano deore derailleurs.
Depends what you are looking for, but I have a sakae triple and an ultegra 6503 (octalink) triple & long cage rd
Liked 692 Times
2019 Salsa Warbird
2019 Salsa Warbird
Liked 3,471 Times
Liked 3,471 Times
It sounds like you're starting with a frame since you are looking for an Italian BB. Are you looking to just change out the drive train and you have the rest of the parts in hand?
tantum vehi
Quoted: 1167 Post(s)
Liked 992 Times
Now if you want to get eccentric (not in the bottom bracket) one could also explore the half step plus granny route with just a six speed cassette: 50-45-24 up front and 12-14-17-21-26-32 in back. You’ll have to make the cassette yourself out of two other cassettes, but it’s doable. Put a shiny chrome dork disk on and you’ve got your spacer on a 7s hub. Ask me how I know...
Likes For mountaindave:
Liked 3,471 Times
If the frame you are working from is a racing bike with tight clearances, you might want to consider a compact crank. Triples can be a bit of a PITA to set up with short chain stays.
aka: Dr. Cannondale
Quoted: 2152 Post(s)
Liked 3,402 Times
Sounds like you're looking at that vintage gravel bike race later this year...
Likes For rccardr:
Liked 692 Times
Gravel Worlds here I come!
2019 Salsa Warbird
2019 Salsa Warbird
Liked 3,471 Times
You might want to consider a 650b conversion for that Windsor but brake reach may be an issue. The parts mix is easy. I’d just get Deore/shimano 600 quality parts and go 3 by 7 with shimano bar end shifters. One thing I've found is that when setting up a triple with a shimano 110/74 bcd crank, a 127 mm sealed square taper bottom bracket works best.
Liked 692 Times
2019 Salsa Warbird
2019 Salsa Warbird
Liked 692 Times
morri869 just hooked me up with that triple crank, so that will be a great starting point. I should edit the original post with a better checklist of things I need. 7s indexed barends would be amazing!
2019 Salsa Warbird
2019 Salsa Warbird
Liked 3,471 Times
Well, so, I've found out that 7s barend shifters aren't exactly easy to find or cheap. After tinkering with things tonight I'm half decided to go with the Schwinn Voyageur. I'm not sure the 3x7 indexed XT/Deore option you're talking about will be easy to find. And honestly, for the sake of ease a 2x7 drivetrain would be awesome, if I could find a period correct ~50/34 crank. 48/32 would be ideal. Did someone like TA make such a thing?
The triple you just bought is a 110/74. You can go 50/34 with the outer two. You could try running it using the middle and inner only in which case you can run as low as 24 on the inside. I've never set it up that way though.
If you want a vintage double that can go as low as 32 on the inside, you can look for a 50.4 bcd crank (TA is the most famous) (new chainrings are available on eBay) or an 86 bcd crank (Stronglight 99 is the most common but SR and other companies made a copy) (new chainrings are available from UK vendors like Spa cycles). Nervar 631 is a TA copy and you can pick one up for less than a TA. One good thing about Nervar is that you don't need a special chain puller. With an 86 bcd crank, you can go as low as 28 on the inside and with the TA (or TA copy) you can go as low as 26 if memory serves me right.
Phyllo-buster
Quoted: 2297 Post(s)
Liked 2,054 Times
I'd have no hesitation subbing in DX, LX, for the XT gear. Heck I've got a 200GS that I've ignored (beat up a bit?) on my winter bike for 4 years and it never misses a shift with thumbies. That early 90's generation of Deore/Exage 7 speeds RD's are super functional. Some are just heavier.
Liked 692 Times
You should put up a separate WTB for the 7 speed bar ends. You'll find them. Also you might want to put up a separate WTB for a shimano indexing long cage rear derailleur. The Deore XTs are pretty bombproof and index great.
2019 Salsa Warbird
2019 Salsa Warbird
Bikes: 1988 Ross Centaur, 2010 Fuji Connoisseur, 2015 Raleigh Tamland 1, 2017 Raleigh Carlton, 1987 Team Miyata, 2012 Soma Stanyan, 2015 Cinelli Supercorsa, 1984 Miyata 1000, [2009 Scattante SSR], [1988 Falcon Competitor 105], [2016 Soma Wolverine]
Quoted: 26 Post(s)
Liked 12 Times
Glad to know that I'm not the only one tackling that race in the vintage class!
Brand new carbon gravel bike - nah, I think the 35 year old Miyata with 35 year old brakes and shifters will do just nicely, thank you!
Likes For sallen73:
Liked 692 Times
Ha! Same. I convinced the wife to let me borrow her '86 Schwinn Voyageur. That might be the bike I wind up riding.
2019 Salsa Warbird
2019 Salsa Warbird
Liked 3,471 Times
Hah, this is out of Lincoln NE. This looks cool. A vintage class in the midwest is interesting. This would be a fun test for a 650b conversion. The bike only has to be pre 1988 . . . .
Likes For bikemig:
Quoted: 4510 Post(s)
Liked 6,377 Times
- crank ✓
- barend indexed (7s?) group
- 32h wheels
- toe strap pedals
- frame pump
- crank ✓
- 32h wheels
- toe strap pedals
- frame pump
Tough as nails, vintage as the day is long and one of the best values in cycling.
Liked 6,377 Times
Likes For merziac:
