Straight Handlebar length/cutting handlebar
Bikes: '88 Peugot 12 spd road bike, Nishiki hybrid, JC Penney 10 spd
Quoted: 61 Post(s)
Bought a new to me 2016 Specialized Sirrus of Craigslist and I really like it, but the handlebar is too long. My old Nishiki hybrid has a 23" or 584mm handlebar, this new bike has a 28" or 711mm handlebar. Was wondering is anyone has ever cut a handlebar and if so what is the procedure. I've cut PVc pipe but pretty sure that won't work. Or should I buy a shorter handlebar?
Thank you.
Felix
Thank you.
Felix
Quoted: 576 Post(s)
Liked 1,003 Times
For Al bars, a pipe cutter will work. For steel, Al, and carbon a hacksaw is best. A guide makes it easy and a file deburs the edges.
Measure twice, cut once
Quoted: 5 Post(s)
I cut about 1/2" off the ends of my handle bar. It made a world of difference in personal comfort.
It doesn't sound like much but you'll notice right away.
aka Phil Jungels
With steel and aluminum handlebars, a pipecutter works best.
Bikes: Giant Escape 1
Quoted: 136 Post(s)
I've cut handlebars and used a hacksaw. I didn't have a pipe cutter. To determine where I cut them, I placed my hands straight out meaning that the distance between my hands was the same width as my shoulders and my arms were parallel to each other rather than angling away from my body.
Quoted: 576 Post(s)
Liked 1,003 Times
Quoted: 136 Post(s)
You make a good point. Before cutting, move in your brakes and shifters and make sure there's room for a bike computer and maybe a light. If you can, move in your grips too. If you're not confident, cut off less on each end than you think you'll want. You can always cut off more but you can't add length back.
For The Fun of It
Bikes: Lynskey GR300, Lynskey Backroad, Litespeed T6, Lynskey MT29, Burley Duet
Quoted: 2135 Post(s)
Liked 1,647 Times
I've used a pipe cutter and a hacksaw. Either does the job perfectly.
Bikes: 2015 Trek FX 7.0 - modified to be better on the road than it was designed to be. Now, 2021 Domane.
Quoted: 23 Post(s)
Liked 10 Times
I didn't cut the bars. I move the shifters and brake levers in about an inch and a half.... moved the grips in accordingly, and set the bar ends at the ends of the grips, holding it all together. I have, then that empty bar sticking out, but since my mirror is out there, too, I'm not tempted to take a hacksaw to the bars. You might try something similar before getting out a saw. Just a thought.
Bikes: 80/90's Specialized Crossroads (3), '91 Miyata Triplecross, '91 Bianchi Boardwalk, 2002 Schwinn Frontier, 2002 Gary Fisher Tarpon, 2009 Trek FX 7.2, 2014 Motobecane 400 HT
Quoted: 9 Post(s)
I recently bought a Sunlite aluminum riser bar to replace the flat bar on my Miyata Triple Cross. I'd know for some time that I like my bars no wider than 24", and the Sunlite's was 27-1/2". So I carefully measured and taped the cutting mark, and to my surprise, after amputating the offending excess, the interior of the bar had suddenly become double the thickness! No grip plug or accessory would fit into the diminutive hollow, and the bars were thus rendered "un-returnable." It took a few dismayed moments to realize that cutting-down the grip plug's fins with a pair of sharp scissors would effectively rekindle their marriage.
Quoted: 5793 Post(s)
Liked 2,594 Times
I'm purely a hacksaw and file guy for cutting bars. It's an easy enough job, and there's no reason not to.
If you are a crappie sawyer, but two hose clamps. Put them on either side of the cut, and run the saw down the slot. Finished with a file to demurred and clean up the cut.
FB
Chain-L site
FB
Chain-L site
Bikes: '17 Trek FX3,'92 IBOC mtb, several old school BMX bikes
Not everyone is fortunate enough to have a machine shop outside their office door but I would just take care of the excess with an abrasive cutoff saw. I read the OP's posting and realize he knows for certain what length he wants his bars but to anyone else reading this thread I'd recommend assembling the bars as is and trying out a new setup as Ray mentioned earlier.
Liked 2,594 Times
IMO, hacksaws need a new press agent, they've become the Rodney Dangerfields of the tool world and don't get any respect.
FB
Chain-L site
FB
Chain-L site
I just cut my carbon bars. One end I used a hack saw(32tpi) and the other end I used a 2x72 grinder that I have. The grinder took it down to what I need precisely and clean in less than 20 seconds. If you have one, that’s the way to go, if not, hacksaw works great too. Make sure it’s for carbon or 32tpi.
Quoted: 23 Post(s)
Liked 10 Times
Cut my bars down a lot.
Hacksaw. Isn't hard. I used electrical tape as a wrap to guide the saw and bing bang, boom. Worked. Easy.
Thank you.
Felix
Thank you.
Felix
+1) Same tool in the Bike Shop that is a saw guide (for cutting threadless steering tubes), works on cleanly cutting ends of handlebars ..
Quoted: 576 Post(s)
Liked 1,003 Times
This is a nice cutting guide; it has an egg shaped hole to secure various sizes. Useful for steerers, bars, and seatposts.
