New rider...what is a good average speed?
Quoted: 192 Post(s)
Liked 11 Times
I just started riding...I am two rides in, both around 22 miles, so not particularly long. Averaging 19.8mph solo with roughly 1000ft of vertical (up and down given they are loops). Wind hasn't been a big factor on these rides and I've been able to keep moving without more than 1 or 2 stops at a light or something. I know there are no "typical" numbers, but trying to get a sense for how I'd keep up with a group of much more experienced riders...
19.8mph sounds like a good avg speed to me. I'm usually a bit slower than that, although in my area it's almost impossible to ride 20 miles with only 1000ft of elevation.
Not everything is speed though. When I'm doing a long ride, especially if it involves lots of climbing, I prefer to go slower and make sure I don't have to go through innecesary suffering at the end, I also tend to ride slower if I know I'm going to ride several days in a row.
Airplanes, bikes, beer.
Bikes: Road bikes, mountain bikes, a cx bike, a gravel bike…
Quoted: 398 Post(s)
Liked 788 Times
If this is your second bike ride ever and you’re averaging 19.8mph over 22 miles, it’s time to start thinking about a coach and a professional cycling career. Nice pace for a solo beginner.
Likes For AdkMtnMonster:
LBKA (formerly punkncat)
Quoted: 2208 Post(s)
Liked 960 Times
Please allow for some difference in advertised group speed and actual, particularly in light of what part of the season it is. Almost every group I have ever ridden with was faster than what they "grouped" and def. so late in the season. Make sure when you start looking for a group that it's a NO DROP ride with a sweep.
Riding in a group is easier on you for a couple of different reasons. Drafting is a big part of it...however I would mention to you to mention to the group that you are a NEW rider and will need practice off the back before trying to join a rotation.
Based on what you are saying I would look for a no drop B group to join, probably wouldn't consider more than a 20-25 mile loop to start with. Get teething over with and see where you stand.
Quoted: 167 Post(s)
Liked 291 Times
In my experience, I'd suggest if you can manage 20mph over 20 miles then you should be ok with weekend group rides. Only way to find out is to try. They are a lot of fun and different groups like different things - some will ride quite easily, not much effort, just out for the social. Others will want to rotate and draft for a decent average - certainly on the way back. Others will see the journey home as a mini-race.
Quoted: 1814 Post(s)
Liked 923 Times
That's as fast as the fastest group ride around here, with roughly the same climbing,
so you would either be leading a group of whippet-thin, high mileage hotheads,
or something about your numbers doesn't add up.
Likes For woodcraft:
Bikes: 2019 CAAD12, 2015 Specialized Sirrus Comp
Quoted: 562 Post(s)
Liked 64 Times
After riding for five years, completing four Centuries in the past year, participating in many club activities, and riding about 3x week, I'm finally able to maintain 20-21 mph, solo, on level ground. If you're getting 19.8 right out of the gate, including hill climbs, then either your an all-star athlete or you're mismeasuring your results.
Likes For Robert A:
Quoted: 192 Post(s)
Liked 11 Times
Appreciate the advice.
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
Anything over 25 is good. Over 28 looks better. But a great speed? Then you're looking at 30 plus.
Hammer group rides/races have little to do with average speed and everything to do with being able to go really, really hard and recover to do it again. Doesn't matter if you can average 23 on your own if you can't hold a wheel at 28 for a couple of minutes when needed.
Bikes: bikes
Liked 1,429 Times
Bolt. I have been doing indoor cycling for nearly 2 years and since October with a Peloton. My power output on that is pretty much double most of my friends on rides regardless of their size and I am only about 160lbs, so makes sense I'd be able to move at a decent clip on a real bike.
100 to 200?
200 to 400?
Quoted: 562 Post(s)
Liked 64 Times
Small sample set, but my two rides are almost exactly the same stats. One was Strava on my iphone and one was with my new Wahoo Elemnt Bolt. I have been doing indoor cycling for nearly 2 years and since October with a Peloton. My power output on that is pretty much double most of my friends on rides regardless of their size and I am only about 160lbs, so makes sense I'd be able to move at a decent clip on a real bike. Just a totally different experience outdoors.
Bikes: 2021 Canyon Endurace SL8, 2019 Cannondale Topstone Sora, 2002 Giant Yukon
Quoted: 34 Post(s)
Liked 148 Times
Quoted: 741 Post(s)
Liked 412 Times
Quoted: 741 Post(s)
Liked 412 Times
While he is fit, he has never ridden in a pack. He had a lot to learn before he is ready to ride the faster groups. There is much less tolerance for poor riding skill the faster things get.
Likes For colnago62:
Quoted: 167 Post(s)
Liked 291 Times
That should be ok for weekend group rides. Give it a go.
I'm 141lbs, 295 watts and max at around 1200 watts for a second or two in a sprint. I'm 51 so have slowed a bit and only started cycling properly again last June. On my Club rides I'm the strongest overall albeit not the best climber, rather the fastest sprinter, but there are Elite groups locally I would struggle to hang in with for very long. Really depends upon the group you join.
Quoted: 3958 Post(s)
Liked 7,312 Times
Joining a bike forum 8 years before getting on an indoor bike, and 10 years before riding a bike outdoors is some serious pre-planning. I admire that.
Likes For tomato coupe:
Expired Member
Quoted: 3683 Post(s)
Liked 5,448 Times
Good to keep a few user names in reserve
Likes For shelbyfv:
a loop with 2 lights and 6 stops
in the beginning of the season I average 30kph solo
at the end of the season 36kph solo
