Pepper spray mounting device?
Bikes: Subject to change at any given moment but currently is...... Colnago Mapei, Colnago C40, Wilier Triestina Carbon, Wilier Triestina Ramato, Follis 472, Peugeot PX60, Razesa, Orbea Terra, Soma Pescadero and 1/2 owner of a Santana tandem.
Quoted: 336 Post(s)
Liked 782 Times
Can anyone recommend a pepper spray mount for a bike? I currently wear one on an elastic Velcro strap around my arm but I’d rather have it mounted near the stem cap.
Likes For ScottCommutes:
Liked 2,981 Times
idk about you, but I'd not want something like that out in the open.
-Oh Hey!
-Oh Hey!
Likes For Troul:
Likes For 10 Wheels:
Bikes: two blacks, a blue and a white.
Quoted: 445 Post(s)
Liked 847 Times
I agree that when you need it, you really need it. That said, I don't need it that often. Same reason I removed the machine gun mount - only fired it like eight times.
Likes For blacknbluebikes:
Quoted: 2497 Post(s)
Liked 741 Times
Bingo. This is the chief fail with the deployment strategy of another popular American weapon. Until there is a way to implant offensive weapons, they really cannot be considered truly effective defensive weapons. Pepper Spray was invented as an offensive weapon to subdue already outmaneuvered prison or arrest subjects. It doesn't even make that great a defense against dogs or bears.
Likes For JW Fas:
Clark W. Griswold
Quoted: 4361 Post(s)
Liked 4,005 Times
If you are planning on using something like OC/Pepper spray make sure you know how to use it well as well as under stress. Beyond that it is pretty useless, as you could easily do more harm to yourself than any good towards the human you think you are stopping. However keep in mind in some of those situations where you think pepper spray might be the right use case could end up with a heavy escalation with someone who has actual firearms and that can be quite deadly. The best method is to deescalate or exfil from the area quickly
If you are going to carry it and have considered the above then I would keep it probably exactly where it is. You want it quick access not something you are fumbling for. However if you do move it than make sure you have more practice with the new location and can easily and quickly access it if you really must use it.
Likes For veganbikes:
Quoted: 626 Post(s)
Liked 401 Times
Why Do You feel the need for pepper spray?
I prefer the best of the best for dependability. I have the economy 14oz can and have it in a sleeve which makes it compatible with a standard bicycle water bottle cage.
Quoted: 823 Post(s)
Liked 1,962 Times
When I started carrying pepper gel after a confrontation with a very aggressive Rottweiler, I just packed it in my dominant hand rear jersey pocket.
It stayed put and I only had to remove it once thereafter but the dog was just yapping and not that aggressive like the Rott.
I am potato.
Quoted: 1790 Post(s)
Liked 1,631 Times
While on the bus I had my bike parked on one of the interior bike racks in the back with the hooligans and fentanyl smokers. I noticed a guy scoping out my bike; Positioning himself so that he could make a well timed snatch and dart out the door. He knew it was mine because he was watching me. So, I did the best thing I could do under the circumstances. I made it conspicuous that I was watching him too and took my can of bear spray out of my backpack strap mounted holster and held it in my hand. The other junkies pretended not no notice. It was deterrent enough. He got off at the next stop backing off the bus, watching me.
Good.
The lesson here is you don't need to use a thing, just be obvious you have it. People don't know bike things. But, people know people. On your sleeve is probably as obvious/optimal as you could get.
Good.
Car dependency is a tax.
Liked 741 Times
Good.
Good.
Quoted: 336 Post(s)
Liked 782 Times
Proper deployment of an offensive weapon. Your Pepper Gel would have been useless after you were knocked unconscious by an unseen junkie (unseen because you were occupied with the primary threat). O.p. is trying to make a case for using Pepper Spray as an effective defense strategy.
OP is doing no such thing. I asked a simple and direct question concerning a mount and received ONE answer to my question followed by far too many opinions on everything surrounding the topic, except my question.
Likes For Tomm Willians:
Quoted: 626 Post(s)
Liked 401 Times
I am potato.
Liked 1,631 Times
Defensive is approximately synonymous with "deterrent." Which it plainly says says on the can. It is a defensive tool. I used it to effectively deter an animal. End of story. Going into the lay out of the bus and drawing football/soccer a map of all person's and their positions is moot. When the animal did a threat assessment and departed the situation, the tool went back in the holster. It's very presence was enough to be effective.
My point in regaling the story is when it is plainly visible and identifiable it functions properly as a deterrent and that is where it's use is most effective. The OP should should use it on his arm strap, his belt, on his back pack shoulder strap etc...not on a bike top tube. When he actually needs it, on his person is better than on the bike that will have most certainly separated itself from the owner in the event of an incident with any wildlife be it 2 legged or 4. My vote is against a bike mount at all.
Liked 741 Times
I guess you are now going to tell us you didn't know your "simple and direct question" was potentially triggering. Sigh. I hope the ONE answer you received helps.
