How do I remove the headset?
Bikes: The Grocery Getter.
Quoted: 39 Post(s)
Looks like friction fit (if that’s the correct term) and Sheldon Brown says I can tap it out but it’s pretty tight and I don’t want to break anything.
Any tips? Or just tap?
Quoted: 4407 Post(s)
Liked 1,560 Times
You tap it out. I use the edge of a copper pipe, but nearly anything will work. It is an press fit, so it is going to take a few sharp wacks. Alternate sides as you go.
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
Less chance of damage to the lugged steel frame than an aluminum frame. You working on the blue frame?
I got a headset cup removal tool to remove cups from a steel frame a couple of years ago and it did the job.
Like this but a cheaper brand. https://www.jensonusa.com/Park-Tool-RT-1-Headset-Cup-Remover-Park-Tool-RT-1-Headset-Cup-Remover?pt_source=googleads&pt_medium=cpc&pt_campaign=shopping_us&pt_keyword=&gclid=Cj0KCQjwpcLZBRCn ARIsAMPBgF20I9YhNimMzUVZ4gW6Rfd9W372hFtGmcPZnEDZ04-QSmt9slsaBiQaAlbnEALw_wcB
Bikes: 84 John Howard, 85 Raleigh Kodiak, 84 Ross Mt whitney, 74 Masi, 82 Allez
Quoted: 40 Post(s)
Liked 7 Times
I use a 3/4" wood dowel that works fine and wont damage anything. Just keep working it back and forth. The key is having the frame stable.
Quoted: 39 Post(s)
I got a headset cup removal tool last to remove cups from a steel frame a couple of years ago and it did the job.
Like this but a cheaper brand. https://www.jensonusa.com/Park-Tool-...QaAlbnEALw_wcB
Quoted: 2432 Post(s)
Liked 638 Times
You can buy a 10 foot piece of 3/4 inch electrical conduit at Lowes and make your own for less than $10. That's what I did. I don't think the guy in the video did this, but I also put in a spare bar end plug on the side that I hammer. It fits perfect.
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Headset Cup Remover.
Less than $20 if you shop around.
SE Wis
Quoted: 2747 Post(s)
Liked 3,395 Times
If you know any carpenter or electrician you can probably get a short cutoff for free that would be tossed anyway.
Liked 1,560 Times
That's a lot of work for no real benefit. Either buy the tool, or just use something simple. You don't need a splined tool to safely and easily knock a cup out.
Bikes: 89 Paramount OS 84 Fuji Touring Series III New! 2013 Focus Izalco Ergoride
Quoted: 285 Post(s)
Liked 74 Times
scott s.
Kids these days...
before the internet outsourced problem solving .. removing initiative to think things thru logically.. for one's self..
I used a long screwdriver and lightly tapped it out going around the Insert edge from the inside out..
Quoted: 4806 Post(s)
Liked 3,928 Times
Ben
In the past I've used a screw driver, brass drift, steel rod, wood dowel, PVC pipe, copper pipe(with and without an end cap), a home made headset removal tool made out of copper pipe, and an official Park Headset Removal Tool.
The removal tool is the easiest to use, and you can hit it hard enough to get out the most stubborn cups with ease.
For the other methods, where you can only hit one side of the cup at a time, tap, tap, tap gently, working around the cup. It takes a little longer, but be as gentle and even as possible.
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
Quoted: 1572 Post(s)
Liked 643 Times
+1 I've tapped out more than a few with old screwdrivers. Take your time and it isn't a big deal. Recently I treated myself to the Park remover. The press was a lot more than I wanted to spend so I went to Home Depot and bought 1/2" threaded rod, washers and nuts. Some pipe to act as a guide. $15?
Ben
Ben
That's me too. I used to have a crummy screwdriver that I reserved for doing jobs like that. Never damaged anything that I'm aware of. The "right" tool is definitely faster and easier.
And I chuckle when I think about how I used to compress the little fingers to slide the tool into the head tube. It's so much faster and easier to just slide it up from the wrong end.
