Lance Armstrong shows to to change a tire in 1,5 minutes.
#76
Sophomore Member
Quoted: 1628 Post(s)
Liked 1,057 Times
If if puts the amount of effort he put into his seven tour wins, into rehabilitating his public image, he will succeed at that as well. This video is a small step toward that goal, and I think it's quite effective at re-humanizing him to the public. I could easily see the guy running for elected office some day, and with his competitive drive I think he'd absolutely crush most lower tier garden-variety politicians.
EDIT: Looks like we have less time to edit our posts now, before the "edited by" flag comes up. Dang!
#77
6-4 Titanium
Quoted: 92 Post(s)
Liked 36 Times
#78
Bikes: 1984 Fuji Club, Suntour ARX; 2013 Lynskey Peloton, mostly 105 with Ultegra rear derailleur, Enve 2.0 fork; 2020 Masi Giramondo 700c, full Deore with TRP dual piston mech disk brakes
Quoted: 324 Post(s)
Liked 81 Times
#79
climber has-been
Quoted: 3428 Post(s)
Liked 3,566 Times
#80
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
That's what belt sanders and bench grinders are for.
#81
Quoted: 1528 Post(s)
Liked 718 Times
Pff, lawyer lips. Being owned by me is a death sentence for them.
#82
Quoted: 550 Post(s)
Liked 325 Times
Tube failure where the valve stem connects is likely when you leave the nuts off. Without them the valve stem moves when you attach and remove the pump, causing the rubber to fatigue and eventually leak.
#83
just another gosling
Quoted: 3889 Post(s)
Liked 1,938 Times
I know a cyclist who isn't a perfect human being, ground his lawyer tabs, bunny hopped, and was off the bike for almost a year. Forgot his QR. Very experienced rider, tour leader, etc.
Results matter
Results matter
#84
Liked 1,938 Times
I once had a tire go flat due to valve leakage. Caps keep the dirt out. I also like colored ones. Easier to find when changing a flat.
I'd like to see Lance with a modern rim, one of those "ready for tubeless" jobbies. Last rim I bought wasn't even advertised as such, but oh boy. My thumbs took a couple days to recover, blisters even. Used tire, too.
Carry a spare tire, never lose time looking for the cause. Bikes go pretty far in 5 minutes.
Road Morph G - never have a friend rip your valve out again.
Results matter
Results matter
#85
Liked 718 Times
I've seen plenty of tube failures at the edge of that stiff part due to the tube ballooning into the tyre bed, but maybe only one or two of the sort you describe. I'm not likely to wear out the base of a valve myself, since I use fittings that thread on rather than push on.
Also, valve nuts look like arse on anything but a box section rim, unless maybe you pinch the profiled spacers from some tubeless valves.
#86
climber has-been
Liked 3,566 Times
Worse than useless, when you have a puncture on the roadside and the stupid nut won't come off.
#87
Quoted: 550 Post(s)
Liked 325 Times
Rubber fatigues.
FACTORS THAT AFFECT THE FATIGUE LIFE OF RUBBER: A LITERATURE SURVEY as published in Journal of Rubber Chemistry and Technology
https://pdfs.semanticscholar.org/c36...594c131968.pdf
In this case, it could also have been abrasion but didn't look like it.
That's what I suspected, so I left them off when they didn't look good on a new set of wheels I built with Velocity Fusion rims narrowing to a thinner edge aerodynamic edge than the classic Open Pro / Reflex clincher / MA40 box section rims I'd been riding for years.
The Continental Race 28 tubes failed within a couple of weeks of each other where the stems attached which I'd never seen since getting a bike with Presta valves.
With nuts, the following tubes from the same batch had no problems and everything has been fine for over 20,000 miles.
The connection was clear although I don't know what the other causal factors are - tube brand/model, tire volume, rim bed shape, rim depth, hole clearance, pump chuck weight, pump hose weight, how much the chuck moved when clamping it on.....
Conversely, I've never had a nut get stuck, just come loose and rattle annoyingly until tightened.
Your mileage may vary.
Those lock nuts are useless.
#88
climber has-been
Liked 3,566 Times
[QUOTE=Drew Eckhardt;21079001]
Let me rephrase: rubber in a bicycle tube will not fail from fatigue in normal use. It's not stress cycled enough. It is possible, however, that a tube will fail at the valve stem from abrasion by a rim that has too large a hole—or a hole that hasn't been adequately de-burred and chamfered.
A stuck nut can happen when you finger-tighten it down after inflation, possibly in the hope that it won't rattle, then a puncture occurs.
The one positive feature of a valve nut is to keep the valve stem from disappearing into the rim when a pump head is pushed onto it. I've never found this to be a useful feature.
#89
Ironically, valve nuts most useful on Schrader valves since they require more force to get a quick-release pump chuck to seat, but most Schrader stems aren't threaded at the base and therefore can't use the nuts.
#90
Rhapsodic Laviathan
Thought that was Bruce Willis...
#91
Rhapsodic Laviathan
