Stem length suggestion
Quoted: 13 Post(s)
Hi,
At beginning few numbers:
My height: 174 cm/ 5,85'
Inseam: 82 cm
Effective Top Tube: 545 mm
Reach: 382 mm
Head Tube: 125 mm + 20 mm Spacers
Handlebar: 42 cm; 75 Reach; 128 Drop
Stem: 90 mm; -10
After this season I will probably remove another 10 or 15 mm of spacers and change handlebar to 40 cm ( same model as current one but narrower)
Problem is that I think my stem is little bit too short. On corners I can feel that bike is too "nervous" and steering is too fast.
I am thinking about changing stem to 100 or 110 mm but I do not know which one will be better. I know it is very individual case, but I need your suggestions which one I should choose. I do not have time ( and stems) to try them in practice. I will change to new one after season.
After removing spacers, "effective reach" will change about 5 mm. I am thinking about 110 mm stem, but in this situation, whole reach will increase about 25 mm ( current stem has 90 mm + 5 mm after removing spacers). It sounds like quite big change, but I am afraid that 100 mm stem will not change steering as much as I want.
I like very agressive and low position. Currently in my "natural" position on hoods my elbows are bent quite significantly, and I can see Hub in about 10- 15 mm in front of my Bar.
My rides are not longer than 100 km, mainly about 50- 80 km, so about 3 to 4h.
What do you think? What stem length do you have on your bike?
Inseam: 82 cm
Reach: 382 mm
Stem: 90 mm; -10
Expired Member
Quoted: 3674 Post(s)
Liked 5,437 Times
A road bike that fits will have 90mm at the short extreme, 110mm at the long extreme. Since it's a WAG why not try the 100mm "right in the middle?" And yes, there are freaks of nature and ill fitting bikes and other "special" circumstances that lead to usage of stems outside this range.
Quoted: 1067 Post(s)
Liked 259 Times
More like 100-120 as normal with 90 and 130 getting a bit short/long but still ok.
Likes For Dean V:
Quoted: 20810 Post(s)
Liked 9,456 Times
It's quite common for shops to have a number of stems, in varying lengths, just hanging around, waiting to be tried on for size. Why not visit or call some shops in the area and take advantage of them?
Quoted: 741 Post(s)
Liked 412 Times
Something to consider; going to a bar that is narrower than your current set up will raise tour position on the bike. Bringing the bar to get a similar position to what you currently are riding might require a longer stem and lowering the bar.
Bikes: Garmin/Tacx Bike Smart
Quoted: 646 Post(s)
Liked 289 Times
Don't guess, get a fitting done. I rode a Trek Madone for five years with a really short stem, but it fit.
Sophomore Member
Quoted: 1628 Post(s)
Liked 1,059 Times
Hi,
Inseam: 82 cm
Reach: 382 mm
Stem: 90 mm; -10
Inseam: 82 cm
Reach: 382 mm
Stem: 90 mm; -10
As I've worked on flattening out my back in the drops, the bar tops on all of my road bikes extend well beyond the front axles of my various bikes.
So yeah, I would go with the 110 and see how you like it. Might take a week or so to adjust. I'm, 5-10" and run 120's and 130's on all my bikes. I find short stems extremely irritating.
Definitely try out more than one new length. My bike (55cm Orca) came with a 100mm or 110mm stem, can't recall exactly. The reach was too short as the frame is a tad undersized for me, so I stuck a 130mm -6 degree stem on there (it actually measures closer to 125mm). The handling improved immediately and I was more comfortable. In search of a lower and longer position, I recently put a 140mm -17 stem on it to see how far I could go. The angle caused the saddle-to-bar drop to increase even more than the reach did. So far I like it, but I may try to fine tune it once more with something like a 130mm -10 stem. It's not quite goldilocks yet.
My point is that even small changes in your cockpit can have a noticeable impact, so don't settle for "close enough." Also take my words with a grain of salt as I am taller (185cm) and prefer longer stems than most riders.
Quoted: 18883 Post(s)
Liked 10,646 Times
I'm on a 90 for fit reasons but also because I like quick handling.
Expired Member
Liked 5,437 Times
No question that outlier stem sizes can help make an incorrectly sized frame more usable. Hopefully OP has a frame that is correctly sized for him!
Advocatus Diaboli
Quoted: 4736 Post(s)
Liked 1,532 Times
If it were me.. I'd remove half the spacers you're considering removing, get a 100mm stem, and not sure about going to a narrower handlebar as that seems would work counter to you already thinking the handling is twitchy.
throw in another option.. try a fork with less rake? eg. if you have 45mm, try 43mm?
The reach of your frame is a little short for your height and inseam. The head tube is also on the short side. Adding 20mm of spacer further shortens the reach. I'd expect at least a 110mm stem, but handlebar reach and choice of brake/shift levers also makes a difference.
I'm 167cm tall with the same 83cm inseam. With that HT length, I have 10mm of spacer and use a 110mm, -17 degree stem. I also use short reach bars and Campy 12 speed that has the shortest reach brake hoods.
Jet Jockey
I’m certain this is apocryphal, but I read somewhere on the interwebz that Eddy Merckx said that a properly designed/fit bike should have a 110mm stem.
Of my two primary bikes, one has a 90mm, one has 110. Both fit and ride just right.
My 55cm frame isn't incorrectly sized for me per se, it's just that I'm in between sizes. The 57cm would be too big for me. You can't fix a too-big frame, but you can make accommodations (as mentioned, many pros do) for a smaller frame.
pan y agua
Quoted: 1447 Post(s)
Liked 727 Times
pan y agua
Liked 727 Times
To paraphrase Abraham Lincoln, a man’s legs should be long enough to reach the ground.
A rider’s stem should be long enough to balance that rider on the bike.
whether that’s 80 mm or 140 mm or in between depends on the frame and the rider.
beyond that, opining about the corrrect length of the OP’s stem is nonsense
Likes For merlinextraligh:
Quoted: 65 Post(s)
Liked 60 Times
This was true when people rode custom built steel bikes and Mike Burrows hasn't introduce the world to slopping top tubes and cutting number of available frames sizes in half.
Quoted: 1743 Post(s)
Liked 1,281 Times
My height and inseam are almost exactly like yours. FWIW, I am 73 years old. I have two road bikes that fit me perfectly. They are both a measured 54 frame w/54-55 TT and I use a 100mm stem. My saddle height, as measured from saddle to center of pedal axle is 92 cm. I find this very comfortable and I seem to ride efficiently and smoothly.
