Trek compact only
Trek compact only
Old 08-13-19, 09:27 AM
popeye
Bikes: S works Tarmac, Felt TK2 track
Quoted: 359 Post(s)
Liked 179 Times in 111 Posts
Trek compact only
2020 Treks all compact crank. I wonder how many are rim brakes?
Says the guy running DA DI2 53/39 12/25 rim.
popeye is offline
Old 08-13-19, 09:32 AM
Seattle Forrest
Seattle Forrest's Avatar
Quoted: 18883 Post(s)
Liked 10,646 Times in 6,054 Posts
The world changed. Old bikes still work though.
Seattle Forrest is offline
Likes For Seattle Forrest:
Old 08-13-19, 11:01 AM
WhyFi
WhyFi's Avatar
Quoted: 20810 Post(s)
Damn it! Now I'm not going to be able to sleep at night - the horror!!!
WhyFi is offline
MinnMan
MinnMan's Avatar
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4387 Post(s)
Liked 3,016 Times in 1,865 Posts
I like my 53/39 and if I were shopping for a new bike, I'd be disappointed if only 50/34 combos were available. OTOH, SRAM now has a 10 tooth cog on its 12 speed cassette....
MinnMan is offline
Old 08-13-19, 11:48 AM
tony2v
tony2v's Avatar
Bikes: 1975 Albert Eisentraut, 1992 Bill Davidson, 2006 Moots Compact, 2007 KHS Solo-One, 2010 Van Dessel Drag Strip Courage, 2013 Alchemy Xanthus, 2016 Breadwinner Lolo, 2018 Moots VaMoots RSL, 2019 Chapter2 Tere Disc, 2020 Chapter2 Ao Limited Edition
Quoted: 31 Post(s)
Liked 32 Times in 16 Posts
Except the SRAM RED AXS cranksets are 46/33, 48/35 and 50/37.
tony2v is offline
Old 08-13-19, 12:51 PM
FlashBazbo
Chases Dogs for Sport
FlashBazbo's Avatar
Quoted: 983 Post(s)
Liked 141 Times in 94 Posts
I guess they figure they'll have the wrong spec for a certain percentage of buyers anyway. This probably ticks off the smallest number of potential customers. If the customers want compact, give them compact. (And if they want 52/36 or 53/39, they know how to solve the problem.)
FlashBazbo is offline
Likes For FlashBazbo:
Old 08-13-19, 01:34 PM
TimothyH
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times in 469 Posts
Especially since Trek is the only bike manufacturer on the planet.
-Tim-
TimothyH is offline
Old 08-13-19, 02:14 PM
rosefarts
With a mighty wind
Quoted: 1087 Post(s)
Liked 862 Times in 490 Posts
I remember grinding up Mt Evans, The Tour de Gila, Tour of Utah, etc 53/39 and 11-25 on steep days and 11-23 most days. I even thought I was "spinning". Turns out I was just young and strong.
I ride 50/34 x 12-30 now. I'm slower but it's not because of the bike. I really would like to take the gears I've got now and apply to the fitness I had at 25.
Yes, I'd regularly hit 50's. I think the most I recorded was 58. Pretty sure I wasn't pedaling any of those times.
Trek aren't dummies. How many top pro's are riding sustained speeds where 50x11 just doesn't cut it?
rosefarts is offline
Old 08-13-19, 09:08 PM
Kimmo
Kimmo's Avatar
Quoted: 1528 Post(s)
Liked 718 Times in 510 Posts
The reason I hate compacts isn't about top speed... a 34 or 36 runs out right in the middle of typical cruising speed, which is just dumb. And the smaller the ring, the bigger the gaps between gears, not to mention higher drivetrain friction.
Kimmo is offline
Old 08-13-19, 09:28 PM
noodle soup
noodle soup's Avatar
Quoted: 4717 Post(s)
Liked 1,882 Times in 998 Posts
34x14 is good for about 20mph. If I need more speed than that, it really isn't much of a climb.
noodle soup is offline
Old 08-13-19, 09:31 PM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3871 Post(s)
Liked 2,568 Times in 1,579 Posts
Why would you try to cruise in the small ring anyway?
Originally Posted by chandltp
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Likes For ThermionicScott:
Old 08-13-19, 10:38 PM
Dean V
Quoted: 1067 Post(s)
Liked 259 Times in 153 Posts
Exactly
With rear cassettes typically having a 28 or larger you can cruise on the big ring around the middle of the cassette. In fact you can virtually treat it as a 1x11 and just drop it down to the small ring when you get to a proper hill.
I like the 50/34 set up.
Dean V is offline
Likes For Dean V:
Old 08-13-19, 10:44 PM
HTupolev
Quoted: 1974 Post(s)
Liked 1,298 Times in 630 Posts
Right, which is why Trek's bikes should really come stock with 44-28 subcompacts.
HTupolev is online now
Old 08-13-19, 11:05 PM
Kimmo
Kimmo's Avatar
In street clothes, a 39 is good for everything except downhill and tailwinds.
Kimmo is offline
Old 08-13-19, 11:09 PM
ThermionicScott
Yeah, that works with a standard, where you hang out on the small ring at low speeds until you're going fast enough to shift up.
You have to think differently with a compact. I use mine exactly like @Dean V -- stay on the big ring preferentially, shift down to the small ring (practically a granny) only when you need to climb a steep or long hill.
RUSA #7498
Old 08-13-19, 11:12 PM
Kimmo
Kimmo's Avatar
I'm still waiting for someone at Shimano to catch onto my 38/50/52 idea for electronic...
Kimmo is offline
Old 08-14-19, 12:29 AM
colnago62
Quoted: 741 Post(s)
Liked 412 Times in 230 Posts
Does that include P-1 builds also? I know you can get rim brake Madones in a frame set.
colnago62 is offline
Old 08-14-19, 03:50 AM
waters60
waters60's Avatar
Quoted: 203 Post(s)
Liked 108 Times in 63 Posts
Just looking at recent mountain stages of the Tour it was obvious that they are using lower gears as their cadence is much higher than the days of Jan Ulrich grinding his way.
waters60 is offline
Old 08-14-19, 09:00 AM
FlashBazbo
FlashBazbo's Avatar
Quoted: 983 Post(s)
Maybe, but these days, they don't eat as many donuts as Jan did.
Old 08-14-19, 09:38 AM
seypat
Quoted: 3241 Post(s)
Liked 2,512 Times in 1,510 Posts
Plenty of Shimano 11 speed cranksets on Ebay in various sizes and combos. Get a backup and rotate them as you see fit.
seypat is offline
Old 08-14-19, 02:13 PM
TimothyH
- Soli Deo Gloria -
Weird days when roadies gush over a bike because it fits 38 mm tires, claim that 30 mm wide rims are the "Sweet spot" and one of the biggest bike manufacturers on the planet doesn't even offer a full sized crankset on their top of the line road bikes.
I guess gravel is the new road.
-Tim-
TimothyH is offline
Likes For TimothyH:
Old 08-14-19, 02:34 PM
seypat
-Tim-
Even funnier is back in the day, that is what the standard sport tourer from said companies was. You want a gravel bike, get you a French bike from the 60s/70s or before. They knew how to make bikes for crappy roads.
seypat is offline
Old 08-14-19, 03:10 PM
Dean V
-Tim-
Definitely some weirdness there but I wouldn't say compact cranks was one of them. Your so called "standard" crankset was really just a blip the time line as well.
54/42 was common too. 52/39 as well. Plus others. Usually coupled with a rear cassette that didn't get smaller than 14 or 13t.
Dean V is offline
Old 08-14-19, 03:30 PM
Seattle Forrest
-Tim-
Gravel is a subset of road. I mean we're talking about gravel roads, and drop bar bikes.
dvdslw
Road Cycling
16
03-25-16 05:51 AM
rpeterson
Road Cycling
34
06-18-14 12:33 PM
Frankfast
Road Cycling
17
05-29-13 10:59 AM
