Very tight pedal clips
Bikes: I have a few
Quoted: 340 Post(s)
Liked 210 Times
I put my Eroica bike back on the trainer and installed the pedals I am going to use. When I tried it out the shoe cleats were having a very hard time seating all the way on the pedal. I thought about making the slot wider but Is it normal to open the gap to allow them to fit better? Also the way there are now there would be ZERO float and I am sure that would kill my knees.
Industry guy
There are clipless pedal cleats that look very similar, but are different.
Wellgo and Shimano are good examples.
The ramps and flat areas are different enough that they do no interchange, while visually, they are very close
- including the color in some cases.
This in both the metal and plastic versions.
If you do manage to get the similar types to engage, it might be very difficult to get them to dis-engage.
Bikes: I have a few
Quoted: 340 Post(s)
Liked 210 Times
Quoted: 1324 Post(s)
Liked 927 Times
Cheers
Likes For Miele Man:
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
BITD, "float" was provided by filing the cleat slot into a narrow hourglass shape: )(
Likes For JohnDThompson:
Quoted: 556 Post(s)
Liked 132 Times
BTW, OP...one other possible solution is a thin spacer between the pedal and the toe clip where it mounts.
I've use 1/8 aluminum flat stock before. Drill two holes in each spacer...bingo.
I don't see any big reason not to open the slots up a bit. I've never done it, nor do I know of anyone who has. Perhaps someone on the forum has done it.
Edit: oh yeah, the hourglass thing. I've heard of that before but don't remember anyone doing it. That would be the smart way.
Regardless, I suggest starting by getting them positioned as well as possible before you do any filing open. If they are the later 70s/80s type with adjustable plastic cleats, bring an allen wrench with you on a ride and tweak the angle until it feels just right.
Bikes: I have a few
Quoted: 340 Post(s)
Liked 210 Times
Are you talking about traditional slotted cleats for quill pedals? Yeah, they are zero float. Float wasn't really a thing. That's why they were aligned very carefully.
Yes they are quill pedals and slotted cleats. The biggest reason for this is that I am quite sure on a couple hills I will be walking and at the moment where riding forward is not an option I do not want to be stuck in the pedals. I have a bum knee and a little float is a must, as well as the ball of my foot ahead of the pedal axle. That being said, I will go with the advice and ride it on the trainer for a while and dial in the position. With any luck the cleat will loosen up on its own.
Quoted: 3464 Post(s)
Liked 2,831 Times
open up the slot. not mentioned was if pedal has an aluminum quill or plates- they are often (almost always) thicker than steel pedals.
JohnDthompson is correct, another option back in the day, there was a "fit kit" pedal system long ago to monitor your pedal stroke, good for setting cleats.
Some riders swing their knee in and out as they pedal- not good. one really has to have another video you pedaling on the bike to show this.
I see it often on the road and when I meet up with the rider I ask how their knee pain is. "How did you know?"
Liked 927 Times
Cheers
Quoted: 930 Post(s)
Liked 1,293 Times
The obvious solution, and the one I use, is to not use cleats. BITD, I used cleats for racing and most local riding (but never for touring). However, it's subsequently been proven through research that being cleated in does not improve performance overall (though it can be helpful on very steep uphills). Also, it can lead to knee problems if cleats are not adjusted and makes it very difficult to walk your bike on Eroica-style hills. I gave up cleats a long time ago and have never observed a down side. The only reason I can see for using them is to stay authentic to the past (though who is going to notice whether or not you have cleats nailed to the bottoms of your shoes?).
While I'm not convinced that it's been proven the cleats don't improve performance - that's another discussion, I think @davester makes a very good point. If you've got knee issues and you know you'll be walking, why not get some non cleated touring shoes? Walking in cleated racing shoes was always a pain. There's a fair amount of choice in traditional looking touring shoes these days. If you search for some recent threads you'll find suggestions.
Edumacator
Quoted: 2440 Post(s)
Liked 3,130 Times
My two cents...
1) It might be they are not seating because your toes are stopping before it is fully in place. Add a really thin washer to each of the bolts behind the clip (between clip and the plate).
2) If it is aligned and not able to move down because of the thickness of the slot-- versus the cage-plate, then file the cleat from the sides as evenly as possible as suggested above. Modern replacement cleats are hard to find and not built to days of yore specifications...
Edumacator
Liked 3,130 Times
Quoted: 741 Post(s)
Liked 818 Times
I used plastic cleats on my first Eroica ride. I think it was 2016, a drizzly day with lots of muddy trails. I stopped and used a screw driver to clean the cleats several times, because they would not engage. Twice, I fell on the same knee (still hurts) when they wouldn't disengage, even with loose straps. Conversely, on a washboard, dirt section, my feet actually came out of the pedals, even with cleats and straps. BITD, I used to race with metal cleats, straps and clips, but our races never included repeated stops and starts, walking or riding on mud or gravel. I did spend some time filing the plastic cleat slot into a bit of a "V" by beveling the sharp edges of the slot, but couldn't tell much difference. I tried half clips from VO, and even ugly black plastic mtn bike type toe clips. The shoes I was using are Vittoria 1976, with three hole cleat mounts, and very slick soles, not good for walking. Unless you are some kind of Superman, you Will be walking at some point. I now use Louis Garneau Nickel SPD shoes, where the cleat location is recessed, giving a flat, rubberized sole, good for walking, and not bad for pedaling with toe clips and straps. I have considered going to a shoe shop and having ribbed rubber soles put on the Vittorias, but so far the LG Nickels are working (without cleats). On an all pavement club ride today, 40 miles, with a couple of nasty, steep, but shortish hills, I had 4 Strava PRs and a 16 mph average. I even had one best PR segment over a bunch of pretty good riders on modern carbon, with "real" pedals, so I guess this setup is working, even with a 70 year old rider. Good luck with your cleats, but they just didn't work for me.
My current set-up, with washers between pedal and toe clip to get more toe room.
The Vittorias I started with
The LG Nickels, not as pretty as the Vittorias, but work for SPDs 11 months a year, and dreaded toe clips and straps 1 month a year for Eroica. They are half the cost of Vittoria, but infinitely more useful.
Quoted: 4806 Post(s)
Liked 3,931 Times
daviddavieboy, I've been riding traditional cleats and pedals a long time and have strong preferences for certain materials. Aluminum cleats and chromed steel rattrap pedals. Also quality leather straps. I have done a lot of my traditional setup riding on fix gears and often in hills. There is a really simple test for the quality of the setup. Ow steep a hill can I get up without either pulling my foot out or injuring my foot. Pulling too hard on the straps feels like am going to break the bones in my foot.
Aluminum cleats and chromed steel rattraps are sweet. The chromed plate slides easily into the cleat slot (assuming the slot is wide enough; virtually all are, even new - unlike the wider aluminum rattraps). Being dissimilar metals, they tend to bind when force is applied. This means you do not have to pull the straps all that tight to keep your feet in place, even pulling quite hard. (NOT TRUE of any of the plastic pedals I've used.) Quality leather tends to hold shoes with friction, not just tension, so you do not need to pull them as tight. I also find them far kinder to my feet when I am doing long out of the saddle fix gear climbs. Another plus of the aluminum and chrome combo - the rattraps last forever and stay good looking quite a ling time. The cleats last far longer than plastic ones (and are far more forgiving- wear wise - than plastic). If y9o9ur pedals have aluminum rattraps and are detachable, see if you can find chromed steel relacements. Set the aluminum ones aside to maybe sell later (to someone who killed his).
A really good aluminum cleat that is easy to find is the Exustar track cleat, ~$20. (Skip the $80 ones. They are for the veloddrome sprinters and have no place on the road.) The Exustars use the 3-bolt LOOK pattern so you have the choice of any modern road shoe. (I just saw that Lake now offers a laced cheap shoe. ~$80! I love the Lake shoes; the fit and they last nearly forever for me. Hate straps in general and have been taking them off my Lake and installing laces. Now they do it for me!)
Oh, the straps - I buy Zephal toeclips for their good buckles. Go to a local leather shop and have them cut me 1/2" leather strapping from quality hide. (Tell them 1/2" or a touch less.) Attach the straps with pop rivets. These straps do not last as long as the harder leather in say a Binda strap, but they are far cheaper and for about half the life of a Binda, they are excellent. ($15 gets me the Zephals. A dollar gets me plenty of rivets. 5 feet of strapping is I think about $6. And the Zephal buckles will outlast a half dozen straps.
Ben
Ben
Quoted: 741 Post(s)
Liked 818 Times
Looks like those fit well on a NR pedal. Do you mind my asking what size they are? I bought some 510 cycling shoes in size 9 and they are wider than the pedal reminding why they are quill pedals. Then some 30 yo Avocets in 9 and they are right for length and fit on the pedal but narrow on my feet but might work out depending on how they change to accomodate my feet -- they seem to be pretty flexible, so might work.
The LG Nickels are Euro 47s (US 11) as are the Vittorias. I had to space the clips forward with a few washers to get toe room in the clips. There might be larger clips available, but these were on sale at the Performance close out sale, and I only use them once a year.
edit: and spacing the toe clips forward, I never would have thought of that. I'd just bend them and hope the didn't break.
Bikes: Indeed!
Quoted: 1507 Post(s)
Liked 3,478 Times
Do you know more? I'm curious whether the swinging knee is the cause or the symptom. In other words does the swinging knee cause the pain?
or
Do people swing their knees to lessen the pain?
or
Are both the pain and the swinging knee symptoms of another problem? i.e. bad saddle position, restricted hip joint, weak or damaged knee joint, etc.
Thanks,
Brent
Quoted: 930 Post(s)
Liked 1,293 Times
Edit: I just found them on amazon as "pedal extenders". Apparently they're quite common. Think I might get some since the quill always digs into my foot.
Quoted: 741 Post(s)
Liked 818 Times
I just noticed something highly significant about that photo...you have some kind of spacer between the crank and the pedal that apparently makes it so that the quill doesn't dig into your sole. Where did you get those? I've never seen them before.
FWIW, muddy roads and slot cleats really don't get along that well. BITD whenever we'd ride a fire road or someting, I'd carry a small screwdriver or something in a jersey pocket. This was used and used often for digging mud and gravel out of the cleat slots. It boggles my mind to think people used to cyclocross with slot cleats, albeit special ones.
Bikes: I have a few
Quoted: 340 Post(s)
Liked 210 Times
Also, thanks ALL for the great information. As some mentioned my knees, I will add that my peddling form is good and experience no swing in my knees and neither any harsh pulling or pushing on the pedal but fluid on the stroke. I think the cleats I was using might have been walked on a little too much and closed the gap as I swapped them for a brand new set and they engage/disengage quite nicely.
