Blue locktite under chainring nuts?
Quoted: 765 Post(s)
Liked 660 Times
You know that maddening thing when you go to loosen a chainring bolt and it just spins in the hole? And then you have to use that stupid little two-pronged tool to hold it in place--or try to hold it in place--so it will unscrew? One of the instructors at UBI bike school, where I went years ago, called it "the worst tool in the world," and I think that's a fair description.
What about putting a dab of blue lockite under the head of the slotted half of the bolt as a preventative during assembly? Not the threaded part--just the part that makes contact with the counterbored portion of the hole in the chainring. It seems to me that that might help prevent the bolt from turning when you go to loosen it. Off the top of my head, I can't think of any possible negative side effects. Of course, if the nut is really seized to the bolt, the locktite will probably shear before the bolt breaks loose, but it might be helpful in less extreme cases.
Has anyone here tried that, and if so did it seem to work? I'm thinking I might give it a try next time I install a chainring.
www.redclovercomponents.com
--Ogden Nash
--Ogden Nash
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3889 Post(s)
Liked 6,488 Times
Blue loctite is better than rust ... less permanent, anyway.
Strong Walker
So far, whenever I had trouble with the chain ring bolts, it was getting them loose (which is why I keep a VAR tool for that in my arsenal), not them rattling loose.
Quoted: 1372 Post(s)
Liked 1,752 Times
Blue - not a good idea for chain ring bolts! Blue just might damage fine threads during removal. I believe that Loctite 222 is for finer threads...
Likes For randyjawa:
Quoted: 4806 Post(s)
Liked 3,931 Times
I think he's talking about putting the blue between the nut and the spider, not on the threads. In other words, making the nut a semi-permanent insert. I've considered epoxying them in place, expecially in my fix gear where I change chainrings relatively often.
Likes For 79pmooney:
RUSA #3100
Bikes: Yes
Quoted: 237 Post(s)
Liked 505 Times
I have done this myself and it works pretty well, and you can still remove the nut after the lock tite has set. A little light grease or vaseline on the threads (not on the exterior of the nut) also helps. You just want more friction on the interface of the nut/chain ring than at the threads to keep the nut from spinning.
https://utahrandonneur.wordpress.com
Half way there
Quoted: 986 Post(s)
Liked 880 Times
I don't have problems getting them tight on assembly. Removing is a different story. I usually drill them out unless the pieces are vintage or special. Many times I wished I had one of the nice VAR tools for this purpose,
I have the nice Var tool, and proved I'm not very clever by somehow tearing up my knuckles much worse using the Var tool than I ever did with the stupid little Sugino thing.
The stupid Sugino thing can work a little better with the crankarm removed, on the workbench surface with the crank facing up, and pushing down on the crank so the tool is less likey to slip.
You can also position the tool so that it is pushing up against the edge of a spider arm, that plus leaning on it makes it very unlikely to slip.
If you don't mind mixing eras, you can use modern nuts/bolts which have allen key openings at both ends. Usually 5/6mm.
Fuggedaboutit!
Fuggedaboutit!
Quoted: 7349 Post(s)
Liked 2,474 Times
All my knuckles are scarred from work like this, so I don't care if I gouge them again.
Likes For noglider:
Liked 1,752 Times
Point well taken. I failed to properly understand the issue. To that add, I too see the need to do something to prevent or at least reduce the frustration caused when one of the fasteners fails to release.
It is always a good day when all 5 bolts make that crack and loosen without the little pin tool. And yes, my hands have been bloodied by that stupid tool but at least it has worked every time. Instead if making the nuts harder to remove you could focus on making the bolts easier to remove. A bit of grease should have them turning sooner than the nuts.
Likes For Narhay:
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 987 Post(s)
Liked 640 Times
Interesting! I think I am aging to get some of that.
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
PM me your cotters
Quoted: 1137 Post(s)
Liked 590 Times
I'll play devil's advocate here for a sec in case nobody else has...
What if you're like me, and you spend 75%+ of your time in the small ring on a double crankset, and thus you wear down and replace your small ring more than anything else? When you go to replace, you'll need to thread something into the sleeved wide you locked in, then hammer it out, potentially damaging its threads?
I like the idea of using blue threadlock, the bond is light, on-par with locking it in place with paint. But the long-term effects could make for painful upgrades later.
Loctite 247 is primarily designed for threaded applications; for a press-fit or slip-fit, you might have better luck using the appropriate green loctite.
I have accidentally done your experiment in the past (with too much blue loctite), and it was a huge pain in the butt to remove.
If you want a simple (but modern) solution: FSA makes chainring bolts that have a 5MM hex on one side, and T25 on the other.
Quoted: 581 Post(s)
Liked 921 Times
I have been frustrated by many difficult-to-release chainring bolts over the years. The solution I came up with was selective application of grease- basically the photo negative of OP's Loctite idea -
1. Thoroughly clean all surfaces on the bolts and the spots on the chainring holes where they touch;
2. When reassembling, insert the back side of the fastener (the 'nut' half of the chainring bolt) into its hole
3. Put a light dab of grease only on the threads of the chainring bolt and thread it into the nut so it takes up all the slack, but is not yet tight
4. Repeat steps 2-3 for all chainring bolts
5. Tighten in a 'star' pattern.
6. Re-tighten after a couple rides just to be sure
The low friction of the greased threads combined with the relatively higher friction of the bare metal of the outside of the fastener against the chainring will allow you to tighten the chairing bolts without the back part of the bolt turning. THe grease will also serve as an 'anti-seize', and the bare metal contact between chainring and fastener will still have higher friction and hold the fastener in place enough to easily break the tight bolt free when removing.
Although, I also have one of the little chainring bolt pin spanners, they work perfectly for what they are supposed to do, and I don't really see how these are so complicated.
Likes For ClydeClydeson:
Bikes: 1970s Coppi/Fiorelli beater, 1973 Raleigh Competition, 1972 Bob Jackson, 1970 Cilo Sprint-X, 1985 Fuji Touring Series IV, 1969 Legnano Roma
Quoted: 217 Post(s)
Liked 198 Times
would stainless chainring bolts (if they really are) mitigate the problem simply by not seizing as quickly/often as the generic ones?
Catching Smallmouth
Bikes: 1990 Specialized Sirrus Triple, 1985 Trek 460, 2005 Lemond Tourmalet, 1984 Schwinn LeTour 'Luxe, 1988 Trek 400T, 1985 Trek 450, 1997 Lemond Zurich, 1993 Diamond Back Apex, 1988 Schwinn Circuit, 1988 Schwinn Prologue, 1978 Trek TX700, Sannino
Quoted: 88 Post(s)
Liked 134 Times
Same here. I grease the threads and clean everything else. No problems.
I've used red loctite for the purpose mentioned and think I'll take the suggestion to switch to green loctite for this sleeve retaining purpose. Klein used to use it for bearing retention at the factory.
Stop reading my posts!
Quoted: 1444 Post(s)
Liked 1,063 Times
I have not tried any colors of LocTite but would also endorse the Green (if you have it, I happen to) but with any/all of these they are an-aerobic adhesives so will only cure where air cannot reach. I think the Green is formulated for this type of interface versus any of the "for THREADED" strengths (from Low-strength Purple to "you really think so?" Red). Might give it a shot next time. Cleaning the surfaces with solvent (Acetone or de-natured Alcohol is what I use) is key.
Quoted: 380 Post(s)
Liked 541 Times
I just use the little tool - used to be Sugino and now (since '86 or so) the Shimano. In the last +/- 50 years I've never had one come loose. Never had one I couldn't take out. Just been lucky, I guess.
Likes For Steel Charlie:
Quoted: 581 Post(s)
Liked 921 Times
Stainless fasteners are generally more likely to gall and get stuck together than plain or chromed steel, or aluminum. Corrosion is not really the issue causing difficult removal, so stainless would not improve this at all imo.
Bikes: S-Works Stumpjumper HT Disc, Fuji Absolute, Kona Jake the Snake, '85 Cannondale SR900
Quoted: 219 Post(s)
Liked 217 Times
Though one CAN use the small crescent wrench spanning from the back nut to a chainring tooth hack if one has to...
Bikes: '04 LeMond Buenos Aires, '82 Bianchi Nuova Racing, De Rosa SLX, Bridgestone MB-1, Guerciotti TSX, Torpado Aelle, LeMond Tourmalet 853, Bridgestone Radac
Quoted: 101 Post(s)
Liked 46 Times
I put TruVative bolts on all my cranks - 5mm on one side and 6mm on the other.
Quoted: 765 Post(s)
Liked 660 Times
Only someone like me would know or care about this, but the hex-socket-on-both-sides chainring bolts are only available for double chainrings. No one makes a single-stack version, as far as I know. As it happens, you need to use a single-stack nut, a 4mm spacer, and a long chainring bolt to fasten a granny ring to a Red Clover Components triplizer. I'd switch from the slotted style to the socket version in minute, if I could.
--Ogden Nash
--Ogden Nash
Senior member
Quoted: 943 Post(s)
Liked 658 Times
A little dab of lapping compound works for this. Just enough grit to hold the nut from turning. I think I saw that suggestion on this forum some years ago, and I have some in the sharpening kit that came with my lawnmower so I gave it a try, and it works.
