I don't get gravel bikes?
Bikes: '99 Cannondale M900, 2015 CAAD10 105
What am I missing about riding drop bars on gravel? Is it just me or does it just seem like a novelty? It's like it's some new found invention to have clearance for wider tires with a bit of a knob on them... I have a road bike and then I have an older XC Mountain bike. The XC bike has nice knobby tires that rides great on rougher gravely roads and smaller diameter, more efficient tires are just a swap away if needed. It is a rigid frame, so it's very light. The handle bars are wider and more stable, and the gearing goes way lower if things become more of a slog fest. I just can't seem to see where a "gravel bike" would be advantageous.
Likes For TheZip:
Quoted: 581 Post(s)
Liked 921 Times
For the same reason your mtb with slick tires is not a road bike - primarily the handlebar shape which encourages a more aero position and gives many options for hand positions, which can reduce fatigue. But if you go riding on your mtb with your buddies on gravel bikes and you can't keep up, it's probably not the bike's fault.
But, in general, you are correct - the whole 'category' of gravel bikes is just a minor tweak on existing bikes. Before gravel bikes there were cyclocross and touring bikes... gravel bikes are like a CX and touring bike had a baby. If you like to explore roads with loose surfaces, though, most road bikes from ~10 or 15 years ago are completely inadequate due to extremely limited tire clearance.
Likes For ClydeClydeson:
Likes For tdilf:
Quoted: 1279 Post(s)
Liked 1,393 Times
Sure, you can swap tires. But not halfway through a ride. 20 miles of pavement, 10 miles of dirt, 20 miles of pavement makes for a great ride. And good luck keeping up on the 40 miles of pavement with big knobby tires and a flat bar! road geometry with tires that can take multiple surfaces and a bit of squish is a nice best-of-both-worlds for many. it's just the name that's new really.
Likes For pipeliner:
Likes For ksryder:
Sunshine
Quoted: 10965 Post(s)
Liked 7,492 Times
Likes For mstateglfr:
Bikes: 2016 Surly Cross Check, 2019 Kona Rove ST
Quoted: 284 Post(s)
Liked 313 Times
Well, you have a road bike, so you obviously understand the benefits of drop bars. It carries over to riding offroad for many folks.
Expired Member
Quoted: 3674 Post(s)
Liked 5,437 Times
And the great thing is, nobody will put a popsicle to your head and force you to buy one.
Likes For shelbyfv:
Quoted: 324 Post(s)
Liked 251 Times
This sub forum was due for another one of these quarterly posts.
Imagine if we all rode the same 4 or 5 bikes and we lived in a vacuum of choice.
Bikes: 2002 Eddy Merckx Team SC Resto-Mod; 2019 Ibis Hakka MX; 2017 Spot Brand Ajax Belt Drive
Quoted: 169 Post(s)
Liked 192 Times
Every bike is a compromise. A gravel bike is just a slightly different set of compromises than a road bike or a MTB.
Likes For mattcalifornia:
Randomhead
Liked 3,699 Times
The local Wednesday night gravel worlds has about an even split between people riding mountain bikes and people riding drop bar gravel bikes. So in practice, a lot of people agree with the OP. And also, just ride what you want. No need to seek affirmation from the people that do get why one might want to ride a drop bar gravel bike. I certainly am not going to try to convince you.
On edit: the people on mtb never win the sprint at the end, so there's that.
Likes For dsaul:
Quoted: 2333 Post(s)
Liked 2,097 Times
N + 1
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
Let me do the math for you.
N + 1
N + 1
The road, mountain, and urban bike have been collecting dust. So I guess that makes it N-2
Liked 2,097 Times
My math shows N-1. I don't need a road bike or urban bike, or a mountain bike or a cross bike. I still need a velodrome bike and a bike with suspension, but those two aren't getting ridden much.
Many riders want lots of bikes and companies oblige that "need"
Expired Member
Liked 5,437 Times
Well, OP has squatted and moved along. Maybe he'll drop a companion in Ebikes....
Quoted: 3242 Post(s)
Liked 2,086 Times
I found out decades ago that I don't like to ride distance on flat bars. I'm good for 10 - 12 miles. I'm much more comfortable on drop bars as there are many more positions for my hands. My gravel bike allows 45mm tires thus and at much lower tire pressures than what I run on my skinny tired road bike, is more comfortable on dirt roads. and a 45mm tire isn't that terrible on the shorter segments of pavement I might do as part of a gravel oriented ride. It's just a good in-between alternate to a mt. bike or road bike.
Quoted: 286 Post(s)
Liked 262 Times
If you like riding all sorts of terrain a road bike is perfect for the road and small gravel stretches, and a mountain bike is perfect for single track and typical trail riding. The latter can be ridden on gravel without any issue and people do it all the time. Most gravel bikes, with 40mm+ tires are ‘good’ on most surfaces but not great on anything. If I owned only one bike it would be a gravel bike.
Quoted: 4227 Post(s)
Liked 2,488 Times
Gravel riding has evolved into an elitist snob activity which requires taking out a mortgage to finance purchasing all types of special "gravel specific equipment, clothing and items "...It's not about the challenge and enjoyment., it's become a fashion show for the newest " gravel specific trends " .
Likes For JWK:
Sunshine
Liked 7,492 Times
Gravel riding is as expensive or as inexpensive as you want to make it. Just like every other hobby and just like every other genre of cycling, it offers products that vary in quality and price. It is no more or less snobby than it was last year or 5 years or 10 years ago. That is just your uninformed perception, based on the fact that brands now market to the genre. You seem to rely on marketing as reality.
I was in a gravel race 2 weeks ago. There were riders from a local high level amateur team, riders on $4000 gravel bikes, riders on $1500 aluminum gravel bikes, a guy on a bikes direct motobecane fat bike, a few single speed gravel riders, etc etc. The equipment was wide ranging. Some were in boutique kit, many were in jerseys from various rides they have done(so a basic Primal jesey), and quite a few women were in active tank tops.
I went for a 40mi mixed ride yesterday and coming the other direction at one point were a couple of good riders from a different local team. They were in their team kit, as always, just like when they are on the road or when they race cross. Same kit for all of it- hardly elitist snob level. Both were on relatively new gravel bikes that cost the same as relatively new road bikes or relatively new mountain bikes.
Get over your irrational hate. You are being led to a conclusion due to lack of experience and what media you consume.
Liked 2,488 Times
You have a consistent dislike/negative approach to the word 'gravel'. Its so comically extreme that I actually remember from the last generalized rant you went on.
Sunshine
Liked 7,492 Times
I love riding gravel roads, it's actually my favorite form of riding besides mountain biking, what I dislike is all the marketing BS associated with this particular activity....Lack of experience ???....I converted two of my rigid forked MTBs to drop bars and started riding gravel way back in 2009, long before it became trendy. It's 2021 now so that gives me 11 years of experience of riding gravel and I know exactly what I need....I refuse to buy into all the marketing BS that's out there.
Get over your irrational hate. You are being led to a conclusion due thinking reality is based on what media you consume.
There ya go, accurate now.
Its awesome that you know what you need. Thats the case with a lot of cyclists- they know what they need and buy accordingly. That doesnt mean their genre/discipline is elitist snobbery just because brands market their products to a different audience.
Please tell me you can see this exact same thing with road cycling, mountain biking, triathlons, etc. It is absolutely no different- brands market an image, but that doesnt mean the entire genre is actually that image.
You have to be able to know marketing /= reality. If marketing was reality, then me buying a 6 pack of bud light back in college would have started a pool party.
Quoted: 324 Post(s)
Liked 251 Times
I don't think anyone is being forced to buy into any marketing that's out there. It's just marketing. It's been around a while and it ain't going away. How one perceives it and reacts to it is the only thing one can control.
