Remove glue residue after sticker removal
After removing sticker from frame i have layer of glue residue left that don't remove even when using brake cleaner or WD-40. only scrubbing for 10 minutes nonstop removes it. Is there an easier way to take off that residue without damaging the paint job?
Expired Member
Quoted: 3674 Post(s)
Liked 5,437 Times
Designate one of your stable to scrub it?
adhesive remover
Hardware stores sell a product called Goof Off. It claims it can be used on automotive paint surfaces. I've used it in the past. Works great
Likes For Bent4life:
Quoted: 5224 Post(s)
Liked 3,585 Times
I've used rubbing alcohol. dunno if it's safe for paint, but I think so. I've also used hand sanitizer to remove tree sap. seems safe for car paint
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
Goo gone, De-solv-it, lemon juice
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
WD-40 works pretty good on some things, too. but, goo-gone, goof-off.....those work for sure. it all depends on the adhesive
Quoted: 6196 Post(s)
Liked 4,811 Times
You tell us what the name of the adhesive is and maybe we can tell you what works.
Otherwise, try everything mentioned. No guaranty that it won't hurt your finish as you didn't tell us what that is.
Actually i want non commercial solution, but more of a some cheap and dirty.lifehack. Thanks for understanding.
Liked 4,811 Times
Well mash out some grain, ferment it a few days and distill out the alcohol. Usually where WD-40 or mineral spirts doesn't work, alcohol does well for me.
But since WD is commercial, just try some citrus oil.
No guaranty on the finish though. Paper towels do scratch, so cotton cloth will be better if you have to rub forever.
Try blow drier or heat gun (keep distance with heat gun and keep it moving) dont need to get the surface too hot to touch.
Try applying WD40 on the area first, heating it, then use a non-marring tool like a nylon spudger or just use finger nail or credit card, lightly scrape and most should come up.
Could also wrap a shop towel in wd40 overnight and leave on surface overnight (use zip tie or wrap some rope/cord around the rag to keep it tight and most residue would come off after soaking.
Going slow and even taking a few days of soak+clean will help decrease chance of marring.
Coconut oil and cooking oil would likely work as well but would require the rag soaking method and time.
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
Start with Goo Gone, which has worked 90% of the time for all of my sticky residue needs. Goof Off is more heavy duty, but might harm the paint.
It's like riding a bicycle
Likes For urbanknight:
Nail polish remover, which is acetone. Just don't use it on resin.
Likes For cyrano138:
Quoted: 2432 Post(s)
Liked 641 Times
Get a can of disc brake cleaner from the auto store and buy nothing else. Takes it right off. Better than anything else posted or works just as good for less money and I've tried them all.
Sierra
Trying to get away from chemicals, I've found applied heat from something like a blow dryer my best method to remove a sticker and adhesive together. Most of the adhesive comes off with the sticker. Patience required. Follow up with a plastic razor blades for any residue.
Space Ghost
Bikes: Bridgestone, Fuji, Iro, Jamis, Gary Fisher, GT, Scott, Specialized and more
Quoted: 292 Post(s)
Liked 412 Times
I actually give the vegetable oil a shot before resorting to solvents.
Quoted: 1303 Post(s)
Liked 1,912 Times
How about using the stuff you use on your hands: GoJo hand cleaner. A bit on a rag and start rubbing and it should come right off. And safely I might add. Smiles, MH
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1948 Post(s)
Liked 1,471 Times
Then I used acetone to remove the residue after the Goo Gone step.
Likes For SoSmellyAir:
Liked 1,471 Times
Quoted: 967 Post(s)
Liked 1,631 Times
This is the only one I would trust if I did not know the durability of the paint. It will not remove paint or clear coat. It is safe for the skin. If this does not work then a detailed exam should be done of the adhesive on a test area with any stronger solution.
