tubeless tire swap
tubeless tire swap
I need to change a tire on my gravel bike, and need a suggestion on how to clean up the rim after removing the tire and sealant. The sealant I have is Orange seal endurance, would warm water and soap work?
Dave
Dave
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Quoted: 6972 Post(s)
Liked 10,968 Times
Maybe I'm doing it wrong, but I just wipe off the rim with a couple wadded up paper towels, then mount the new tire.
Likes For Koyote:
Dave
I like bike
Bikes: Roubaix Comp 2020
Quoted: 267 Post(s)
Liked 283 Times
The sealant is not normally touching the rim due to gravity. That plus the slick surface of the rim means there is no issue removing any sealant on the rim with a paper towel. It can collect in and around the valve stem though so make sure to clean that well.
Good luck with those Gravelkings, I found them one of the hardest tires to mount as they were very loose on my rims.
Liked 10,968 Times
Likes For msu2001la:
Got the old tire off no problem, and the rims cleaned up really easily. Just used paper towel. Got the new tire on, but can't seat it with the floor pump unfortunately. Guess i'll have to drive home and use the compressor at some point.
Dave
Dave
I tried using a compressor today, but no luck setting the bead. The valve core was out of the wheel, the pressure output was set to 110 psi, and I used both a blow-gun and schrader valve filler, but didn't have any luck. The tire bead was set in the middle of the rim. Is the issue the fitting used to get air in the tire? What else could be wrong? The compressor is also pretty large at 8 gallons.
Dave
Dave
Bikes: Niner RLT RDO, Trek Remedy 9.8
Quoted: 108 Post(s)
Liked 117 Times
Dave
Dave
Likes For tdilf:
I like bike
Quoted: 267 Post(s)
Liked 283 Times
For me the Gravelkings were too loose and bead in the middle would never work. The only way I got them to set was to get the tire beads right up against the rim. The tires are very flexible so you can use your hands to pinch the tire and pull to the rim, just rotate the wheel while you do that to every inch of the tire. Then inflate without setting the tire down (setting down will move the bead from the rim on the spot where you set it down). Either that or adding half a dozen layers of rim tape might work.. a couple layers did not help, the LBS tried that and failed.
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times
If you haven't seen this, it might help.
https://www.youtube.com/watch?v=tE3h4nmDdOo
I was going to recommend the same video, def works. Also, and this is an easy one, but I've done it before, make sure the valve stem is actually between the tire beads, I've had it where I popped the tire off to one side of the valve without realizing it. But if that's not the case, then getting the bead started in opposite directions as shown in the video usually works. I've always been able to seat with a floor pump using that method.
Dave
Bikes: 1984 homemade 531SL road bike; 1988 Ritchey TimberComp; 1997 Nashbar tandem; 1998 Kona Explosif; Specialized Epic, Scott CR1 Pro; Salsa Beargrease; Curtlo custom Tandem, Curtlo custom S3 steel gravel bike.
Quoted: 67 Post(s)
Liked 49 Times
I'm a big fan of Skinny Strippers - which is a bike thing ;-) for tubeless setup.
Usually can inflate gravel tires with just a floor pump with those in place. I've never had a problem getting a gravel tire to seat when using a compressor with the valve core removed.
So I took the tire and rim to the LBS. The mechanic blaster the tire with a massive automotive dual stage compressor. The tire wouldn't seat with several attempts. His verdict was that the rim/tire wasnt a good one. Rims are wtb i23s, and the tire was just too loose. They had a Specialized Pathfinder Pro, and offered to mount it, and if it didn't work, no charge. The tire inflated right away, popped, and seated perfectly. It was also a bit wider than the Gravelking at 42mm vs the 38mm. Has anyone seen a database of good rim/tire combos for tubeless? So far the good tires know of for the Wtb i23s are the Maxxis Rambler and Specialized Pathfinder Pro.
Dave
Dave
Liked 10,968 Times
Dave
Dave
Dead but dreaming
Location: Bay Area, CA (East Bay - Contra Costa County)
Bikes: 2020 Santa Cruz Stigmata, 2022 Cannondale Synapse
Quoted: 171 Post(s)
Liked 326 Times
Dave
Dave
Likes For KJ43:
Dave
Dead but dreaming
Quoted: 171 Post(s)
Liked 326 Times
My first impression of the Pathfinder is that it reminds me of WTB tires on a MTB. They seem like they will be strong, puncture resistant tires. I ride a lot of singletrack and rough gravel on them, so that will be a plus. The Ramblers I had held up really well, but were only 40mm. Wondering about the suppleness of the Pathfinder Pro though, seems like it rides a bit harder than the Ramblers. Probably fast when it gets going.
Dave
Dave
The Ramblers I had (42mm width) were great in the dirt both in grip and comfort, but not great on the pavement and the knobs wear fast. The Pathfinder Pros were not as supple as the Ramblers but much faster on the pavement and seem just as fast in the dirt even if they aren't as comfortable as the Ramblers. The Pathfinder Pros just last forever also since it has the solid center line.
Dave
This morning I took the gravel bike out for a real test of the Pathfinder Pro (got the brake rub issue addressed already). The ride was 37 miles, and a mix of pavement, leaves, dirt, fine gravel, and a little rough gravel. The tire gripped really well in all conditions, but was especially fast on pavement and the fine gravel. The suppleness was good too, but I think the Rambler might be a little better (which is odd since this casing is 120 tpi, and the Ramblers I ran were 60 tpi). Can't wait to ride these again!
Dave
Dave
Likes For bonsai171:
