Is this a bike fit issue?
Is this a bike fit issue or physiological?
I have noticed that over a period of time, my bib shorts start to wear out at the point of contact between my right sit bone and the saddle. This probably indicates imbalance between the two legs. I don't have power meters to verify that.
So, I am looking to seek the wisdom of the general populace to figure out what's the best way to diagnose this and then how to resolve this. Growing up, I always had issues with my knees where they would buckle under sudden pressure from change of direction or sudden stoppages. So, I may be favoring my left knee unconsciously?
Incidentally, this happens only on Rapha shorts. I have a Specialized pair that outdates the Rapha ones but it shows no such signs.
Thanks!
Thanks!
just another gosling
Quoted: 3889 Post(s)
Liked 1,939 Times
A lot more people than one would think have mild scoliosis. I have trouble with saddle sores on only one side. I've had my legs measured by a doc and they're the same length. So that's my guess. A good doctor can tell by examining your back muscles for asymmetry, no X-ray necessary.
Results matter
Results matter
Quoted: 514 Post(s)
Liked 450 Times
Jeez, how did we ever fit ourselves before power meters? Maybe your saddle is crooked, bent, or too high, maybe your hip alignment is crooked, maybe one leg is shorter than the other, maybe your cleat alignment is off, or maybe your pedaling dynamics are just asymmetrical. Sorry I can't fix your problem, but hopefully I've given you a few things you and a riding buddy or professional fitter can look at.
Quoted: 4409 Post(s)
Liked 1,566 Times
Have you examined the shorts to rule them out? The difference between the two seems like the biggest clue.
Likes For Kontact:
It happened on 2 Rapha shorts. Maybe their material is softer and hence wears out more than the one on Specialized shorts.
Quoted: 6196 Post(s)
Liked 4,811 Times
Unless you have 12 pairs of Rapha and 12 pairs of Specialized shorts, each showing the differences you claim, then I wouldn't put much into your hypothesis other than it needs more investigation.
Liked 1,939 Times
When I had sciatica, my lower back hurt like the devil for the first mile, then it was fine. I walked every day for a couple weeks, went away, did not return. My saddle sore OTOH is still around, but it's just a flesh wound..
Results matter
Results matter
Another possible issue is saddle is too narrow and you are pushing harder with your dominant (right) leg and moving slightly off the saddle wearing out the shorts on that side?
