General Saddle Advice?
I don't know much of anything about bikes. I just bought a used Jamis Ventura because I want to train for a triathlon. I'm a woman. I did a 30 minute ride and thought the saddle was kind of uncomfortable (maybe too narrow for my sit bones). What are the different considerations for buying an appropriate saddle? Is it just as easy as finding one designed for women (I purchased this bike from a man)?
Quoted: 6196 Post(s)
Liked 4,811 Times
You might see if a local bike shop has a way to measure where your sit bones are. Supposedly women in general have wider sit bones so if your bike wasn't a specific women's model then the saddle width might be a consideration. You can do a google search for how to determine your sit bone distance. But be sure to be in the position you expect to be on your saddle/bike. The structures that comprise what we call your sit bones narrow up as your hips roll forward.
If you haven't riding much and especially if you haven't ridden at all, then even the perfect fitting saddle for you will become a real pain for several weeks until your body gets use to your new demands on it. I can only describe it as a ache down in the bones. If you are having a sore rubbing in the skin then that's other issues that might be saddle shape and cushioning inappropriate for the type riding you do, but more likely the seams in the clothes you wear or something else. As the saddle on a new bike should be appropriate for the intended use of the bike.
However some of use prefer a saddle with a cutout down the middle and others don't like that. And the variations of cutout width and saddle profiles are vast. Back a long time ago when I was getting use to riding again after a quite a few years of almost no riding, I played the saddle swap game for a few months. When I finished and found the saddle I liked, I noticed it wasn't much different than the original saddle that started me looking for saddles. I used that saddle on another bike later.
Quoted: 514 Post(s)
Liked 450 Times
Generally women's saddles are wider at the butt end and shorter, and they work better for most women. By all means visit a bike shop and get measured. Many saddle brands have 30-deay returns on saddles. Some dealers offer demos.
Likes For oldbobcat:
Finding the correct saddle definitely seems like a complicated endeavor. I just adjusted the saddle height (I knew it was too high, but I didn't have time to adjust it before my first ride), and I do feel something is "off." It's definitely related to my sit bones, not rubbing skin or anything like that. Maybe the seat is too firm for me? I'm about to go on my second ride, so I'll see how it does today.
Thank you for the response! I do think it would be helpful to visit a bike shop for some help. Frustrating thing is there are many of them, but they are all about an hour away 😥
Liked 4,811 Times
For a road bike there 2 basic positions. A relaxed position and a aggressive position for being very aerodynamic. Sometimes called a race fit. And all the positions in between. But for all, there probably isn't a difference in the measurement that is significant.
Essentially I really just meant not to be sitting bolt upright. Unless that is the position you will be using while riding your bike.
I found a website (SQ Lab) that showed photos of where the pain is and an explanation of why. Based on that, I think either I just need to get used to riding or the saddle might be too narrow (the pain is at my sit bones, but sort of towards the inside of them?). I tried to measure my sit bones and I think they are about 120mm (if I did it correctly), and the seat is 150mm at the widest part, but since it slopes down at the sides, 120mm is kind of on the edge of the saddle where it's sloping down? It looks to me that someone with about 100mm sit bone distance would be more comfortable/supported 🤔
Quoted: 514 Post(s)
Liked 450 Times
It doesn't sound like you're measuring correctly, unless you are really small.
Riding companions, if you have them, are good for free advice. Sometimes it's just something simple like, "You don't look balanced," or "You look funny on the bike." Something tells me that (a) this is the wrong saddle for you and (b) you're not sitting on it correctly. But I can't really tell without watching you ride.
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
My sit bone width measures about 115 mm and I comfortably ride a 150 mm saddle on a drop bar bike. Your 120mm width would suggest a 140mm saddle.
Of course, not all saddles of proper width may work for you. I switched a month ago from a basic modern shell and padding saddle (Volt) to a tensioned rubber saddle (Cambium C15), and it’s like the saddle disappeared. Which is a good thing. Hopefully you will find one that isn’t a problem.
I should say that most people who try a tensioned leather saddle and a tensioned rubber saddle pick the leather saddle. Also, tensioned saddles tend to be heavy and probably a bit of a liability in a triathlon.
Otto
Quoted: 2488 Post(s)
Liked 2,957 Times
Best general advice about saddles---a bit higher than the ideal saddle height is considerably more uncomfortable than a bit lower than the ideal height. I have five bikes that I ride regularly and a few more that I ride occasionally, all with different saddles, almost all with the saddles that were on the bikes when I bought them, all perfectly comfortable for me. I started shrinking in height in my 60s, so I've had to drop the height of the saddles a couple of times since then, but having done so, they're back to being comfortable.
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
I think blaming your saddle might be putting the cart before the horse. I would suggest finding a bike shop that provides a detailed fit. These usually cost around $200 and a good fitter will spend a couple of hours with you and your bike.
The point I am getting to is that a fit that isn't quite right can cause you to blame your saddle. Granted that your saddle may indeed not me right for you. But you won't know this until you get your fit just right.
Likes For Lombard:
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
Otto
Likes For ofajen:
Quoted: 1743 Post(s)
Liked 1,281 Times
Quoted: 1858 Post(s)
Liked 664 Times
Thank you for the additional explanation! I would say overall I'm in an aggressive position with the aero bars, but sometimes more relaxed. The seat isn't as uncomfortable when I am in the most aggressive position.
Bikes: two blacks, a blue and a white.
Quoted: 445 Post(s)
Liked 847 Times
I'm guessing you plan to compete in "a good number of triathlons" in the coming years. In that case, the investment in a professional bike fitting will pay hefty dividends, especially if you are on the aero bars. You're going to train for, probably, thousands of miles - think about that. The pro fitting session will address the saddle and other issues that ensure you feel *great* on your bike like it was made for only you to pedal.
just another gosling
Quoted: 3890 Post(s)
Liked 1,939 Times
Beyond the good advice above, several of the women I ride with ride a Selle Italia Diva. If you see one at a bike shop, you might try sitting on it, see what it feels like.
Results matter
Results matter
Likes For Carbonfiberboy:
Keep in mind that you can’t really judge a saddle unless you yourself are “broken-in,” and your backside has become acclimated to riding. No saddle is comfortable, and any saddle will make you sore if you are not used to riding. In my case, after the winter season, it will take me half dozen rides or so before I feel comfortable on the saddle, and don’t suffer from any saddle pain after the ride, YMMV.
Likes For 50PlusCycling:
Quoted: 1401 Post(s)
Liked 1,886 Times
Terry Butterfly Ti
155mm wide, fairly well padded w / center cutout, titanium rails, 250 g approx weight
put this seat on mrs t2p bike
seats are a personal thing - so what works for one might not work for another
Likes For t2p:
Quoted: 427 Post(s)
Liked 700 Times
t2p beat me to it. A number of women I know use the Butterfly saddle--don't know which model. As mentioned, no saddle is right for everyone, but this one works for a few I know. I've found a good fitting chamois helps with comfort also, especially on longer rides. With any new saddle I always carry a wrench which I can easily get to when first using the saddle. Usually takes a week or more until I feel it's adjusted just right. And even then it may change a little after initially getting it where I think it's adjusted.
Liked 664 Times
Her riding position uses drop bars, but they are positioned about at the same height as the saddle. So she is nowhere as far leaned as the archetypal tri-bike bars, with weight on the elbows and forearms. Her saddle is placed fore-aft so that her knees are a little behind the crank axis, and tilted so she does not tend to slide forward (nose too low) and her bones don't rest on the steel base in the back of a leather saddle (nose too high). With the degree of lean she has, the width of the B17 works well for her. If she went for a tri-bar (we don't compete so I'm pretty sure she won't), she would benefit from a narrower saddle. I'd put her on a B17 Narrow or a Brooks Professional, just as examples.
This is all controversial and worthy of debate, but it is how I have worked to set us up for comfortable and (I guess) efficient riding. I worked similarly with a neighbor lady who wanted to train and ride her first triathlon, and she won. But no reported discomfort.
I hope this helps!
Liked 664 Times
Also, there is a saddle company owned and run by a woman who is a very capable long-distance rider, a true randonneur who can readily take up a 100 mile day on the bike. She designs and evaluates her products herself, and can talk about saddles. The company is Rivet, and the Head Rivetress is Deborah Banks. I think it might be worthwhile to have the words of a true expert, so Google her site and poke around in there.
I'd also suggest looking at the products of Selle AnAtomica and reading through their site.
In the family we don't have any experience with Terry saddles, though Mrs. Road Fan loves Ms. Terry's clothing and rides a custom Terry.
Liked 664 Times
I would think some help from a bike shop is in order. The saddle width doesn’t seem obviously wrong for you. Generally a starting point is a saddle with a nominal width that is about 20 mm wider than your sit bone width.
Otto
Otto
