What's the thinnest, fastest wheel I can fit on my beach cruiser
What's the thinnest wheel I can fit on my beach cruiser
Just picked up a 26" "crank-forward" style cruiser at WalMart for $79.
I'm looking to use it as the basis of a bike building project (I like to tinker) to add a 3 speed rear wheel and shifter and some more urban friendly tires.
The stock tires seem to bite a bit too much and since my neighborhood is a bit hilly, I'd like to know if I can fit these tires on the rims?
Liked 6 Times
Those tires should work, although "fast" and "crank-forward beach cruiser" are pretty much mutually combative concepts unless you're skydiving with it But you probably realized that already
If you want a fast 1.5" tire, however, Pasela TourGuard folding with Continental Supersonic ultralight tubes qualifies as "fast." Those cheapies at Amazon... not so much.
Those tires are probably more than I spent on the bike, LOL. Just looking for some cheapies that will work.
Biking Viking.
They'll work. You'll probably need new tubes as well.
Quoted: 12195 Post(s)
Liked 1,497 Times
If you have a specialized dealer nearby, the Nimbus tires are really nice. They start at $20 each, but the ultra-flat-resistant armadillo version may pay for itself at $45 in the number of tubes you don't end up replacing.
https://www.specialized.com/us/en/bc/...jsp?spid=57827
Quoted: 19 Post(s)
Liked 7 Times
The best modern cruiser tyre is Schwalbe Big Apple. It is quite fat but very slick uses the latest hi tech construction so is very efficient. It has been my daily commuting tyre for a couple of years.
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12781 Post(s)
Liked 7,696 Times
I briefly thought about bringing up lacing the hub to some road rims, but figured the OP was looking for something off the shelf, hehehe.
What's the width of those rims? Some cruiser rims are probably too wide for 1.5" tires. If those rims are really wide there are plenty of good 1.75" and 2" choices out there.
maybe a coaster brake 3 speed , so you got 2 more gear ratios, too..
JRA cruising, and a headwind and a tailwind gear..
Bikes: 2010 GT Tachyon 3.0
Quoted: 45 Post(s)
I don't see any kind of brake levers on that. You need a front brake, or at least a rear V brake. What do you do if your coaster brake fails?
Bianchi Goddess
Quoted: 2935 Post(s)
Liked 2,930 Times
you should have upgrade to this one.
Sugar "Kane" Kowalczyk
Don from Austin Texas
Bikes: Schwinn S25 "department store crap" FS MTB, home-made CF 26" hybrid, CF road bike with straight bar, various wierd frankenbikes
Quoted: 11 Post(s)
That's going to be one schizophrenic cycle! Beach cruiser and speed are at opposite ends of the spectrum!
Don in Austin
Don in Austin
Real Men Ride Ordinaries
Quoted: 17 Post(s)
Scwalbe has you covered already, they make a tire called a 'speed cruiser'
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
Not likely this bike will be going fast enough for that to be an issue.
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
Those could cost more than the bike cost.
Bikes: CCM Torino 76
You get what you pay for.
There are plenty of options for reasonably priced road tires. SOmeone mentioned Specialized Nimbus tires, and I have certainly had good luck with those.
Kenda makes a few good road/hybrid tires.. The 'Kwest' is cheap and decent.
THe OP needs to measure the width of the rims on the bike and buy a tire slightly wider than that, at least.
