Garmin Edge 530 Not Pairing With Wahoo TickrFit HRM
Bikes: Trek Domane SLR 2019, Trek Trek Madone 5.1 (2011), Trek 1400 (1991)
Quoted: 47 Post(s)
Liked 74 Times
I picked up a Wahoo TickrFit HRM the other day. I paired it with the Wahoo app on my phone, no problem. I paired it up with Zwift on my computer, again no problem. I then tried to pair it with my Garmin 530, its sees the sensor, but it doesn't complete the pairing process. Garmin SW has been updated and my Wahoo cadence and wheel sensors both work fine. I've tried power cycling the garmin and wahoo multiple times, no luck. I've checked with Garmin and Wahoo support and forums, for any information on my situation can be found. Has anybody had the same issue and was able to resolve the problem? Does anybody have any suggestions?
Quoted: 18883 Post(s)
Liked 10,646 Times
Quoted: 47 Post(s)
Liked 74 Times
The Garmin "sees" the Tickr and displays its name, it just won't pair. The only other thing I tried so far is shutting off all other Bluetooth devices nearby to see if that was a problem. No luck.
Liked 10,646 Times
When I try to pair my Garmin to a sensor that supports both radio types, it shows me the sensor twice. Do you get one HRM or two after you search but before you (try to) finalize the connection?
Quoted: 6250 Post(s)
Liked 4,851 Times
What does it say that tells you it didn't pair?
I remember long ago one guy on the Garmin forums went through several pages of replies of help trying to pair his HR strap to his Edge of some early model. Finally someone ask if he had the strap on. He later came back and admitted he didn't and when he put it on, he had a HR reading.
Quoted: 47 Post(s)
Liked 74 Times
Ok I just googled Wahoo TickrFit HRM and it looks like this supports ANT+ as well as Bluetooth. I think your 530 does as well, I've never had that one though so I'm not certain.
Quoted: 47 Post(s)
Liked 74 Times
Quoted: 47 Post(s)
Liked 74 Times
So some how I managed to get it to work! I think it just needed a long time to pair. I was fooling around with data fields and was playing around with it for about 10 minutes, when all all of a sudden it asked me to create a data field for HR. And lo and behold when added a HR field, it was filled with HR.
So thanks to all for your help and suggestions.
Likes For Buzzkill53120:
Quoted: 681 Post(s)
Liked 949 Times
Likes For fooferdoggie:
Liked 4,851 Times
Also, turn the power completely off and then restart it. Don't just push the power button and put it to sleep. Hold the power button for a few seconds and then you'll have the option to turn it off. That might help ensure a previous update is fully functioning.
Durn, should have read the previous two posts!
