Best looking hybrid you have seen
Bikes: Cannondale Supersix Hi-Mod / Scott Spark 930 / Scott Sportster 20 / Jamis Allegro 2.0
Here are my favorites:
Orbea Diem: S20 https://www.orbea.com/us-us/bicis/mod.../#presentacion
Specialized Sirrus: Limited https://www.specialized.com/us/en/bik.../sirruslimited
Wilier Bassano: https://www.wilierbikes.co.uk/2012/im.../1120/12BA.jpg
Ha ha ha ha ha
Bikes: 2004 ORBEA Mitis2 Plus Carbon, 2007 Cannondale Bad Boy Si Disc, 2012 Trek Gary Fisher Collection Marlin WSD 29er Aldi Big Box (Polygon) 650b
Quoted: 8 Post(s)
Liked 11 Times
I agree in part but...the Orbea has discs which means it can swap to 26 inch wheels and MTB's can have rigid forks. My Hybrid has discs (hence easily swapped from 700 to 26 inch) and a rigid fork on an MTB frame. Most definitely a hybrid.
Quoted: 1576 Post(s)
Liked 1,182 Times
Looks like Specialized has done a really nice redesign (to my mind) on the '13 Crosstrails:
https://bicyclesportshop.wordpress.co...ed-crosstrail/
Much better looking frame/geometry; the top two (Comp/Pro) get a frame material upgrade. The Pro in particular tempts me: X0/9 drivetrain; Magura brakes. Throw a decent lightweight set of 29er wheels on it, and ...! I like the fact that they've turned away from "29er light" just a little, and oriented the model more toward the classic, light Euro-style "cross" (not to be confused with "cyclocross") bike.
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1105 Post(s)
Liked 2,169 Times
Bikes: 2012 Trek 7.2 FX, 2005 Schwinn Mesa, 1978 Raleigh Super Course
Nothing pretties up a bike like trekking bars. Mine:
They don't all have to be flat bar road bikes. To me, the major limiting factor in most hybrids' appearance is a cheap crankset.
Bikes: Specialized Sirrus Limited
How many "features" from either ends (pure mountain bike and pure road bike) it has to have to be a "hybrid?" What I notice is that a lot of bike manufacturers have dropped the hybrid designator and are simply calling these as multi-use, street, or fitness bikes. For example, the Specialized sirrus used to be listed along the road bikes but for 2012, Specialized has introduced a whole new class called multi-use. But I do agree that the Orbea and the Sirrus limited are essentially road bike frames with a flat bar. The Sirrus limited shares the same frame as the Roubaix SL2.
I think "hybrid" is correctly applied as a very broad term. Anything not purely a road bike, or purely a mountain bike, that falls somewhere in between, I will call a hybrid. Flat bar road bikes fall under this designation, so do the new dual sport/multi-use bikes. Frame geometry is the major differentiation that is less obvious. My Trek 7.2 FX apparently can be described as a "light touring" geometry, with longer chainstays and slightly more upright seating than a "flat bar road bike" would have.
Bikes: 2011 Felt Z85 (road/commuter), 2006 Marin Pine Mountain (utility/commuter E-bike), 1995 KHS Alite 1000 (gravel grinder)
Quoted: 676 Post(s)
Liked 13 Times
In my mind, a road bike has a lower BB, longer head tube, a more horizontal, shorter top tube, and shorter wheel base. A mountain bike has a higher BB, shorter head tube for more clearance between down tube and front tire, longer, sloping top tube, and a longer wheel base.
A "true" hybrid might have some of both. In the case of a flat bar road bike, you might have a longer top tube and shorter stem to work with a flat bar, but then also the lower BB and shorter wheel base.
To me, my own KHS Alite 1000 isn't really a "true" hybrid because it's still MTB geometry, despite me adding smoother road tires, rigid fork, and a shorter stem. It's still got that high BB, sloping top tube, and massive clearance between front tire and down tube that I don't really care for.
