Problems mounting Schwalbe G-One Tubeless Tires
Quoted: 427 Post(s)
Liked 339 Times
Hello.
I have had trouble now with two Schwalbe G-one tubeless tires. These are being mounted on brand new American Classic MTB Race 29er wheels. I get the tire mounted with no problem, and have been using Schwalbe's own tire bead lubricant to help get the bead over the lip on the inside of the rim. As I get the pressure up to 45 - 50 PSI and the bead pops out to the rim, the tire then blows off of the rim completely. (The sidewall of the G-one says 60 PSI max). Then when I dismount and remount the tire I find that clearly one bead is not as tight as the other leading me to the conclusion that one bead has stretched. Upon reinstallation and inflation I find that the same scenario repeats with the only difference being the same side blows off of the rim but now at an even lower pressure.
I did not exceed the tire pressure listed on the sidewall.
On Schwalbe's site they say to only mount the tires on ETRO tubeless rims with a 6mm side wall height, but the AM Classic rims measure a side wall height of 3.3mm. I called AM classic and they insisted that the rims are compatible with Schwalbe and the G-one should work fine with their rim.
Suspecting a bad tire, I bought another and the same scenario repeated.
I have contacted Schwalbe but as yet I have not heard anything back.
Has anyone else had this problem?
Bikes: Trek Domane SL Di2, Giant TCR 2004, Salsa Beargrease 2015, Dahon Mariner
There have several similar problems with G-1's, see posts at https://www.bikeforums.net/cyclocros...l#post19901938 . It seems to be a quality control issue.
Quoted: 20810 Post(s)
Liked 9,456 Times
See this thread - same tires, same wheels, same problem (and no solution, that I see) - https://www.bikeforums.net/cyclocros...ternative.html
Liked 9,456 Times
I don't know that it's a QC issue if it's on the same wheels (with a rim profile that Schwalbe evidently doesn't support) - sounds like a compatibility issue. My G-ones have been nothing but hunky-dory on HEDs with taller sidewalls.
Liked 9,456 Times
Quoted: 427 Post(s)
Liked 339 Times
More tape on the rims helps seal tires that will not seat, but if you have too much tape the tire bead gets stuck on the inside of the bead then eventually pops out forcefully and can have enough inertia I believe to blow over the outer wall. It appears that is what is happening here...
