Gearing Question
Gearing Question
Is high gear the slow gearing on a bike.?? Is low gearing the fast gears of a bike.??
How about 1st gear.... Is that the slowest gear of a bike.?? Is 18,20, 22 the fastest gear on a bike.??
This stuff drives me nuts. I need to learn it once and for all.
It's called "higher" because the ratio of rear wheel rotations per crank rotation is higher.
If you're on a 44-tooth chainring up front and an 11-tooth cog in back, the ratio is 44/11 = 4. So when pedaling, every time you turn the cranks in a full circle, the rear wheel will spin 4 times.
If you then downshift to a 22-tooth cog in back, the ratio becomes 44/22 = 2. So the rear wheel now spins twice every time you turn the cranks once: a much lower gear,
The highest gear on my Emonda is when I'm in my 50-tooth chainring up front and 11-tooth cog in back. I call it my highest gear, or I refer to it as fifty-eleven, or some other descriptive term.
Quoted: 523 Post(s)
Liked 229 Times
Don't obsess on what gear you are in. Just find the one that makes pedaling your trike or bike comfortable. My Catrike 700 has the gear range of a road bike. For me, comfort is almost always in the middle range in front, using the 10 gears on the cassette to find a comfortable cadence. If you asked me, "What gear are you in?" I would have to answer hell if I know.
Backwards. High gears are the ones you tend to use when going faster, low gears when going slower.
People mostly don't number their gears like this, because gear ratio counting doesn't convey much information to other cyclists. Two different drivetrains will have wildly different meanings for what "gear 13" is.
And yes, I get it that one can't refer to a gear in numerical language. In other words I can't say.... "I was in 12th gear and my bike makes a noise." That would make no sense to anyone and I learned that in HTpolev's post.
Well, you sort of can. Give the rear gears (cassette) numbers, 1 being the biggest, and the front (chainset) letters - L and H (or L, M and H) for Low, (Middle) and High. So you can then say 'I was in 7H and the bike was making a noise'. I grant you, though, that it's not very universal. Of course, if I use L and H for the chainset and someone prefers L(large) and S(mall) then that could get very confusing.
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
In all due respect you missed my point. My question is, in bicycle talk, what is a high gear or what is a low gear. On occasion people will say... "I was in the highest gear and my bike was making a noise." HTUpolev provided a great explanation. It makes perfect sense.
"Bicycle talk" encompasses talk with people of all levels of knowledge, so if I am talking with someone knowledgeable, I will use ratios. If I'm talking to a beginner, I will say high or low, and make sure they understand high means big in the front and small in the back, and the other way around for low. It helps them both know what to call them and helps them understand how they work.
I know that is more than you asked for, but as you gain knowledge about bikes, I think it's also useful to know how people pass it on. If you ever ride ride with a kid or a beginner, I hope you find this useful. It's also important to remember that a kid has never driven, so high and low is really meaningless to them, and it's not intuitive that harder to pedal can mean faster.
Not universal at all. If you have a 7-speed cassette in back, that might be your high gear. but if you have an 11-speed, it'll be almost in the middle of the range. And that "7" gear might be anything from a 17 tooth gear to a 36 tooth gear. So, still not very useful.
Daft I know but I still have to really think about it and always got it the wrong way round to the extent it's habit ... I think it's partially because I cycled way before i could drive and it just became ingrained.
I always remembered that LOW is SLOW
