Schwinn world sport rear drop ou not milled all the way ?
Is this strange, or pretty much normal -
Basically the drop out isn't slotted all the way across on the drive side.
Thanks.
Srinath.
Thanks.
Srinath.
Looks normal to me. It's got the integrated derailleur dropout instead of one that bolts into the slot; so the slot doesn't need to be open as far back.
Quoted: 576 Post(s)
Liked 1,001 Times
There's a version of this that has the rear portion milled out but leaving a center rib. When there is a skewer you cannot see a thing and it is frustrating trying to get the wheels back.... and then realizing you cannot
Quoted: 645 Post(s)
Liked 797 Times
That's a little weird, especially considering that the NDS dropout is milled all the way back.
Cycleway town
Perhaps the provision is for when a derailleur isn't specified. In that case the slot is needed for chain tensioning, whereas here it isn't.
Quoted: 169 Post(s)
Liked 84 Times
I'd like to see a picture of the other side of the bike.
Quoted: 2479 Post(s)
Liked 2,947 Times
Not a mistake.
If I remember rightly, that dropout design was introduced to ensure that the sprockets would be optimally positioned for the then-new indexing derailleurs. The NDS end was milled to enable centering of the wheel. That dropout design preceded the common use of vertical dropouts.
Quoted: 1066 Post(s)
Liked 780 Times
Not a mistake.
Likes For OldTryGuy:
Ok, I am not fixie'ing this bike then. Cos its all intact and might as well keep it as a unit and sell it as such.
Thanks.
Srinath.
Thanks.
Srinath.
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
Not a mistake.
Señor Member
Quoted: 649 Post(s)
Liked 292 Times
This is so the axle is properly position wrt. the derailleur, but the longer slot on the NDS allows adjustment if the frame is not perfectly aligned.
Many less expensive bikes with horizontal dropouts use a 'claw' type rear derailleur, and the claw acts as a spacer exactly the same way as this short dropout.
Likes For Wilfred Laurier:
I love this forum. Someone posts a extremely esoteric question about a thirty year old, low-priced bike and someone else knows the answer.
Old fart
Quoted: 3582 Post(s)
Liked 3,395 Times
If it bothers you, you can take a round file and extend the slot all the way back, like it is on the non-drive side. But why bother?
Quoted: 4790 Post(s)
Liked 3,918 Times
That accomplishes two things. It located the wheel correctly for the derailleur and it is easy to build and align. All the builder has to get right is the vertical since the user can center the tire by hand. (Dropouts with full slots and no stops are more difficult because yo have to simultaneously locate the hub fore and aft and center the tire if you are using a quick release. Two stops makes putting wheels in straight really easy, hence all older race bikes had the adjustable screws on both sides but just the drive train stop is barely harder and barely slower.
So, cheap to make. Cheap to get past quality control. Easy to use. What not to like? Oh yeah. It looks wrong.
Cheerfully low end
Quoted: 644 Post(s)
Liked 1,044 Times
Otto
