Stepping up in Rideability from Conti 4000
#51
Quoted: 1975 Post(s)
Liked 232 Times
Kind of, most of the weight should be on your feet, also for the seat I find the saddle base material to make the most difference, going from a fizik antares to a fabric scoop with a plastic base that handflexes also made a huge difference in comfort on the gravel and cx bike
#52
I've used Michelin many pro 3 and now pro 4 tires. I ride 12 miles of chip seal on nearly every ride. I use 23mm, but plan to switch to 25mm, when my current tires wear out. They ride good enough for me. I weigh 140.
I plan to buy the endurance version rather than the pro 4 service course.
Contis are notorious for harsh riding. I have gatorskins on my winter bike. I can tell the difference.
I buy tires in groups of three - two for the rear and one for the front.
#53
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Comparing Gatorskins to Michelin Pro3/4 is apples to oranges. They are not the same class of tire.
Gatorskins are objectively harsh and sluggish. I'm not a fan of Continental tires but lets be fair - they have much better tires than Gatorskins.
-Tim-
-Tim-
#54
Quoted: 850 Post(s)
Liked 344 Times
https://redshiftsports.com/shockstop...nsion-seatpost
No reviews for this suspension seatpost because it hasn’t delivered yet, but for $160, this will probably give you the most comfort/$. Whether you’ll still be able to pedal with the same forcefulness is another question. I imagine they did some research into that. It’s my belief that in 20-30 years, road bikes will almost all have suspension of some sort, even if quite minimal because everyone will finally realize the extent to which getting beat up by the road slows you down and skittering across the tarmac reduces your grip. So you have the opportunity to be a pioneer.
You can also try the vittoria corsas like many people have recommended. Unfortunately they’re not available in TLR in the 23c size. So you’ll need to go clincher. However, I personally have been running Orange endurace sealant in my continental race tubes to excellent results. I’ve pulled a nail out of the rear tire and it sealed despite the tire being a normal clincher. I frequently run 40 psi front, 50 psi rear depending on conditions (25mm tires but I weigh 62kg). I’ve SLAMMED potholes at these pressures, and I’m sure I dented my rims slightly but they’re cheap and alloy so I’m not too worried. I’ve literally never flatted. OK, one time a staple got caught in my rear tire and I rode it for around 10 miles (“is my rear soft? No it must be in my head.” Until the sidewall collapsed in a turn because I was probably around 10psi).
The point is, you can go *very* low with tire pressure if you use sealant and have somewhat wide rims (17mm rims with fat 23 mm tires is fine). You’ll have to get used to the fact that the tires will feel squishier (because they are). The tires will feel draggier when out of the saddle because the central tread flexes more when leaning the bike. However, if you’re riding on quite rough roads, I’d bet that you’ll be faster over long distances anyway.
Another thing you can look at is maximizing rim width. You should be able to go up to a 21mm rim with a 23mm tire. This will reduce the floppiness of the tire at very low pressures. You could also go with a very light, low profile rim - somewhere around 21 - 25mm deep. Then go with a relatively elastic spoke like sapim Lasers, CX Rays, DT aerolites or even Spinergy spokes which are supposed actually be a lot better.
#55
- Soli Deo Gloria -
Liked 736 Times
In general, a smaller diameter and longer seatposts will absorb vibration better. Some gravel bikes have seatposts specifically designed to do so. The RDO post on my Niner is one example. I rode a Salsa Cutthroat on a trainer and thought that the rear tire needed air until I realized that the seatpost was flexing. Salsa designed it to do this on purpose.
https://ninerbikes.com/products/niner-rdo-seatpost
The Ergon CF3 isn't cheap but reports are that it really works to absorb vibration.
https://unicornbattleground.com/post...gon-cf3-review
I believe the Canyon VCLF seatpost is designed similarly. It doesn't look like it will play well with Di2 though.
https://www.canyon.com/en-ro/gear/co...st/148286.html
I own the Fabric Scoop Ultimate Carbon with flexible base and again, thought the rear tire was low the first time I rode it because it was flexing. It helps a lot. People riding behind me have commented that they can see the base flex. I'd be surprised if there were not other brands.
My point is that those concerned with vibration damping might want to look into some of the gravel specific technologies and products out there.
-Tim-
#56
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times
We can take lessons from gravel here.
This can't be stressed enough and is a great point. Another area to look is the saddle.
-Tim-
-Tim-
#57
I agree, but a lot of Conti users say that the 4000/5000 ride harshly too. I've ridden plenty of top of the line contis too, but it's been quite awhile. I can't complain about the michelins.
#58
Quoted: 84 Post(s)
Liked 5 Times
Specialized Turbo Cottons 26mm with Latex tubes is pretty darn smooth. I tried the Vittoria G+ and went right back to the Turbo Cottons. First season I ran latex front only because I'm a heavy weight (195) but I've since gone with latex on the back . Incredibly I haven't flatted (knock wood) since I ride some big groups and riding right of the white line in the crap is common. I'm probably just lucky and it's just a matter of time because the turbos are getting worn.
#59
Farmer tan
I run the Vittoria G+ 28c at 90 psi front, 93 rear. I weight 155 lbs. Bike is traditional 531 steel and moderately stiff for those tubes. Open Pro rims, 32 or 36 spokes and as many crosses as feasible.
I'd probably run the 25c tires 10 psi higher.
I will never run a big difference in pressure front to rear. Racing days, the word was 5 psi or less. We never questioned it nor regretted it. Now I hear the "experts" say we should adjust our pressures by the percentage of weight front and rear. No way am I ever doing that! If I hit a stone in a hard stop behind a car, I DO NOT want to ever pinch flat and blow a front tire. But in that hard stop, I have 100% of my weight on that tire. Carefully adjusting the pressure to be best at 40%? Not me! I'll stick to what those vets told me 40+ years ago. Knowledge that was probably 80 years old then.
Ben
Ben
#61
Quoted: 4746 Post(s)
Liked 3,861 Times
#63
Found this site about rolling resistance, some other good info, not sure if it was shared yet or if it helps
https://www.bicyclerollingresistance.com/
I have only ever had Hutchinson Fusion and Vitto Rubino in the past in size 23 and had great luck with both on previous road bike
My new bike came with Specialized Turbo Pro in 28 they are quiet and its super cush, but also have thicker bar tape, cobble seat post, crabon frame and future shock compared to last bike
I ride lots of chip seal, railroad tracks, over tree root risings, low maintained roads, hard pack and the occasional gravel
Had one slow leak flat at 520 miles, took a day to notice. May been to early to review them yet (currently 600miles)
#64
I personally think the gp4k and now the gp5k (have not tried myself) is puncture proof enough imo.
I have read others say the 4 seasons are better. i have no idea. but i have feeling they are right. otherwise why would so many people say these are better?
My own experience is this:
conti with 5mm of yellow "plus" foam/rubber inside. i rode these through a sea of heroin needles! for several years (maybe 10000km in total). and not one single time did they puncture and not one single time did my tires get aids. but lets just say i didn't really lick these ones.
you can can probsbly get by with only vectran/kevlar weave/fabric for a long long time though. it works for me at least.
#65
Bikes: 2020 Trek Emonda SL6, 90's Vintage EL-OS Steel Bianchi with 2014 Campy Chorus Upgrade
Quoted: 452 Post(s)
Liked 162 Times
I rode today seeking out chipseal to try out. I was riding my existing tires at 80F/85R as a very conservative test (highly confident that this will not be creating issues). I will be trying lower pressure later. And I mostly just paid attention to what I was feeling.
1) This is incrementally more comfortable than the low 90's pressures that I had been using.
2) There is a difference between the vibration of chipseal and a bumpy road. This is hardly a surprise, but I had never thought about that. They are pretty different issues, probably having different solutions (it seemed to me).
3) I paid really attention to the transition between good asphalt and the chipseal stuff as in "what is it about this chipseal that is uncomfortable?". And my conclusion was that vibration clearly coming up through the seatpost (as is mostly from the rear wheel) was probably 60% of the discomfort. I was not expecting that. So lower pressures and probably wider rear tires is definitely in play here.
There are other options including other tire pressures (and tire makes/models), latex tubes, and adding some kind of foam cushioning to my handlebars in the "sweet spot" a smidge to the rear of the horns of my shifters where my hands tend to spend most of their time. I am speculating that this will be the same as or more effective than either bar tape or a second glove.
This reminds me of the process that I have gone through more than once of trying to find 'a better sound from my guitar strings' (nylon - I play a classical guitar). But in the guitar case new strings cost (typically) between $7 and $20 and an aggressive 'start to end of string' is only 3-4 weeks. The experiment is a bit more expensive on a bike and the 'natural cycle' a good bit slower.
dave
dave
Thanks for all the very helpful input.
dave
#66
I ride the Specialized Turbo Pro's that came on my Roubaix. Even though the bike is designed for comfort, the 2017 SL4 Sport model rides stiffly. I had been using 95 PSI (according to the gage on my Park pump) but on yesterday's ride I backed down to 80. The difference was easily noticeable. By the way I weigh about 205.
#67
Bikes: Current: 2016 Bianchi Volpe; 1973 Peugeot UO-8. Past: 1974 Fuji S-10-S with custom black Imron paint by Stinsman Racing of PA.
Quoted: 215 Post(s)
Liked 204 Times
due to supple casings.
https://www.renehersecycles.com/shop...6-cayuse-pass/
i personally really like Conti 4000ii. I'm 190 and run 80 front 70 rear no pinch flats ever. I run 28mm tires on A23 rims. Tires measure out to 30mm on those rims.
now that I have my 2019 Specialized Roubaix dialed in I do believe it is a great chip seal killer...Future Shock combined with CGR seatpost.
I am a bit heavier than you and my main set was Compass Chinook Pass 28s that measure a true 28. They are better than the Contis, but I like the Contis also. I just fit replaced the Compass 28s with 32 (true 32) Stampede Pass, but do not have enough miles to really say better, yet. All three of those sets of tires are very good. I find I can ride the Compass with higher pressures yet still be comfortable and not get pinch flats in lightweight tubes.
