Used Zipp 303 Firecrest Wheels
Old 06-14-19, 01:11 PM
Robert A
Bikes: 2019 CAAD12, 2015 Specialized Sirrus Comp
Quoted: 562 Post(s)
Liked 64 Times in 46 Posts
I'm interested in replacing my stock wheels that came on my rim-brake CAAD12 and the price limit is $1k. Two contenders are a used pair of Zipp 303 Firecrest wheels from Proscloset, in clincher or tubular. I've ridden sew-ups for years so I understand the tradeoffs.
These wheels are prior gen to the current 303s with different brake tracks and rim construction. They also have prior gen 11-speed hubs. Compared to the latest 303 Firecrest wheels, how much do these differences matter? Keep in mind that new 303s are well beyond my budget and I would probably be looking at Light Bicycle wheels (or something similar) instead.
Thank you,
Robert
Robert A is offline
Old 06-14-19, 01:15 PM
GlennR
On Your Left
GlennR's Avatar
Quoted: 3004 Post(s)
Liked 2,433 Times in 1,187 Posts
I have 303s that I purchased in January 2015 and have well over 20,000 miles on them. They are BULLET PROOF.
I'm sure there have been 2-3 newer versions and I don't care.. I love the ones I have and the cost to "upgrade" isn't justified.
There was a recall on the front hub so find out if they were done or not. The back has never need touched. Both are perfectly true and never needed any adjusting.
There's a lot of fakes so make sure you're getting REAL Zipps.
GlennR is offline
Old 06-14-19, 01:17 PM
Robert A
Quoted: 562 Post(s)
Proscloset is trustworthy so I'm not worried about fakes. Are you on sew-ups or clinchers, and do you happen to know which hub you have?
Robert A is offline
Old 06-14-19, 01:18 PM
base2
I am potato.
base2's Avatar
Quoted: 1789 Post(s)
Liked 1,629 Times in 933 Posts
WRT The Pro's Closet: I have bought from them before and found what I bought to be accurately described & in good condition. All-in-all, the price was fair, (reasonably well, actually) & I would buy definitely from them again.
If your wheels are purchased from them, I wouldn't even think about it. Just buy 'em. They'll be good.
base2 is offline
Old 06-14-19, 01:20 PM
rubiksoval
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times in 711 Posts
I've seen enough hub failures to not ever buy another set of Zipps, used or new.
I'd go the Light Bicycle wheels route 10x over.
rubiksoval is offline
Likes For rubiksoval:
Old 06-14-19, 01:23 PM
GlennR
On Your Left
GlennR's Avatar
Clinchers and not sure of the hubs.
The rear is the original 2015 and the front has replaced as part of the recall.
20,000+ trouble free miles. Maybe i'm just the only lucky person.
GlennR is offline
Old 06-14-19, 01:27 PM
Robert A
Quoted: 562 Post(s)
What fails in the hub, and how is the issue repaired?
Robert A is offline
Old 06-14-19, 09:07 PM
Noctilux.95
Bikes: Bianchi Oltre XR4 Celeste, De Rosa SK Pininfarina, Giant TCR SL, Giant Revolt Advanced Revolt 0 Gravel Bike, Trek Madone SLR, Cervelo R5 Disk
Quoted: 376 Post(s)
Liked 124 Times in 65 Posts
I had failure on my 2018 Zipp NSW 404’s. No thanks. If you want great value with excellent reliability look at Reynolds.
Noctilux.95 is offline
Old 06-15-19, 05:18 AM
rubiksoval
Bikes: bikes
The flanges rip apart. They're not repaired. They're toast. Have to get a complete rebuild. Hopefully of just the wheel.
Old 06-15-19, 05:47 AM
GlennR
On Your Left
GlennR's Avatar
They've been recalled and replaced. Are you saying that they still have problems because i've not seen/heard any.
https://www.zipp.com/support/recall-information
GlennR is offline
Old 06-15-19, 05:58 AM
rubiksoval
Bikes: bikes
Saw a rear hub last season.
Old 06-16-19, 03:23 PM
bikebreak
Quoted: 129 Post(s)
I rode pre-used older gen 303 firecrest tubular wheels for thousands of miles. Great wheels, never needed truing
The hub recall turned me off. I sold them on ebay, got almost what I had paid. In effect I rented them for 3 years for about $150. So + for resale value
After that I used Easton ec90 55mm, very fast but a bit heavy feeling, then Bontrager Aeolus, then added Enve 2.2. The 303 tubular is still a great all around rim. My set was ~1275g
bikebreak is offline
Old 06-16-19, 03:41 PM
Robert A
Quoted: 562 Post(s)
What's it like living with tubulars these days? I rode them quite a lot in the 70s and somewhat in the 80s. My memory is a little faint when it comes to replacing a tire then cleaning and applying cement to the rim, but I know I did it myself. We didn't have tape back then either. What's it like for you?
So for close to $800, I can get a used pair of 303s from Proscloset. These would be prior-gen tubular style rims, and older hubs. Or for $1,000, I can get a new set of tubeless wheels from Light Bicycle including hub upgrades. Tough call. One thing I like about the 303s is the weight -- only 1200g vs about 1500g for LB. However, it would be nice not having to deal with sew-up cement.
Robert A is offline
Old 06-16-19, 04:16 PM
bikebreak
Quoted: 129 Post(s)
What's it like living with tubulars these days? I rode them quite a lot in the 70s and somewhat in the 80s. ....
I have been riding tubular for the past ~8 years. the double sided tape is great, easy and fast. I've used caffelatex tape. I have also glued a dozen+ tires. Tape lets you get the tubular aligned perfectly.
The other innovation is latex sealants, used as a preventative or to fix a flat. Many rides have been saved over the years, and I get more life out of tubular tires.
With the newer wide rims, the carbon rims are almost always wider than the tires, since tubular tires don't get wider on wide rims like clinchers. This is good for aero.
Ride quality is excellent with vittoria and veloflex, the Corsa speed is very light and fast ~200g but still durable enough for a front tire. The 28mm veloflex tires @60psi are heavenly on any road.
That said, carbon clincher rims have been getting wider and lighter, and some of the new generation rims from enve and others are almost as light in clincher as in tubular. The weight savings is less than it used to be.
Also, the fastest (lowest CRR) tires nowadays are tubeless clincher.
Old 06-16-19, 04:31 PM
Robert A
Quoted: 562 Post(s)
Is double-sided tape a complete replacement for glue, or is it primarily a substitute when glue can't be used (i.e., on the road)? Do you have confidence in downhill corners?
Also, on long-distance rides (say 100 miles), what do you carry for spares?
Robert A is offline
Old 06-17-19, 07:25 AM
bikebreak
Quoted: 129 Post(s)
The tape is for regular gluing, you could use it road side too, but ideally you're supposed to let it dry overnight before riding. It would be no worse than a pre glued spare in a pinch
The caffelatex tape is ridiculously strong, it's good enough for CX tubs, probably overkill for road cornering. Never had a second thought in a corner. It's much easier than glue to get tires off and on, I had to pull a tire to true a wheel (not a 303, those have external nipples), and it was a 3 minute job instead of 30 with glue.
For a long ride I would carry a light spare like a tufo, depending what wheels I'm using. My glue is usually fresh enough that even an unglued spare would stick on the rim ok. If I had a taped rim, that comes off leaving the rim clean, so I would bring some tape and a spare of the same tire and tape roadside if needed.
I usually don't ride more than 50 and don't bring a spare. I haven't done a roadside tub change in 5 years, the sealant canisters have fixed most, except a pinch flat I got from a huge pothole.
Old 01-23-20, 08:52 PM
inspclouseau
Quoted: 45 Post(s)
Liked 6 Times in 2 Posts
Not to revive this old post, but what failed? Mine are being sent back, they're a year and a half old. I had a speed wobble from hard braking and the mechanic said they became out of round (top to bottom, not side to side)
They aren't honoring the warranty and will be charging for repairs. I'm not exactly thrilled.
inspclouseau is offline
Old 01-24-20, 08:06 PM
Noctilux.95
Quoted: 376 Post(s)
My rear hub went bad. Zipp replaced the set and I sold the replacements.
Old 01-24-20, 09:14 PM
colnago62
Quoted: 741 Post(s)
Liked 412 Times in 230 Posts
I had a pair of Zipp wheels from, maybe, 2011 that had the front hub recalled. It sounds like they still can’t get it right. I don’t understand why they don’t just have a company like Chris King supply them hubs.
colnago62 is offline
jstraz85
Road Cycling
2
07-04-16 10:33 AM
santinuro
Commuting
20
06-30-15 12:26 PM
SaiKaiTai
Fifty Plus (50+)
28
07-18-13 12:24 AM
velohenley
Road Cycling
31
06-26-12 09:45 AM
Nickrows
5
12-06-09 07:11 PM
